04-29-2017, 12:37 PM | #1 |
74
Rep 126
Turbo go bye bye
My turbo just stopped producing boost without warning at 3100. No fault lights and I don't have the ability to check codes. I'll report back once the service center has a go at it.
2017 340i xDrive
MPPSK More to come |
04-29-2017, 08:15 PM | #2 |
1412
Rep 3,211
04-29-2017, 08:16 PM | #3 |
74
Rep 126
Yeah, I'm too chicken to mod at the moment.
2017 340i xDrive
04-30-2017, 09:33 AM | #4 |
200
Rep 536
Drives: 2013 335xi Alpine White
Wow you just got your car...might be a loose charge pipe rather than the turbo...let us know when you finally get back on the road.
05-01-2017, 10:47 AM | #5 |
74
Rep 126
I just got a call from the service rep and they say absolutelt nothing is wrong with the car. All of us as car guys know when something is wrong with the car more often than not before the car itself does. We'll see if he managed to inadvertently jostle something back in to position. For your reference, symptoms were no increase in acceleration force indicating positive boost, a quieted turbo, and I spent roughly 50% longer in each gear than normal when accelerating.
2017 340i xDrive
05-02-2017, 09:53 AM | #6 | |
200
Rep 536
I recall from previous threads that early F30 335i's with MSport were having problems with their turbos - sluggish turbos, excessive fan speeds and limp mode - caused by faulty cooling. While this may not be exactly what you are experiencing, and you are in a B58 as opposed to N55, I'm not sure how applicable this info is. But it is food for thought. However, I also know that B58's are being delivered without sufficient coolant in their second reservoir, leading to low coolant warnings for their owners. You may be experiencing side effects of low coolant - but not low enough to trigger a warning light. Good luck and keep us posted |
05-07-2017, 01:17 AM | #7 | ||
74
Rep 126
Long story short, the turbo is behaving properly now. I imagine the waste gate was stuck open since all the tech did was jostle things about and now it's hunky dory. There is a silver lining, however. Since I couldn't pick the car up until this weekend I opted to have them install the MPPSK and let me tell you... it's fuckin nice.
2017 340i xDrive
05-17-2017, 08:42 AM | #9 |
1412
Rep 3,211
Alot if not most of these techs just hug the ISTA software and maybe check for problems others have experienced similar to this.. which I dunno about the others but I've not heard of on the forum.
If you ever find one who can think on their feet stick to them like fly on sh!t. Keep us updated if it happens again.. BOL BTW I would consider doing some logging as a baseline so you have some #s to compare with if the issue crops again.. |
