2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Misfire @ ~100+MPH
      05-17-2017, 09:21 PM   #1
Chris_B
Chris_B's Avatar
110
Drives: Melbourne Red 2016 M235i
2010 BMW 128i  [0.00]
Misfire @ ~100+MPH
Hey folks.
BMS JB4 Stage 2
Map 2 @ 91 Octane (Don't judge me lol)
ER Charge Pipe
ER 4" Catless
M Perf exhaust
No codes thrown, but butt-dyno notices an inconsistent pull.
Car went into limp (Drivetrain Malf) one time, but never saved a code (on car or JB4).
I'm assuming I need to change spark plugs?
Thinking NGK N20's. What have some of you switched to?
Assuming my ignition coils are okay
Don't mind changing those as well, just want to take it step my step.
Can attach logs later, tomorrow after work.
Cheers!
Past: 2008 BSM BMW 128i 6sp w/ EU spec interior.
Past: 2010 BSM BMW 128i 6sp +Msport
2016 MR BMW M235i
Instagram @project_kristi
      05-18-2017, 03:26 PM   #2
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Post the message message here if you haven't already http://www.n54tech.com/forums/forumdisplay.php?f=35
You'll get some logs advice from more experienced ppl than on this forum and you're able to upload csv file on n54tech.
I'll bet you they'll start off by saying map2 is prob too aggressive for your low octane
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      05-18-2017, 04:05 PM   #3
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
how much gas did you have in the tank?
If less than a quarter tank, the gas will slosh around to the back while on it hard, car will throw a CEL go into limp with drivetrain malf because no fuel got to the pump.
www.nybmwcca.org
Current Cars:
1995 M3 Coupe Manual Alpine White
1997 M3 Sedan Auto Cosmo Black Metallic
2018 x3 m40 Auto Grey Metallic
      05-19-2017, 02:43 PM   #4
ocN55
ocN55's Avatar
560
Drives: '15 M235i 6MT/ '16 M3
Guy has issue with car. Runs Map 2 on 91. Asks us not to judge.
Okay then.
FBO M235i r
F80 M3
      05-19-2017, 02:46 PM   #5
ocN55
ocN55's Avatar
560
I can almost promise you that upgrading coils will not help your inconsistency. Change your map and re log the car.
FBO M235i r
F80 M3
      05-20-2017, 03:31 PM   #6
Chris_B
Chris_B's Avatar
110
I'll do it asap. I've just been busy with life haha. Appreciate it.
      05-20-2017, 03:31 PM   #7
Chris_B
Chris_B's Avatar
110
Cheers. Good thing to keep in mind.
      05-20-2017, 03:39 PM   #8
Chris_B
Chris_B's Avatar
110
Okay then.
Just do everyone a favor and get off the thread.
Just looking for some quick spark plug advice (if anyone's in the same boat I am) not looking to upgrade coils. Maybe you could take the time to actually read the post without being rude?
I run Map2 because I enjoy pushing the car. Get over it.
Map1 isn't spectacular , and Map5 auto tune is totally bogus.
Sometimes I go higher, sometimes I don't. I'm running 91 since I'm commuting so much right now.
Don't need your attitude here, child.
      05-21-2017, 12:38 AM   #9
ocN55
ocN55's Avatar
560
Okay then.
I meant to say plugs too. Changing plugs will not solve your issue either.
Your car boost level is too high for your fuel and your car doesn't like it, neither of which will be changed by changing to N20 plugs nor coils, plain and simple.
Either way you need to post a log or no one can help you.
FBO M235i r
F80 M3
Appreciate 2
      05-21-2017, 09:23 AM   #10
Drpoomanchu
Drpoomanchu's Avatar
308
Drives: AW M235i Man FBO
Okay then.
I think he stated the obvious due to you already knowing that 91oct. Is not sufficient for that map. Burger Tuning advises 93oct. or a mix E85/meth for map 2. Its understandable you want to push the car but there is a fine line when crossing the safe point. Pushing the car safely is the key. You are not pushing the car safely according to tuners and a very good possibility that the car is notifying you of this unsafe condition. I would heed the advise and increase octane and or lower have a custom tune. You could have multiple issues right now and very well could be plug related but just the fact that your octane is not sufficient throws a red flag. You could be damaging the plugs prematurely due to detonation or a number of other factors. When you pull the plugs they may tell you quite a bit.
To add, i believe Luminous and a few others are on stock ignition other than plugs making 550+WHP. Dont think thats an issue.
Appreciate 2
FSociety3812.50
      05-22-2017, 03:06 PM   #11
Chris_B
Chris_B's Avatar
110
Sounds good. I'll remix fuel and make a log after my car gets serviced.
Cheers!
      05-22-2017, 03:43 PM   #12
Drpoomanchu
308
I have purchased the M3-M4-M2 plugs but not yet installed. Cannot give any feedback on them. I do know there are others running them
      05-23-2017, 08:43 AM   #13
bryan_G01
bryan_G01's Avatar
1165
I've been on the s55 plugs for a little less than a year without any issues.
Ppl say the ngk n20s are better, i have not seen anything to back this up.
When its time to change them, I will go the n20 route tho.
www.nybmwcca.org
Current Cars:
      05-23-2017, 10:27 AM   #14
Drpoomanchu
308
NGK N20 plugs are far superior!
In what ways are they superior...? N20's are 2 steps colder than N55 plugs correct..? I was under the impression that S55 plugs were one step Colder than N55's. I always thought plug choice was relevant to application. Curious to hear your findings.
      05-30-2017, 04:35 PM   #15
Chris_B
Chris_B's Avatar
110
I've considered this as an option as well, but I think I'll lean toward the N20's.
Been reading good things.
Side note, no issues in cold weather.
So, I guess it's time for an FMIC.
2016 MR BMW M235i
2addicts
