Looking for: homelink harness 61120434330
05-29-2017, 12:59 PM | #1 |
401
Rep 1,425
Looking for homelink harness 61120434330
3IM . Okada Plasma Direct . Euro Ram Intake . AA header (Pending) . PE . 2nd Cat Delete . F30 340mm 6 pot . EBC Yellow Stuff . StopTech SS Brake Line . BMW Performance CF Strut Bar. 219M . PSS
05-29-2017, 02:00 PM | #2 |
456
Rep 2,749
you do not need that harness if you are not trying to retrofit external autodim mirrors
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
05-30-2017, 05:52 AM | #3 |
401
Rep 1,425
I have a 10 328i, with autodim, i just bought one with homelink, i followed the instruction to hook up with the garage door opener. Erased the old data, then held the "1" button on mirror and my remote control button at the same time. The light indication showed it had already hooked up, but once i drove up to my garage it didnt work. So i need that hardness right?
06-07-2017, 03:19 PM | #4 |
456
Rep 2,749
nope, if the the led near buttons blink when you press them your homelink is connected
the only thing that it is working only when engine started
Blueeyesredpanda400.50 |
06-10-2017, 09:10 AM | #5 | |
Enthusiast
167
Rep 1,622
06-10-2017, 01:19 PM | #6 | |
242
Rep 1,354
The Homelink electronics learns how your transmitter encodes its data and uses that protocol. However you usually then have to also teach the receiver in your garage opener to accept the new rolling codes the Homelink sends out. In my case the receiver would not accept the Homelink initially. I kept trying and found that I could get a pairing when I angled the receiver antenna and put my car at an angle several car lengths from my garage. After doing the pairing that way, I could open my garage doors from a block away... all three required this. I believe the Homelink antenna is part of the mirror electronics. It is quite small, so as long as the transmitter lights up when you press the button, it should be working. |
07-26-2017, 04:13 PM | #7 |
30
Rep 285
I just bought the mirror with homelink, autodim, compass. You saying I don't need the wiring harness? My outside mirrors are standard. What do I use so at least inside mirror works for the 3 functions?
07-31-2017, 04:10 AM | #8 |
456
Rep 2,749
what type of the mirror you have now(old) ? what is your car's VIN last seven digits ?
07-31-2017, 03:02 PM | #9 |
30
Rep 285
08-02-2017, 11:31 AM | #10 | |
456
Rep 2,749
so you need three 20cm wires with square mqs pins to connect power from fzd(roof switch center) to three pins in new mirror your car also have universal telephone(handsfree) and satellite radio preparation so you easily can add those options too
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. Last edited by ptpending; 08-03-2017 at 06:01 AM.. |
08-02-2017, 11:12 PM | #11 | |
30
Rep 285
I'll get some wires and mqs pins. I'd also love to get the alarm telephone satellite radio working. Do you know if my car already has mic and other preps to make them work? |
08-03-2017, 05:58 AM | #12 | |
456
Rep 2,749
you need mic, bluetooth module(mulf2 or tcu MOST) with bracket and bluetooth antenna to get handsfree working for sirius you need sirius module with bracket for alarm you need sensor in headliner, siren and bonnet sensor all these options will require coding you can unclip and lift trunk cover under rear seat backrest, you'll find wiring for handsfree and sirius
08-03-2017, 03:49 PM | #13 | |
30
Rep 285
08-04-2017, 02:54 PM | #14 | |
456
Rep 2,749
