05-08-2017, 06:37 PM | #1 |
71
Rep 289
Window problem
Okay so not sure if this has came up before I've got a 2012 f30 and about a month ago I tried putting my window up on drivers side, window came up, and then came back down about 4 inches tried again and again until finally after keeping it down for a while n doing it in small bursts it came up fully, doesn't do it all the time just every now and then now the passenger side has started doing same, anyone else had this ?I've rang Williams they said they can fix it by reprogramming it for £169 anyone else thinks it may be hardware problem not software?
05-08-2017, 07:11 PM | #2 |
Rep 10
try resetting the windows ... push down the button to roll down the windows and keep pushing it down for 20-30 seconds ... then put the window up again
05-09-2017, 12:47 AM | #4 |
13347
Rep 7,484
IIRC there was a number of F30's affected by this issue. The window regulator was replaced by the dealer. See here: http://f30.bimmerpost.com/forums/sho...d.php?t=736824
05-09-2017, 04:57 AM | #5 |
71
Rep 289
Thanks mate no real answer tho, my car is out of warranty BMW went to charge me a hours labour to diagnose n reprogram the windows, but my worry is that if they do so and I still have issue I'm 170 down and no better off then I will have to go buy new regulators and fit them myself, if it's a common issue to BMW is there anyway I can get this fixed by them for free ?
05-09-2017, 05:57 AM | #6 |
2647
Rep 3,664
Yup - as Broken_Gearbox says - known issue. Had this too on my 62 plate F30 (come to think of it, that fcuking car was riddled with faults....)
Window first started playing up and then completely died within a week. Drivers side regulator replaced under warranty. Have you had a horn die yet OP? That will be next......... .
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87 |
05-09-2017, 05:59 AM | #7 | |
71
Rep 289
05-09-2017, 06:06 AM | #10 |
1388
Rep 2,127
Surely if after investigation and a reprogram, the problem is not fixed, then they have not provided the service you paid for? If their investigation was done properly, then they would know if they reprogram would work or not, and if they say it will, then it does not, you shouldn't have to pay. Its their fault for getting it wrong, not yours.
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
05-09-2017, 06:12 AM | #11 | |
71
Rep 289
05-10-2017, 12:15 AM | #12 |
13347
Rep 7,484
I have not done one myself... at this stage you want to find out if your VIN is one of the cars that may have been affected and there is no charge for this check... if it is then you go to the dealer and it is done without quibble... warranty or not. They are more likely to play ball if you do have some kind of warranty or good service history in place.
05-10-2017, 12:19 AM | #13 | |
13347
Rep 7,484
Having said that the job can be done as a DIY if you are confident removing the door trim... an independent garage should be able to do it too if DIY is not your thing... we're probably talking 1.5 hours labour tops + part + VAT |
05-10-2017, 03:31 AM | #14 | ||
451
Rep 1,201
Dearler A told me You have not logged in properly to your connected drive account and basically fobbed me off. Dealer B took 6 weeks but correctly diagnosed the fault, replaced the part and explained and spoke to me like a human being.
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d |
05-10-2017, 03:28 PM | #15 |
453
Rep 1,116
I've had this on a couple of cars, both times down to a bit of crap on the seal triggering the anti-finger-chop mechanism. Have you tried running a wet microfibre round the seals to clean them out?
05-10-2017, 03:33 PM | #16 |
71
Rep 289
I haven't sir however I'm stripping door down tomorrow so I shall do just that thanks
05-10-2017, 03:59 PM | #17 |
71
Rep 289
Well just tried that cleaning moving window up n down n the. Guess what it worked the one button such worked! Window went down on one touch and came up on one touch... however...sadly now it won't move at all and is stuck in the up position anyways got replacement regulator and motor coming tomorrow so hopefully that will be the fix oh joys of owning a f30
05-10-2017, 04:04 PM | #18 |
453
Rep 1,116
You're welcome. Unless you need to strip the doors down for some other reason I would try a good clean and maybe some carbaflo first. It only takes a bit of dirt and a dry seal to activate the anti-trap.
05-10-2017, 04:08 PM | #20 |
71
Rep 289
Gimlitehdwarf54.50 |
05-10-2017, 10:15 PM | #22 |
13347
Rep 7,484
