04-19-2017, 11:15 AM | #1 |
17
Rep 60
Warped brake disks
Hi all,
I've surprisingly got warped brake disks with the car only having done 8,000 miles from new. I can't tell yet if they are front, rear or both as I only heard it today at 5mph - the sound echoing off a wall... Is this type of thing covered by the warranty due to the mileage? Car registered in Sept 2016 and has the M Sport upgraded brake kit. I'm sure I've read threads on this but can't remember the outcomes? Thanks
Scusswold
2016 F30 Mineral Grey, M Sport plus package, Harman Kardon, Professional Nav, High Beam Assist |
04-19-2017, 11:34 AM | #2 |
10995
Rep 32,881
It's extremely unlikely to be warped discs, they are a bit of a myth! Much more likely to be uneven pad deposits:
http://www.mossmotors.com/SiteGraphi...ake_discs.html |
04-19-2017, 11:39 AM | #3 |
283
Rep 797
Are the disks heavily corroded? I had to replace the front disks on my 330d at about 15K miles due to corrosion - the car had been standing a fair bit over the winter months.
Current: 21 G21 330e | Portimao Blue | 791 M | M Sport Pro | Vis/Tech/Comfort Plus packs
Previously: 19 F20 M140i Shadow Edition | EB II || 16 F31 340i | EB II || 13 F31 330d Luxury | MG |
04-19-2017, 12:17 PM | #4 |
17
Rep 60
No corrosion, the disks are still looking like new. They just make a 'swish' sound with each rotation, which you can hear at low speeds. The car hasn't been left standing.
The noise stops when you brake. |
04-19-2017, 12:55 PM | #5 |
344
Rep 834
Any judder through the brake pedal?
Any unusual road noise at or approaching motorway speeds?
BMW X1 sDrive20i ///M Sport MHT
04-19-2017, 01:00 PM | #6 |
6416
Rep 8,499
Are they plain, slotted or drilled ?
Slotted discs tend to make a thrumming noise when brakes are applied. Drilled can make a hollow whistling sound. Unless there's vibration coming through the brake pedal or the suspension it's unlikely that the discs are warped.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
04-19-2017, 01:06 PM | #7 |
17
Rep 60
No pedal tremor at all and no unusual noise apart from the low speed stuff. The disks are the plain BMW factory performance disks. I'll have a closer look hopefully tomorrow.
04-19-2017, 01:07 PM | #8 |
General
8567
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
I'd be astounded if the brake discs were warped!
Quite a few of us have tracked our cars with standard discs and no one has managed to warp a disc despite putting massive heat through them. Groaning, fading, smoking, and grumbling... yes! But not warped discs.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
04-19-2017, 02:13 PM | #10 |
409
Rep 1,162
It's highly likely that it's something fairly innocuous rubbing against either the disk or the wheel. If the car was older it could be a wheel bearing, but again highly unlikely on such a young car.
04-19-2017, 02:30 PM | #11 |
250
Rep 707
I think mine make the same noise.
A metallic sounding gentle rubbing noise when I first pull away. I can only hear it with the windows down and because I go through a sort of tunnel immediately as I leave my parking space. The sound is gone when I go back through the tunnel on the way home even if only a 5 min journey. I haven't been worried about it (should I be?), but curious as to what it might be. |
04-19-2017, 03:46 PM | #12 | |
325
Rep 709
Try and find a quiet stretch of road and do some hard stops. You may need to repeat 5-6 times before it cleans off. You need to get some real heat into the discs to get the pad resin off. |
teaston10994.50 |
