335d Smog Check - OBD "NOT READY FOR TEST"
04-22-2017, 04:14 PM | #1 |
20
Rep 59
I have a 335D and had to disconnect the battery to remove an accessory. I need to get it smogged, but the ECU is reporting "not ready" on OXY and one other sensor.
Is there some magic bullet to have this "ready"???? Why does BMW have to make EVERYTHING so COMPLICATED???? |
04-23-2017, 12:07 AM | #4 |
BRR tuned
220
Rep 646
It's not really "BMW" all cars go through a check that take a handful of miles to complete.. generally it is a few key cycles in conjunction with a handful of miles driven... Hearing 400 miles sounds like a lot!!!
04-26-2017, 11:59 AM | #6 | |
2125
Rep 3,368
smass397.50 |
04-26-2017, 01:09 PM | #7 |
63
Rep 296
Drives: E90 335d | i3 REx
Carly has a special mode where you can check to see what readiness monitors are left. It's under "OBD Functions".
That's what I used when I went in for a smog check last month. If I recall correctly, for diesels of certain model years (all E90 335d are included), you're allowed up to two monitors "not ready" and it will still be considered a pass. At least that's how it is in California. You can also force a DPF regen through Carly if that would help you get that particular monitor ready and within the passing limit mentioned above more quickly. Additionally, I believe driving at around 55mph for 30 minuets straight could help speed up the process and get all the monitors ready.
2011 E90 335d M Sport | KW V3 | M3 Bits (arms/bushings/sways) | JBD | Apex ARC-8 w/PSS
2015 i3 REx | Solar Orange | Tera World | Tech |
POBEP367.00 |
04-26-2017, 01:31 PM | #8 | |
BRR tuned
220
Rep 646
Yes I'm use to gassers |
04-26-2017, 02:05 PM | #9 | ||
63
Rep 296
YMMV.
04-26-2017, 02:48 PM | #10 |
213
Rep 2,210
My 96 jeep cherokee required 50 key cycles and specific driving sequence to set all the monitors. While I guess you could just start it over and over in the parking lot, realistically it was a month of driving around town. The quickest ive seen a gas car set the monitors is 50 miles, and that was just enough to pass smog but wasnt all the monitors set yet. It takes a while, just gotta give it time.
05-01-2017, 06:45 PM | #11 |
17
Rep 112
I recall you need to drive 100 miles without any issues, then the OBD will report as NO CODES FOUND
'11 335d + BMW Perf Susp + JL600 +Technic Harness + Bavsound Stage One + Injector #3 replaced and other 5 cleaned by diesel shop+Fuel filter and EGR valve replaced
05-01-2017, 10:34 PM | #12 | |
2125
Rep 3,368
http://www.smogtips.com/smog-questio...rs-Are-Allowed NY guidelines https://dmv.ny.gov/brochure/what-do-...cars-not-ready Lastly here is the bmw guidline for reseting readiness on a 335d http://www.bimmerfest.com/forums/att...2&d=1448280718 |
05-09-2017, 12:19 PM | #13 | ||
63
Rep 296
Here is the CA resource: http://asktheref.org/About/MonitorRe...2/Default.aspx
06-14-2017, 06:32 PM | #14 |
ITZ DZL
Rep 19
Drives: '11 335d
I just failed CA smog w/ a pass on emissions but two fault codes in the ERG. Car is at the dealership now for a assessment. They gave me a 17 330i and I miss the torque already.
off-road eligible 335d for sponsored upgrades
06-15-2017, 11:49 AM | #16 |
ITZ DZL
Rep 19
Drives: '11 335d
repairs - $655
"We found that the SCR metering module at the exhaust is not working upon activation. We will need to replace this part. $665.00 installed includes tax. We show to have this part in-stock and we could get done today."
I'll pay it, get it smogged, and fight with BMW USA for repairs.
06-15-2017, 11:53 AM | #17 | |
389
Rep 1,623
You can find those a lot cheaper. Check eBay and it's very easy to R&R.
06-15-2017, 12:14 PM | #18 |
ITZ DZL
Rep 19
Drives: '11 335d
I'm in a cruch as the smog and registeration is due on the 2nd of July.
for reference - BMW part 18307807206 Bosch - $150 w/ ebay being less BMW - $320 w/ ebay being less
06-15-2017, 01:35 PM | #19 |
321
Rep 1,157
