Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Fender liner destroyer with 19 OEM M3 wheels
      05-18-2017, 08:17 AM   #1
Smurfzilla
22
Drives: E90 335i
So I had my fenders rolled in the front and rear and a spacer in the front to make the front wheels flush with the fender. Tires are nothing crazy (as low as I could go with out stretching) and my fender liners are gone in the front. I can see the back of the fog lights when I turn the steering wheel.
The car is on the upgraded M sport suspension from the factory. I wanted to get a set of Forgestars but if my fenders are getting beat up on the OEM M3's I'm afraid if I replace the fender liners they are going to get annihilated with slightly wider wheels.
What are some of you doing to keep your finder liner in especially with a aftermarket set of agressive wheels........or do you just not ride with fender liners?
I was looking at getting better (IE stiffer) suspension thinking maybe the suspension travel is the culprit. I dont need coilovers because I never change the height of my car once I set it, so coilovers would be a waste of time (I was all set to buy a set of Bilstein PSS's).
Any advice you all could lend would be much appreciated. I'm going to be buying wheels soon and possibly suspension to go with.
      05-18-2017, 08:30 AM   #2
Supra2k6
132
Drives: 335i
what size tires are you running? i'm running 19's 245F 275R. I don't rub on the front and i might be able to squeeze in a 255.
      05-18-2017, 08:35 AM   #3
Smurfzilla
22
Drives: E90 335i
I think its a 245 in front but I'll have to double check
      05-19-2017, 06:59 AM   #4
Smurfzilla
22
Drives: E90 335i
Its 235/35/19
      05-19-2017, 08:36 AM   #5
BeastMode335i
Maximus Decimus Meridius
BeastMode335i's Avatar
1130
Drives: F30 335i
Originally Posted by Smurfzilla View Post
Its 235/35/19
What size spacer?
F30 335i
Melbourne Red Metallic
M-Sport Package
      05-23-2017, 07:34 PM   #6
Smurfzilla
22
Drives: E90 335i
25mm spacer. I assume the 19X9.5 wheels would be about the same fitment (flush-wise).
      05-24-2017, 01:58 PM   #7
YoungBlood
LongDongSilver
274
Drives: e90 335i
in for replies, I'm rubbing with that same tire size and 8.5 +35 offset on Tein springs, I don't get it because my fenders are rolled and that tire size is only like .25 inches taller than oem
N54 E90 6AT: 3" Pipes that go down, Thing that cools the inter, PE Mod, DCI, ST XTA, Whiteline bushings, Aodhan, and lotsa corn-juice
      05-24-2017, 02:13 PM   #8
Antetokounmpo
Antetokounmpo's Avatar
1552
Drives: E90 6MT FBO; '18 F150 Platinum
Yikes. I had a more aggressive wheel with a taller (245/40/18) tire and didn't even rub.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
      05-24-2017, 03:27 PM   #9
YoungBlood
LongDongSilver
274
Drives: e90 335i
what suspension are you on? My front struts are also almost totally blown, and I'm just waiting for my parts to get in, and then when I've got the wheels off I'm gonna fix where the bumper meets to fender, and see where else I'm rubbing in a day or two. I'm just driving it carefully for now though I was running 12mm spacers, without rubbing on the drivers side, but it rubbed over every little bump on the inner fender where it meets the bumper so I pulled them off but I still get rubbing when turning and going up an incline, like a driveway
      05-24-2017, 04:24 PM   #10
Antetokounmpo
1552
Bilstein b12
      05-24-2017, 04:29 PM   #11
YoungBlood
LongDongSilver
274
Drives: e90 335i
hmm, sounds like blown struts, or the fender liner being slightly out of place is probably my issue then, I doubt I'm a whole lot lower than coilovers..
      05-24-2017, 04:38 PM   #12
bryan_E90_28
55
Drives: 2009 BMW e90 LCI
lowered on kw1s
Wheel spec
F: 19x8.5 et 35 and +12mm so that gives me +23
R: 19x10 et 33
Tires : PSS
F:235/35/19
R:265/30/19
No issues on fender lining
      05-24-2017, 05:18 PM   #13
YoungBlood
LongDongSilver
274
Drives: e90 335i
Originally Posted by bryan_E90_28 View Post
lowered on kw1s
Wheel spec
R: 19x10 et 33
Tires : PSS
F:235/35/19
R:265/30/19
got any pics of how low you are? that's very close to my setup (I have 12mm spacers I ran for a day until it ate through part of the liner on the left side) and I'm running 9.5 +23 in the back on that same tire size.
      05-24-2017, 06:06 PM   #14
bryan_E90_28
55
lowered on kw1s
Wheel spec
R: 19x10 et 33
Tires : PSS
F:235/35/19
R:265/30/19
Here you go
      05-24-2017, 08:42 PM   #15
Smurfzilla
22
Drives: E90 335i
I'm on the factory MSport suspension. I was thinking maybe that setup is past its useful life (just crossed over 100k on the clock). I was looking at what to get for suspension. I dont think I need 3k suspension since its my daily and once I set the height I'll never re-adjust. That being said I was seriously considering the H&R Spring/Strut combo or Bilstein B12 kit when I finally buy some F14's
      05-24-2017, 08:49 PM   #16
bryan_E90_28
55
I have koni yellows and h&r on this set before and it had no issues just a bit of roll at the rears. I feel you. This was my daily for a while. This is how the car sits when i was with h&r's
      05-25-2017, 07:46 AM   #17
Smurfzilla
22
Drives: E90 335i
Nice. I might consider those. This is kinda a first for me. Normally I buy the best of the best. After my most recent car ownership fiasco I needed a break but I love car culture so I know I wont stay away.....I'm just kinda over buying brands/labels that look and sound good but dont work as advertised or wont be used to their fullest potential. While I'm NOT looking to buy traditionally terrible products but I'm also no longer looking down on brands that function well but dont have the cachet of more well known brands. I'm going to research the shit out of my suspension choice. I dont mind a slightly stiffer ride. I just want a fun daily that wont allow for fender liners to be beat, lol.
So I'm going to assume its the suspension thats my issue so I'll replace when I replace the suspension.
      05-25-2017, 09:14 AM   #18
YoungBlood
LongDongSilver
274
Drives: e90 335i
that's exactly the height I sit at on Tein's, maybe a hair lower in the front. After reading thread on trimming the bumper mounting tab I think I'm gonna do that, and then take a heat gun to the corner of my inner fender to clearance it the 1/4 inch I need to not rub at all. Honestly with the newer stiffer shocks/struts I've got coming in, I might not even need to do it, my stock struts are getting worse by the minute
      05-25-2017, 09:16 AM   #19
YoungBlood
LongDongSilver
274
Drives: e90 335i
H&R and Tein give very similar drops, having seen them side by side. I've also run both on my car, and Tein are much more comfortable, while still firmer than sport suspension. They both go pretty low though. Honesly if I had coilovers, I'd raise the car 1/4 inch all around at least and it would still have no fender gap
      05-26-2017, 08:14 AM   #20
Smurfzilla
22
Drives: E90 335i
In the car world I come from Tein is synonymous with overpriced marginally ok quality. Maybe they put better R&D into their European products. Its hard to overcome that bias when I've lived with it so long. Plus their cost to rebuild their coilovers was not the greatest. Their springs especially had a horrible track record in the Evo community.
      05-26-2017, 09:19 AM   #21
YoungBlood
LongDongSilver
274
Drives: e90 335i
I got my tein's for $170 shipped, brand new, they've been better than H&R, which are almost $100 more than that. so far IMO for a daily, that you want pretty low, but not uncomfortable, these are the ticket. But my front struts have had it after 100k miles and being lowered on H&R then back to sport height then Tein, that's the reason I'm smacking my fender liner. They also list their springs rates, which I really like. They're stiffer than Eibach, but I can say pretty confidently they're less stiff than H&R. It all depends what you want out of the car, mines a daily, that gets auto-x'd once a month, and see's a canyon run once or twice a month, so for that I think they're perfect. If my car didn't have 100k on it, and wasn't a daily, I'd spring for some $1500 coilovers, but for a daily, a decent set of dampers and springs is all I wanted.
All that being said, stiffer suspension might save your fender liners. Do you know for sure that your front struts are in good shape? I have not hit my right side liner a single time, running the same front tire size as you. My left fender liner, is getting eaten, and that strut is almost totally blown, but I didn't realize it til I put lowering springs on a few days ago. On stock sport springs, the dampers felt soft but not blown, but once I was under the car I realized they were leaking, and my left had almost no resistance to compression, a week of running lowering springs and it's totally gone.
      05-26-2017, 09:26 AM   #22
Smurfzilla
22
Drives: E90 335i
If my car didn't have 100k on it, and wasn't a daily, I'd spring for some $1500 coilovers, but for a daily, a decent set of dampers and springs is all I wanted. That $1500 goes a long way towards new turbos or when injectors go out :P
That is EXACTLy the situation I find myself in. Normally I buy higher end coilovers but really I dont change the height so its mostly overkill for a car that performs daily duties and hurts the occasional feelings stop to stop light or on the highway. I just dont want to beat fenderliners up, so I know whatever I choose will need better/newer struts. Just trying to figure out what makes sense.
So H&R isn't the greatest? I was looking at some of the Bilstein options maybe Koni Yellows with Swift springs?
