05-04-2017, 08:11 PM | #1 |
1084
Rep 2,361
Engine oil measurement stopping at 15-17%
Hi
UPDATE: It's not because of the below valve, but because the oil does not have the right temperature that the measurement stops at 15-17%. Oil temp must be between ~65 and 100°C and as operating temp is 110-115°C the level must be measured during warm up (pretty stupid and even more so that no information is provided in iDrive)... IF the measurement still does not work, the next step would be to check the below valve for functionality. ************* I have been having this issue for a while but finally decided to do something about it. A bit of research revealed that the problem most likely is this valve (which I can now confirm): Hydraulic valve 11417622768 1: Disconnect battery 2: Remove undertray 3: Remove 3pc screws for waterpump 4: Disconnect waterpump and valve 5: Remove 1pc screw for valve 6: Turn valve 90° CCW (then you can get a finger behind it) and remove 7: Exercise valve/check function with 12v 8: Reinstall and see if it now works
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) Last edited by harkes; 01-09-2018 at 07:52 AM.. |
05-04-2017, 08:41 PM | #2 |
1084
Rep 2,361
Jason Move to Maintenance section perhaps?
(A Dane in China) |
05-06-2017, 12:01 AM | #3 |
1084
Rep 2,361
Update
I found that the oil has to be between 65 and 100 degreeC for my car to measure it. Below the measurement will not start and above it stops at 15-17%. Nothing wrong with the mechanics probably.
(A Dane in China) |
06-28-2017, 11:44 AM | #4 | |
Rep 5
Where did you find this information? From a BMW dealer or service or there is some documentation that you found ? Thanks |
09-07-2017, 02:26 PM | #5 |
128
Rep 403
maybe if everybody can try that, mesure oil level at 120 degrees C , my car does the same thing, it will stop between 15-17% above 100 degrees C.
09-07-2017, 07:48 PM | #6 |
1084
Rep 2,361
Tested it myself. Would be cool if you tested it too! 100°C = 212°F.
(A Dane in China) |
04-19-2018, 03:29 AM | #8 |
Rep 5
Update:
They replace both hydraulic valve 11417622768 and the oil sensor. When I start the car and keep it idle until 'Start Measurement' become available - it measure for the first time. (it took at least 5-7 minutes and when it was cold even more than 12 minutes) I checked the temperatures : where like 89 for water and 78-79 Celsius for the oil. If I try a second measurement in a minute or up to 80 Celsius degrees oil temperature - it always quits at 15%. I think that it is 15% or 17% depending on software version Fortunately that is working at least once - but this is odd not to work even above 80 Celsius degrees... For example on a 2012 F30 328i is working just fine at 115 Celsius degrees... |
02-09-2019, 01:37 AM | #9 |
1084
Rep 2,361
Added info:
Using ISTA to trouble shoot the oil level measurement it automatically set the revs at 2000rpm until the oil has reached 90°C.
(A Dane in China) |
10-19-2019, 12:54 PM | #10 |
Rep 5
Anyone figured out the problem yet? Out of nowhere my GR started to do the same thing with measuring the oil. It stops at 15-20% when measuring, my trunk won’t lock and I get a weird sound from possibly the frame when I have 1 or 2 passengers and take a turn. It sounds like there’s too much weight on a metal or cracking your knuckles...
10-20-2019, 09:56 AM | #11 |
26
Rep 55
Mine would stop at 17%. Started right after an oil change. When the garage threw out the oil filter, they also threw out that little thingy inside the oil filter. Bought a new thingy and it's now fixed.
10-20-2019, 07:46 PM | #12 | |
1084
Rep 2,361
(A Dane in China) |
10-20-2019, 08:29 PM | #13 | |
8270
Rep 16,128
Requirements (for detailed oil measurement) ▷ Vehicle is on level road. ▷ Steptronic transmission: selector lever in selector lever position N or P and accelerator pedal not depressed. ▷ Engine is running and is at operating temperature. |
10-20-2019, 10:25 PM | #14 | |
1084
Rep 2,361
(A Dane in China) |
10-20-2019, 11:38 PM | #15 |
2984
Rep 6,036
The car measures the oil level or oil pressure throughout the driving cycle and will let you know if you need more oil, so no need to measure it manually.
10-21-2019, 06:34 AM | #16 |
1084
Rep 2,361
Because we care for our cars and just out of interest for the oil consumption
(A Dane in China) |
01-15-2020, 06:34 PM | #17 | |
Rep 1
I tried to measure the oil level with the temperature up 125 °C and it works. To check the oil temperature you have to access the hiden menu, pressing the button in the panel during ~7 seconds, after unlock the other options (the password is the sum of the last 5 VIN numbers). I tried many times and i only can discover it because the comments below. Thanks to all. |
01-15-2020, 08:07 PM | #18 | ||
1084
Rep 2,361
(A Dane in China) |
06-22-2022, 06:59 AM | #19 |
Rep 27
06-22-2022, 09:14 PM | #20 |
1084
Rep 2,361
Years since I used ISTA last time - sorry mate
(A Dane in China) |
03-16-2024, 01:20 PM | #21 |
Rep 15
Hey I had same problem. Make sure your engine oil cap contains the same plast net which should go onsite the oil filter, at the tip you need to have a rubber gasket as well.
Usually when oil measurement process stops at 17% it means there is not enough of pressure which can be built inside the system. |
