2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Noticeable shudder/vibration when accelerating from a stop
      05-18-2017, 03:14 PM   #1
Ubermeister
Drives: 2015 M235i
Hey guys I am noticing a shudder/vibration I feel in the gas pedal and hear as well (sounds similar to when the car is in say 8th gear and your going 30mph and punch it hesitates and you get a sort of low rpm rumble??) when accelerating from a stop. It only happens in first gear as well and only for a second or two. It's a 2015 MY FBO with a JB4. I have been running with a mix of 4 gallons of e85 much more recently. Any thoughts or anyone else experienced this? At 24k miles, it's never been tracked, I don't drive excessively hard but I do drive it 🙃. A little nervous because I am about to trade it in for a new gti because of $$. Thanks !
      05-18-2017, 03:23 PM   #2
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
If you;'re about to trade it in why you still running jb4 ?
Do it in map0 and see if it happens again
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      05-18-2017, 10:13 PM   #3
Ubermeister
Drives: 2015 M235i
I tried turning off the JB4 it still happens. I spent some time after work trying to reproduce the issue and it happens in first thru third gear. The car is an automatic if it was't clear. The more I tried to reproduce it the more it feels like something is rubbing when I turn the wheel and accelerate. If I push the pedal down very slowly it doesn't happen, it only seems to occur if I push the pedal down about 30% while the steering wheel is turned either left or right about 3/4ths of a full turn.
Thanks again
      05-18-2017, 10:14 PM   #4
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
If it happened with jb4 off take it to dealer =\
IG: @bmwF9XG80
      05-19-2017, 11:27 AM   #5
XutvJet
5554
Drives: 2011 Cayman Base, 2016 M235
Remove everything and see what it does. If it's still there, take it to BMW for a look.
      05-19-2017, 01:41 PM   #6
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
probably warped rotors.
www.nybmwcca.org
Current Cars:
1995 M3 Coupe Manual Alpine White
1997 M3 Sedan Auto Cosmo Black Metallic
2018 x3 m40 Auto Grey Metallic
      05-19-2017, 01:41 PM   #7
amw896
amw896's Avatar
583
Drives: 2015 BMW M235i
2015 BMW M235i  [10.00]
Awd? Where do u feel the vibes? In the seat? In the steering wheel? front or back of car? Need some more info to help.
      05-20-2017, 10:14 AM   #8
Ubermeister
Drives: 2015 M235i
It is awd, and I feel it in the mostly in the accelerator/front of the car. If the car is in neutral and I rev the engine I get none of vibes/shuddering. If starting off from a stop it only happens at <2k rpms. If I am already going forward and intentionally change gears to lower the rpms (i.e. Going 40 mph and manually changing to 7th gear) it will not shudder but act as expected being in a high gear but moving slowly. I will hopefully be able to get it in to a dealer on Monday I just have a lot of driving to do before then and don't want to get stranded on the highway.
Thanks again for any other insights or thoughts!
      05-20-2017, 10:21 AM   #9
amw896
amw896's Avatar
583
I would have them start with the transfer case, front diff, and front cv axle/prop shafts. I mean, ur trading it in anyway so I wouldn't worry too much but good luck!
2addicts
