05-16-2017, 01:34 PM | #1 |
229
Rep 631
Advice to remove snapped locking wheel nut!
To cut a long story short, a BMW dealer replaced a corroded 442m wheel under warranty tonight. When they've put the new wheel on the locking wheel nut has sheared off completely: flush with the top of the bolt.
Now I know accidents happen, but I can't see how the technician didn't notice this? And they certainly didn't inform me of this before I left. I checked the wheel whilst still at the garage but didn't spot anything. When I looked at home (needed to inflate the tyre to the same as the others) I saw that there was something amiss with one of the nuts, although I couldn't at first see what. I looked to see if they'd returned the locking wheel nut to the boot and there it was - minus the pattern in the middle - which is now attached to the bolt in the wheel! Surely they'd have noticed this when it happened???? There isn't even a mm anywhere above the top of the nut to 'grip' onto to remove it. Anyway, I phoned the service department and I've arrange for it to go in asap (will be 8 tomorrow morning) as I'm not happy at all - not at it happening, but at not being told! And the fact that I have been left without a locking wheel nut I would have no way of removing any of the other 3 wheels either if I'd needed to. My worry is now, how on earth are they going to remove the locking wheel nut without marking my brand new wheel? So, any advice that I can pass on to the garage tomorrow will be greatly appreciated. Many thanks |
05-16-2017, 01:58 PM | #3 |
19
Rep 59
I did see a trick where somebody welded a nut on top of the bolt and got it off that way (not sure if I understand enough to know if it is the solution for you
TheLiverBird229.00 |
05-16-2017, 02:03 PM | #4 |
General
8567
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
That's a muppet with an air gun or torque wrench, which is just laziness as everyone knows you find the risk of this with locking wheel nuts.
You're right to be annoyed, I'd be furious.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
05-16-2017, 02:10 PM | #5 |
2647
Rep 3,664
I'm not sure I'm following what's happened?
You said "nut sheared off" - it's a bolt holding the wheel on. The "nut" part is your locking wheel "key" for want of a better word. The bit that lives in your boot 99% of the time. So if the "nut" has broken and stuck to the wheel "bolt" then they should be able to remove that easily without drilling anything and just supply you with a new locking nut. Am I reading that right? As Tengo says though, some over zealous grease monkey with an air gun............ .
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87 |
05-16-2017, 02:13 PM | #6 |
1774
Rep 3,490
Don't stress. They are a BMW dealer.
If they damage your wheel they will have to replace it. It's their fault the locking nut got damaged. Their problem to fix. |
05-16-2017, 02:13 PM | #7 |
170
Rep 616
Get a socket that just barely fits over the bolt that's left and smack it as hard as you can onto the bolt until its tight, it will need proper whacking but once its on, slowly unwind the bolt and it should come off.
Be careful will the whacking and don't hit the wheel, seen a tyre fitter do this and it came straight off. |
05-16-2017, 02:18 PM | #8 |
602
Rep 2,246
05-16-2017, 02:49 PM | #9 |
Fool
1857
Rep 3,542
Dealers have the master set of keys, there's only around 20 combinations so once the sheared off piece of metal from the key is removed, it'll be a few seconds work to undo it. They will then need to replace your key though (or replace all the bolts with new ones).
05-16-2017, 02:52 PM | #10 | |
229
Rep 631
The locking wheel nut (from the boot) the one that's inserted 'over' the bolt on the wheel has a 'pattern' (sorry for the shite wording) that fits into the same 'pattern' on the head of the bolt (that's in the wheel). It is this 'pattern' that has snapped off the locking wheel nut and remains filling the head of the bolt in the wheel. It is completely flush with the head of the bolt so I can't see an easy way of removing it - and therefore getting any traction on the bolt itself to remove it. Maybe it's a bit clearer now, if not I'm screwed because I'm all out of words for bolts, nuts and patterns, sorry. http://i1010.photobucket.com/albums/...psfl7sej37.jpg This isn't mine but this is what's happened. |
05-16-2017, 02:55 PM | #11 | |
229
Rep 631
a) it's their mess, and b) they'll be the ones supplying a replacement wheel / bolts / locking nut etc if they damage it |
05-16-2017, 02:56 PM | #12 |
76
Rep 181
So if I understand correctly the insert pattern part of your 'key' is stuck in the head of your wheel bolt?
I think they can get that out with a punch and hammer, the head of the locking nut should protect your wheel as it protrudes enough to get a removal tool onto it which will shag that bolt. They can then remove the bolt and the other 3 on the other wheels & replace them & provide you with the correct locking key for the replacements. The mech probably air wrenched it up & didn't even notice the key had broken & left part of itself on the bolt. |
05-16-2017, 02:58 PM | #13 | |
2647
Rep 3,664
Either way - let them sort it and while you're there, ask them what happened to the quality control of the workshop!
Current: M4 G82
05-16-2017, 02:59 PM | #14 | |
229
Rep 631
05-16-2017, 03:06 PM | #15 | |
6659
Rep 15,858
Should not be too difficult to remove, doubt it is the first time a dealer has had that problem to deal with. I'd lightly tap the sheared section, (hammer and angled punch), in the opposite direction to being tightened, should become slightly loose. Then it will probably pull out with a strong magnet. Worked on many items like that in my past, plus the 'weld on nut' (where appropriate) and removed many a sheared stud, or bolt. |
05-16-2017, 03:10 PM | #16 |
2766
Rep 4,577
I had to order a new locking key last month. I don't think they are the best quality and break easily.
Good luck in getting it sorted! |
05-16-2017, 03:10 PM | #17 |
Fool
1857
Rep 3,542
Of course if you have no trust in the dealership, you could always do it yourself: http://www.ebay.co.uk/itm/WW4034-BMW...cAAOSwc-tY5Op1
05-16-2017, 03:53 PM | #18 | |
10995
Rep 32,881
05-16-2017, 04:14 PM | #19 |
133
Rep 570
It it the pattern part of the locking key stuck in the head of the bolt then it shouldn't be too difficult to remove.
Not sure if a magnet might work as it's not held in by anything |
05-16-2017, 05:03 PM | #20 |
Occasional Lurker
190
Rep 589
There are specialist removal tools for this job if they can't remove the piece
The dealer will have something like this in their kit http://www.ebay.co.uk/itm/BERGEN-Loc...UAAOSw9NdXp2e1 http://www.ebay.co.uk/itm/Emergency-...25_DD7lv5I8hSg
Current: F87 M2 Competition
Gone: F36 420D M Sport, F30 Tanzanite M-sport, E90 lci Bluewater M-sport, E90 Le mans M-sport, E46 lci 320d SE Topaz blue, E36 318d Compact Montreal blue, E36 318d Compact Titan silver |
05-16-2017, 05:35 PM | #21 |
10995
Rep 32,881
That won't work mate, it's broken off because it has rotated the key pattern within the bolt pattern, wedging it in.
05-17-2017, 01:02 PM | #22 |
229
Rep 631
Went to BMW this morning - took about 45 mins to remove the sheared nut, but they managed to do it keeping the original bolt intact. I've got a new locking wheel nut that fits all 4 wheels (I've checked). The new alloy is still unmarked (as far as I can see.).
They were very apologetic about it all but the actual tech who tightened the bolts wasn't in today! Anyway, panic over and happy BMW driver again! And thanks for all the help, advice and reassurance. |
Rukka2647.00 HighlandPete6658.50 |
