M2 Technical Topics > Track / Autocross / Dragstrip > Brake sensor - not fitting in new pads
      04-27-2017, 01:46 PM   #1
M2joey
M2joey's Avatar
300
Drives: M2, 335is, X5 M50i
Put on a set of PFC 08s and the sensors do not fit into the pads. The steel plate back on the pad is too think and not beveled like the stock and some other pads. So, I used a file to narrow the sensor plug area down a bit. The front is fine, rear is off a bit.
Anyway, getting a warning on the rear now. Does anyone know if this will cause trouble (ie will not allow you to disable DSC, will back you out of sports +, etc.)? From a quick drive it appears not. Or will it allow you to drive and just show the warning? Assuming I will just have to deal with the warring until I resolve the issue.
BMW CCA and PCA HPDE Instructor
Former BMW CCA National Capital Chapter HPDE program Chairman 2021-2022
      04-28-2017, 08:43 AM   #2
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
Just tie up the sensors when using track pads don't know why you tried to jam them in track pads.
      04-28-2017, 11:23 AM   #3
M2joey
M2joey's Avatar
300
I don't want to hear or see any warning lights, etc. Also, wanted to make sure the M2 doesn't do anything like it does when a low tire pressure is detected.
Pagid and most others take the extra step in the manufacturing process to better accommodate sensors. Guess it is not a big deal really, looking forward to see how these pads are.
      04-28-2017, 01:10 PM   #4
CosmosMpower
2051
The car doesn't know if the sensor is in the pad or tied up
      04-29-2017, 04:29 AM   #5
Wangspeed
51
Drives: BMW M2
+1. I use PFC 08. Just tie them up. No warnings.
      05-01-2017, 08:35 AM   #6
M2joey
M2joey's Avatar
300
Thanks.
After some investigation, I found I dug half way through the sensor cable a bit when attempting to get it in the pad. Must be the reason for the warning light, etc. given you guys are not getting it with the cable just being tied.
      05-01-2017, 03:27 PM   #7
CosmosMpower
2051
Get a new sensor tie it up
      05-02-2017, 09:12 AM   #8
gsrbri
gsrbri's Avatar
560
Drives: F87 6MT
I've had the sensors tied up on my DD M4 for three years. I keep them taped (elec tape) so they don't get dinged-up and throw a warning light. Then track pads are no issue.
      05-04-2017, 08:15 AM   #9
M2joey
M2joey's Avatar
300
New sensor on and tied up with end taped, brake warning reset, all is good.
      05-04-2017, 11:30 AM   #10
MagnusT
MagnusT's Avatar
Sweden
538
Drives: BMW M2
How did you do a reset of the brake warning?
      05-04-2017, 11:41 AM   #11
M2joey
M2joey's Avatar
300
This video shows how, just cycle through until you get to the front or rear brakes.
      05-04-2017, 11:42 AM   #12
MagnusT
MagnusT's Avatar
Sweden
538
Drives: BMW M2
Thanks!
      05-30-2017, 09:17 PM   #13
Twt
Twt's Avatar
634
Drives: 2017 M2
      05-30-2017, 09:24 PM   #14
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Battery disconnected Cut the sensors. Twist both wires together. Done.
m2
