04-15-2017, 11:47 PM | #1 |
36
Rep 123
Loud metal on metal noise when turning left
I'll try to make this short. When turning fairly hard to the left the right rear is making a loud noise that sounds like the dust shield hitting the rotor. I had the wheels rebalanced after a track day and did a through inspection while the wheel was off and found nothing. It sounds like a rock is stuck and it is rubbing under lateral load. It started during a track day and it's now driving me crazy. I'm running Pagid pads and now I'm wondering if they are shuddering.
I bent the shield back away from the rotor but no luck. I'm thinking I'll change out the pads and retest since I'm running out of ideas. Feedback? Help? Also, I only hear it if I'm cornering fairly hard. For example, going 35 or 40 mph on a 20 mph corner. |
04-16-2017, 08:30 AM | #2 |
263
Rep 337
Drives: '17 M2 DCT BSM
vide "soda can crunch noise".
Check out my M2 YouTube channel: The HyperCar Collective
04-16-2017, 02:31 PM | #4 |
1622
Rep 3,402
The diff can make some sounds when the clutch engages back there so its possible that is the issue but I would have the dealership take a look at it to be on the safe side.
04-16-2017, 03:07 PM | #5 | |
36
Rep 123
I can't figure out why it only happens when the right side is hard loaded?! It's a clack clack clack not a solid screech. Its loud though. Was out for a drive with my wife last night on a curvy country road and she said "what the hell is that?" |
