05-05-2017, 08:12 AM | #1 |
Rep 27
Autowatch ghost
Any body fit the autowatch ghost to there car and if so what do they think? . Key Signal jamming is becoming more common wondering is this the best solution?
05-05-2017, 11:40 AM | #4 |
1135
Rep 2,808
I was going to but never got round to it. Must admit if they want my car I don't want a baseball bat or worse in my face demanding the start code.
Current: G26 i4 M Sport Pro, Tech Pk, Sunroof
Previous: 2016 440i MPPSK, 2014 330d Saloon F30, 2013 Audi S4 Avant, 2011 Mercedes C350 |
05-05-2017, 12:06 PM | #5 |
6419
Rep 8,500
I have a Ghost on my car. Brilliant. Works flawlessly, can't be jammed, won't be found.
Am lucky enough not to live in a baseball bat area but if I did I'd just chuck them the key then take photos as they failed to work out why they couldn't drive away.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
05-05-2017, 02:34 PM | #7 |
423
Rep 644
Yeah I've got it fitted too, has worked flawlessly since installation and cuts the car dead if PIN not entered after starting. No visible signs whatsoever that it is installed. Cost me around £400 installed by RAM Mobile in Wakefield. Car is still under warranty but that doesn't worry me too much to be fair.
05-05-2017, 02:48 PM | #9 | |
6419
Rep 8,500
It also has Bluetooth : if the App is active on the 'phone and the 'phone is in range, there's no need for the PIN entry. Given the range of Bluetooth, I don't use tis feature.
05-05-2017, 02:51 PM | #10 |
423
Rep 644
No it's not an OBD protector. It's basically electronically connected to the ECU and relies on you entering a unique PIN (user configurable) once the car is started via your steering wheel buttons. If the PIN isn't entered the engine will cut out as soon as the ECU senses the wheels turn
05-05-2017, 04:37 PM | #11 | |
6419
Rep 8,500
05-05-2017, 05:42 PM | #13 |
6419
Rep 8,500
Ah, didn't appreciate that.
Hugrov423.00 |
05-05-2017, 11:24 PM | #14 |
13347
Rep 7,484
So it's a bit like Clifford Black Jaxx but you're using the PIN to start the car rather than for anti-hijack or does it have that feature too?
If it does then I am in. |
05-06-2017, 01:39 AM | #15 |
709
Rep 1,696
I enquired about the Ghost and it seems a really great product. The only thing that concerned me was that BMW told me that it may affect the warranty (because it's connected to the electronics of the car) when I rang them to ask their advice. However, some lads have it anyway. It depends on your personal take but as it goes there's probably not much out there that is effective as the Ghost...apart from Boris maybe!
05-06-2017, 03:35 AM | #16 | |
6419
Rep 8,500
05-06-2017, 03:50 AM | #17 | |
423
Rep 644
05-06-2017, 12:08 PM | #18 |
243
Rep 1,205
If it is undetectable how could it affect the warranty
It's not quite like having a remap - there really is no trace of this as far as I know ? I haven't got it but was considering it or a Cat 5 Tracker with driver recognition card to avoid key cloning - but with Trackers I think I am right in saying the car can be scanned by the thief to find out if there is a tracker as they emit a signal (? Quite happy to be proved wrong !) |
05-06-2017, 01:43 PM | #20 | |
423
Rep 644
As far as warranty is concerned my thinking was/is that a warranty is useless if the car is gone and I firmly believe that the chances of the GHOST causing any issues are negligible. Last edited by Hugrov; 05-06-2017 at 01:55 PM.. |
05-06-2017, 01:49 PM | #21 |
423
Rep 644
I'm not sure tbh, personally I think it would involve splicing into the CANBUS lines but even BMW use wire taps in their own repair and retrofit kits, i.e. I'm fitting a OEM reversing camera kit which needs connecting to the CANBUS and that's done with wire taps.
05-06-2017, 01:59 PM | #22 |
1517
Rep 3,560
