F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > What does hitting the B58 fuel limit feel like?
Extreme Powerhouse
      04-23-2017, 11:26 AM   #1
BMWILUVU
809
Drives: 340ix
Using Active-8 at 75%+ throttle, I am seeing some mildly rough driving at or just after the peak of the B58 torque curve as if gears are grinding but no sound. Some people have said that it was caused by the fuel limit. What does hitting the B58 fuel limit feel like please?
      04-23-2017, 06:48 PM   #2
goj
goj's Avatar
2253
Drives: 2016 EBII 340i 6-MT
With just the tune you should not be running into fuel limit issues. This is likely due to the tune's firmware. Make sure you update it if it works that way.
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04
Instagram: @brandons340i
BMWILUVU809.00
      04-23-2017, 08:47 PM   #3
Wires
1646
Drives: 2016 340i xDrive
I get the same thing. If you are shifting gears, it could be the car going into torque management to protect the transmission (getting off the throttle before shifting with the auto will take care of that).
Once under hard acceleration onto the highway, it did that at about 6k rpm, doing 70MPH, it felt like it was bouncing off a rev limiter. I'm assuming fuel cap, but I to would like to know if that's what it feels like.
BMWILUVU809.00
      04-24-2017, 06:56 AM   #4
kern417
Cheapskate
4447
Drives: 2018 440i |2016 340i | 2010 X5
fuel cut feels like a misfire. the car will stutter and shake and you'll hear the pops in the exhaust.
Originally Posted by umizoomi View Post
As long as 3-pedals are an option, I will exercise my right to suffer the handicap and indignity of slower shifts and reaction times.
Youtube/Instagram/TikTok: @kern417
BMWILUVU809.00
      04-24-2017, 08:19 AM   #5
BMWILUVU
809
Drives: 340ix
Makes sense, torque management sounds like the culprit because I am not getting violent shakes nor pops just a rough patch where the transmission gears felt like they were struggling.
      04-25-2017, 10:45 AM   #6
PeterA90
86
Drives: 340xi
It feels like the engine power is being cut off and then abruptly coming back on. Only noticeable in 6k, 6.5k rpm ranger. What's actually happening is the DME lowering boost and retarding timing since there's insufficient fuel
      04-25-2017, 11:11 AM   #7
shawntech
The Wolf
shawntech's Avatar
247
Drives: stuff
  [0.00]
2019 BMW M850i conv ...  [0.00]
mine doesn't cut or feel weird in any way, you just think it feels slow then look at the logs and yeah it's slow cause the dme isn't allowing much boost then the additive of jb4 gets it back to around stock levels.
-2019 BMW m850i convertible
-2021 Dodge Charger Hellcat Redeye Widebody
      04-25-2017, 01:19 PM   #8
PeterA90
86
Drives: 340xi
That's happening when with you? Mods and fuel you are using? Map? I've only noticed it with map 7 and additive over 40.
      04-25-2017, 05:54 PM   #9
BMWILUVU
809
Drives: 340ix
BMW has a torque limiter, fuel limiter, DSC limiting cornering speeds, and what else?
      04-26-2017, 07:07 AM   #10
kern417
Cheapskate
4447
there's also a back button on the idrive
      04-27-2017, 12:42 PM   #11
shawntech
The Wolf
shawntech's Avatar
247
Drives: stuff
  [0.00]
No hardware mods, 93octane, any map under 50f ambient it's very apparent.
f30post
