04-27-2017, 11:22 PM | #1 |
21
Rep 87
Burger Tuning Question for M235i
Hey guys,
I'm the proud owner of a slightly used 2015 BMW M235i. This is my first beamer and first time modding a car. I really don't want to change stock exhaust or intake. I was just thinking about doing an ECU tune from Burger which comes highly recommended from a fellow BMW friend of mine. I found 2 options from Burger. The JB+ is only $199 and looks easy to install: https://www.x-ph.com/burger-tuning-b...install-tuner/ The Stage One is $379 and a bit more complicated but looks to give a little more performance (+5 whp/ +10 wtq): http://www.burgertuning.com/f_series...all_tuner.html I found a local shop that would install the Stage 1 for me for $100.
I don't race but I wouldn't mind a performance boost for passing on the HW. I like the idea of the simpler ECU (JB+) that is much easier to remove when servicing my car at the dealership. Thoughts? I attached an image of my M235i and departing Lexus IS350F for fun. Last edited by Audioholics; 04-28-2017 at 12:03 AM.. Reason: additional info |
04-28-2017, 01:53 AM | #2 |
340
Rep 716
Drives: F90 M5
I have the stage 1 and love it. And let me tell u its a good amount more than a 5hp gain. More along the likes of 25-30
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct Hmu on Ig: @n55_shayan |
04-28-2017, 09:24 AM | #3 |
255
Rep 490
Just get a stage one. It is a piece of cake to install. After you disconnect the battery or pop the hood/lock the car and leave it for 15 minutes with your keys left in the house, it only takes about a minute to unplug your MAP and TMAP sensors (which are located on your chargepipe toward the throttle body and towards the back of your valve cover) and plug the stage one tuner in. Don't even bother with the JB+, it's a waste of money IMO.
They do not compromise engine life, N55's are pretty bullet proof engines and the stage 1 is fairly conservative for a tune. All of your modes work just as they're supposed to and it doesn't effect driveability. No sparks plugs or coil packs need to be changed. If you're interested in the stage one, I have one for sale for $220shipped. |
04-28-2017, 11:44 AM | #4 |
243
Rep 447
These aren't ECU tunes, they are piggybacks, just to clarify. They trick the ECU into running more boost. Both are perfectly good solutions for some extra power and both are under 10 minute installs once you figure out which plugs you are going to be using. Unless you're completely inept, get the Stage 1 over the JB+. The only reason the JB+ exists is because Dinan came out with a simple 1 plug solution and it is designed to offer a cheaper solution than the Dinan option.
'15 M235xi | BSM/Oyster/Aluminum | Black Kidneys | RW Carbon Mirror Caps | 40% tint
04-28-2017, 11:55 AM | #5 |
21
Rep 87
04-28-2017, 11:56 AM | #6 | |
21
Rep 87
04-28-2017, 11:57 AM | #7 | |
21
Rep 87
04-28-2017, 12:00 PM | #8 |
340
Rep 716
Drives: F90 M5
Ohh okay i read that wrong sorry bro haha
04-28-2017, 08:31 PM | #9 |
922
Rep 5,538
You don't need to disconnect battery and wait 15 min, Stage 1 takes 5 minutes to install, JB+ takes 2.5 minutes Do they compromise engine life.... probably not, they do compromise the life of turbo since you are running higher boost
04-29-2017, 12:45 AM | #10 |
21
Rep 87
What about a chip like this instead of the Dinatronic or Burger options?
https://www.racechip-usa.com/chiptun.../M-235i-240kw/ |
05-03-2017, 05:31 PM | #11 | |
Joint Chiefs of Staff
24198
Rep 190,805
JB+, Jb stage 1 and Dinan sport are all good options with their own pros and cons JB stage 1 will give you the most gains (install is still easy, takes less than 5 minutes) JB+ is the best value Dinan sport is a JB+ w/ bluetooth connectivity
Shayan55339.50 |
05-16-2017, 04:39 PM | #12 |
MT or bust!
170
Rep 289
Drives: 2010 E90 335i M Sport, 6MT
"Bimmer"...just sayin. Welcome to the club.
2010 E90 335i M Sport, MT - BMW PE; VRSF 7in HD; RB PCV; VRSF CP; Turbosmart KPB BOV; M3 Cowl; VRSF Cerakote DPs; Carly coding; ECS Scoops; Ziza interior LEDs; Fuel-It! Bucketless; Diff lock down brace V2; MHD E60 Map from BQ; Mishimoto OCC; Fuel-It! Ethanol Sensor; Apex 18x9 ARC-8's; StopTech slotted rotors; HPS pads; ECS brake lines; MMP turbos, inlets, outlets; 034 mounts; Kumho PS31s; BimmerLife coils
