05-22-2017, 10:28 PM | #1 |
that M guy
137
Rep 1,134
MPE exhaust rattle FIX!
Hello Forum Fam, I have been on the e9x forum for years and the f8x forum as well new to the F87 forum but this annoying exhaust rattle drove me nuts when I heard it. WOW.
Okay down to the fix. I jacked the car on a lift, and the main issue here is the clamp when the mpe has been installed. I looked by the canister and it was so close to the heat shield by the rear diffuser I knew something was wrong. That is the rattle my friends either that or the support bar right under the clamp. I simply loosened the exhaust clamp holding the oem mid section to the MPE rear section. Push the pipes closer to each other and tighten the clamp back to where it should be. ( I personally pushed the exhaust can closer as my mechanic tightened the exhaust clamp) NO MORE COLD START RATTLE.
F82 M4 6MT
05-23-2017, 09:41 AM | #3 |
126
Rep 236
Drives: 2017 M2 6MT
My cat back exhaust fixes to rattle have always been to remove any clamps, weld the sections and add an exhaust flex pipe to allow some movement. My last MPE on a 135 was to weld the clamp or remove the clamp and weld. My prior car needed a flex pipe to reduce vibration.
06-03-2017, 09:51 PM | #4 |
that M guy
137
Rep 1,134
Hey everyone so my brother took the m2 for a drive and came home saying it's rattling again... I'm guessing it loosened back up, anyone else experiencing this ? This is a new performance edition m2 should be most recent parts
F82 M4 6MT
06-03-2017, 10:39 PM | #5 | |
1748
Rep 1,892
Drives: M5 CS / iX 50i
Not sure if same applies to you.
https://www.instagram.com/day_laborer/ (DM me from this account) Email: nextlevelautobrokersdc@gmail.com Part-time with Next Level Auto Brokers, LLC https://www.instagram.com/nextlevelautobrokers/ |
06-03-2017, 10:41 PM | #6 | ||
that M guy
137
Rep 1,134
F82 M4 6MT
Deutsches Blut82.00 |
06-04-2017, 09:29 AM | #7 |
440
Rep 492
The MPE is made by company not too far from where I live in UK. I took my car to them. They confirmed to me the rattling on cold start is 100% caused by people not pushing the tips ends 100% all the way home. This is the actual fix.
In reality, there is actually very little room for adjustment on the tips once the exhaust has been fitted. People are pulling the tips out waaaay to far to see the "M" logos. If the complete system has been fitted correctly and aligned perfectly underneath the car then the tips should only require a few mm here and there for OCD adjustment. The ends of the main stainless steel pipes coming from the muffler should not be seen through the perforations in the exhaust tips. I guarantee if you unscrew, push right home, and torque back up, maybe a little more than the recommended 5nm (but don't go silly) your cold start rattle will go. |
CommitConfirm474.50 Smiley1175283.00 JustChris17503.50 bazerk00718.50 Howzer739.00 TonySCV510.00 F87EVO4036.00 jas159898.50 |
06-04-2017, 12:07 PM | #8 | |
23
Rep 26
06-05-2017, 04:51 AM | #9 | |
287
Rep 344
06-07-2017, 01:23 AM | #11 |
that M guy
137
Rep 1,134
I'm pretty sure they just brought the pipes closer and re tightened the clamp today at service under warranty. Let's see if it comes loose again
F82 M4 6MT
06-16-2017, 04:51 PM | #12 | |
283
Rep 1,017
My tips were sticking out quite a lot which I thought looked a tad silly, so was glad to discover they could go further back (in). But it hasn't completely solved the issue. Also, I'm pretty sure it's only the right side that makes the rattling sound on my car. It now only does this for a second on cold start since moving the tips. |
06-21-2017, 02:26 AM | #13 | |
31
Rep 138
I found the 5nm is just not tight enough. Update: never mind, wrong conversion, 5nm actually equals to 44.25 in-lb. it's pretty tight. |
Wilsm2187.50 |
06-21-2017, 07:48 AM | #14 |
440
Rep 492
Its on the instructions that come with the tips. I just increased the torque by hand until i was satisfied it was tighter but not mad tight.
06-28-2017, 05:38 AM | #15 |
S0THPAW
8720
Rep 7,846
@ OP, and BishUK
I had the MPE rattle and I told my dealership about your ideas/fix. The tips are now +/- 2 inches(5cm) more inward below the diffuser rearbumperr than before. And the coldstart rattle is gone. Thanks both. Cheers Robin Now: http://i171.photobucket.com/albums/u298/Mokkiwokki/ex3_zpsilbuipop.png Before)I know angle of picture is different.... Last edited by Robin_NL; 06-30-2017 at 05:08 AM.. |
BishUK440.00 |
06-28-2017, 06:33 AM | #16 |
300
Rep 379
Ok, guess I am going to have to try getting the tips moved more inward. The tips look pretty good although seems they can go in a bit more. I am now going on my 4th clamp, coming pretty much completely loose after every track day/weekend. This is BS and is driving me nuts!
06-28-2017, 07:05 PM | #18 |
83
Rep 156
06-29-2017, 12:11 PM | #20 | |
300
Rep 379
Went to the dealership today and escalated the issue with the service manager. The head tech had a new fix to resolve this issue. Not only was my exhaust rattling but is coming loose at the clamp. They heated up the MPE side of the exhaust pipe and widened a half inch of so of the pipe and put a new clamp on. This seems to have resolved the issue for good for a couple other cars, will see how it holds up. |
06-30-2017, 05:03 AM | #21 | |
S0THPAW
8720
Rep 7,846
My dealer also tightened /fixed the loose clamp(s?) again and even welded it(so I've been told) So far so good. Cheers Robin |
06-30-2017, 01:27 PM | #22 | |
158
Rep 478
What clamp is the one that's coming loose? |
