04-26-2017, 01:46 AM | #1 |
26
Rep 159
K2 Karcher
My K2 does not really foam my foam wash even though I have the foam lance. The resulting spray is more suds than thick foam. I dilute the mix, about 25-30ml in the standard 0.6 Ltr foam container....
What am I doing wrong? |
04-26-2017, 01:51 AM | #2 |
29
Rep 100
Have you tried with a more concentrated mix? Also if it's a professional foam lance have you used the adjustment knob on the lance? If it's a standard bottle I suggest buying a professional attachment. Alternatively buy a nilfisk PW which has a metal pump!
04-26-2017, 01:55 AM | #3 | |
General
6733
Rep 20,651
http://www.autobritedirect.co.uk/ind...onnectors.html https://www.amazon.co.uk/Lance-Karch.../dp/B00GU1YYA0 Decent deal on Amazon. |
04-26-2017, 03:15 AM | #5 |
325
Rep 709
The standard foam lance (FJ6) you get with Karchers isn't great as other have said. The FJ10 is much better or get the Autobrite snowfoam lance which is far superior but so is the price.
Your mix is very weak too at around 5% you need to up it to around 20-30%. The density of the snowfoam varies between brands. The Autobrite snowfoam is more watery and I don't find it that effective at removing dirt regardless how warm the water is. I prefer Autofiness Snowfoam in combination with the Autobrite lance makes shaving foam thick snowfoam that clings to the car and removes much more dirt whilst using very little of the mix. |
04-26-2017, 03:36 AM | #6 |
68
Rep 263
Agree with Craig, OP you need a more concentrate solution. I use UF Ultimate Snow Foam and my ratio is 1:5 with warm water. Warm water definitely helps. With the Karcher foam lance you can adjust the water mixture.
04-26-2017, 04:27 AM | #8 |
741
Rep 2,511
My neighbour has the K2 and the Karcher lance. It's a very poor combination, the lance is certainly the weak point.
A mate has the k2 with a similar lance to the one listed above and gets good results. Similar to me with a similar non-Karcher lance and the K4. Basically the Karcher lance is unfortunately poor.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
04-26-2017, 05:49 AM | #10 |
505
Rep 2,152
+1 for autorbrite lance best thing i bought and i have had about 4 lances in total. noting compares
about 2" in bottle then fill up warm water and cake the car
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
04-26-2017, 06:48 AM | #11 | |
344
Rep 834
The little yellow Karcher lance is utter shite! Lots of detailing suppliers selling the HD foam lances so shop around. I use a 10% solution of snow foam in warm water.
BMW X1 sDrive20i ///M Sport MHT
04-26-2017, 06:51 AM | #12 |
97
Rep 155
Been using the AB lance for years with their snow foam.
http://www.autobritedirect.co.uk/ind...oam-500ml.html About 30ml & top up with warm water to 3/4 of the bottle. This gives a nice thick foam that takes the dirt away. |
04-26-2017, 08:31 AM | #15 |
26
Rep 159
Anybody used this product?
https://www.hygienesuppliesdirect.co...FUeZGwodTXUG_Q |
04-26-2017, 08:52 AM | #16 | |
741
Rep 2,511
