04-22-2017, 11:05 AM | #1 |
1253
Rep 3,688
Drives: 2021 Supra 3.0 (Past: 2015 M23
Jerkiness/stutter right after JB4+DP install
Hi, I just finished installing an N55 JB4 EWG to my rwd 8zf m235i along with a VRSF catless downpipe, after taking the car out for a test drive the car starting jerking after a going WOT, the car basically started jerking on and off and kept throwing Drive Train Malfunction codes so I drove back home, unfortunately I was unable to data log since I can not do WOT pulls.
I then updated the firmware of the Jb4 and went for a ready and saw no issues whatsoever, unfortunately was unable to data log during that ride as the cable wasn't tight enough to the unit. Parked, washed the car and tried to drive again (15mins later) but now the "coughing" is back like crazy. Seems like as soon as I put my car in reverse the car starts acting up like crazy and throwing drive train malfunction codes I tried map 0 and the car still shakes/stutters like hell, soon as I put in reverse it throws an engine malfunction sign PS: had an s55JB4 on my M4 and did not experience any issue like this with that tune I've read that this can happen when running map 2 on 91 octane however I was running Map1. Any help fixing this issue would be appreciated, starting to wonder if the problem could be related to the Downpipe instead of the tune...
04-22-2017, 12:13 PM | #3 |
1253
Rep 3,688
OBD2 diagnostics is saying code P0192 is the culprit for the drivetrain malfunction
04-23-2017, 09:36 PM | #5 |
126
Rep 424
yeah dude. Do this. See if its the cat or the JB. I dont see why a cat would do this if installed right beside throwing a CEL. if the car is fine id call burger. Though it seems like you arent the only one experiencing issues with a JB tune currently if u look at the forums.
Who installed the JB. the first general question is did they install it with the battery disconnected.
2016 BSM M235i: Fully loaded. Dinan Stage II Tune, Dinan CAI, Fabspeed Sport Cat, Fabspeed Muffler Delete. |
04-24-2017, 11:52 AM | #6 | |
1253
Rep 3,688
The whole point of the JB4 was to keep the CEL from the DP from popping up so I will probably send the JB4 to Terry for him to fix the unit and then I should be good. On a side note: I'm not sure how I feel about the Catless DP, it makes the car sound 35% better but the smell of gas when parking is kind of annoying.
04-24-2017, 11:57 AM | #7 |
1253
Rep 3,688
here's the thread on N54tech if anyone is interested http://www.n54tech.com/forums/showthread.php?t=46450
04-24-2017, 07:06 PM | #8 | ||
101
Rep 221
05-03-2017, 05:33 PM | #9 |
Joint Chiefs of Staff
24198
Rep 190,805
Glad you got it figured out OP
It is always helpful to mention any parts that were bought used when posting about issues with the car.
