2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning m235i 2016 Dyno Results
      05-04-2017, 11:37 PM   #1
Amack
Australia
101
Drives: EB 2016 M235i
Hey Guys,
So went and had a dyno done today at one of the local tuner places.
Car is:
2016 - 235i
VRSF DP
BMS CIA
Active AutoWerke IC
JB4
Running 30% E85 rest 98.
So I didnt do a stock run and I only wanted to do E85 runs so I only did runs with Map 2 and Map 5. I was surprised to see Map 2 came out a head by only the slightest margin.
That said however I was still a little disappointed by the results.
Map5 - 249 KW
Map2 - 251.4 KW
I was really expecting to hit somewhere around 265+ with the mods I have coupled with the E85. I was told however this particular Dyno does read 10% lower then most so that would place me in that range but without comparison I dont have anything to really go by. Further to this the guy at the place didnt know what gear to run it in so i suspect 3rd was what he ran, and I never got an accurate Torque readout either which is a little upsetting.
I dont have a JB4 data cable so im unable to start logging. Let me know what you think about the numbers, and potentially what could be done next time if anything.
      05-05-2017, 09:49 AM   #2
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Since you're using a different Dyno other than Dynojet, you should of done a map4 run.
- Dyno + Log = A Must
- I wouldn't be driving blindly without logging or seeing you have proper settings/adjustments and on latest firmware
- Numbers don't mean anything without a baseline
- find a Dynojet ; dyno in 4th or 5th gear u can dyno ; dsc off
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      05-05-2017, 11:05 AM   #3
XutvJet
5554
Drives: 2011 Cayman Base, 2016 M235
~250KW is around 340whp which seems low for the fuel and mods. However, if they ran in 3rd, the numbers will be lower. Running in a gear closer to a 1:1 ratio should help push the numbers up 5% to 7% or so which would be about right (~365whp).
      05-05-2017, 04:19 PM   #4
Amack
Australia
101
not sure if dynojet is avail in aus?
was speaking with Terry from burger, he advised Map 2 and 5.
brand new jb4 so firmware is the newest.
      05-05-2017, 05:27 PM   #5
jmwilson125
341
Drives: 2016 M235i
I am not sure that new tune necessarily means most up to date software. If distributor has jb4 in stock they are probably in storage waiting to be shipped. It may be "new" bit sitting in a box for the last couple months. New software comes out all the time. Does anyone know if jb4 are typically up to date when they ship out? I'd be curious to know.
      05-05-2017, 08:32 PM   #6
Drpoomanchu
Drpoomanchu's Avatar
308
Drives: AW M235i Man FBO
Agreed, 11.hex was in beta for a bit before it was released recently. Its a very good possibility you are at least one update behind. you should check the firmware and invest in the rev 3 bluetooth connect dongle. Its worth every penny. The newest firmware is EWG 11.HEX. The firmware is very smooth and improved imo.
2addicts
