2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning JB4 issues
      04-18-2017, 01:06 AM   #1
tengotengo
Drives: 2016 BMW M235i
Angry JB4 issues
Installed JB4 the other day.
Stage 2 version, on my 2016 M235i with EWG
+ OBD2 cable
first problem is that I can't change maps from the wheel. Holding "Volume_Down" or "BC" buttons does absolutely nothing
then I got the usb cable and I managed to change the map from 1 to 2
I can tell it works, driving experience is different now.
I updated the JB4's firmware to the latest one and it did not resolve the map changing issue.
Second issue is that logging via usb cable doesn't work properly.
it only logs boost and couple of other values. majority of values just stay 0 or never change (as you see on the picture)
any ideas?
does it have something to do with DME version? is it faulty jb4?
http://www.bmwfanatics.co.za/showthr...6#post_1147932
This here is the closest I could find to my problem, but I still don't understand how to fix it.
Please help
      04-18-2017, 02:45 AM   #2
SerenVoX
SerenVoX's Avatar
No_Country
146
Drives: M235i Xdrive
Idk if it would help, but on the REV3 bluetooth connect there is a debug file under settings.. never used it but might be worth a look if you have that via the cable.. in any case if this hapened to my JB4 id head straight to N54 tech support thread assuming you havnt already. Gonna follow to learn more about what's causing this.
http://www.n54tech.com/forums/forumdisplay.php?f=35
      04-18-2017, 08:25 AM   #3
jmwilson125
341
Drives: 2016 M235i
Did you disconnect the battery when you installed?
      04-18-2017, 11:32 AM   #4
tengotengo
Yes
      04-18-2017, 12:32 PM   #5
Realdread1
15
Drives: 16 235i
Obd2 uses can bus. You cannot chnage via the volume. You need to hold down the "bc" on the indicator stock. This will get you into the menu. A series of holds and clicks will get you through the different settings.
Instructions are on burgermotorsports for the correct sequences and what the different tach/speedo locations mean
      04-18-2017, 01:27 PM   #6
tengotengo
A dude with the same car told me to hold Volume Down.
I did try BC button - zero effect
      04-18-2017, 02:37 PM   #7
Anthony235
Anthony235's Avatar
715
Drives: m235i
2015 BMW  [0.00]
And you have the car type, engine, etc setup correctly in the software?
If it's not then it won't log correctly. I use the mobile app so not entirely sure what needs to happen for the laptop logging to work correctly.
Make sure the logging software is updated and the JB4 firmware.
Are you sure that you have the OBDII plugged in on both sides?!?! Even data points that do show up in the example log you're showing is not accurate.
      04-18-2017, 05:18 PM   #8
Drpoomanchu
Drpoomanchu's Avatar
308
Drives: AW M235i Man FBO
Did you possibly ground out the usb cable when connected to JB4.?
You should consider purchasing the rev 3 Bluetooth adapter for easier logging and adjustment.
The bluetooth adaptor is worth its weight in gold if you ask me. It works seamlessly on iOS (cant speak for Android).
      04-21-2017, 02:51 PM   #9
Chris_B
Chris_B's Avatar
110
Drives: Melbourne Red 2016 M235i
2010 BMW 128i  [0.00]
tengotengo
100% Get the bluetooth adaptor.
Told you :P
-@Project_Kristi
Past: 2008 BSM BMW 128i 6sp w/ EU spec interior.
Past: 2010 BSM BMW 128i 6sp +Msport
2016 MR BMW M235i
Instagram @project_kristi
      04-24-2017, 05:36 PM   #10
tengotengo
bluetooth adapter
Can anyone in LA let me borrow the bluetooth adapter? just to see if it works??
Please?
Originally Posted by Chris_B View Post
tengotengo
Told you :P
-@Project_Kristi
      04-25-2017, 12:27 AM   #11
harkes
harkes's Avatar
China
1078
Drives: M135i, E39 M5, NSX and AE86
Go to N54tech.com or keep
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China)
FSociety3812.50
      04-25-2017, 10:52 AM   #12
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
Tags
empty logs, issues, jb4, jb4 logging, problems
2addicts
