04-15-2017, 04:14 PM | #1 |
709
Rep 1,696
330d vs 335d low down shove
Gents,
I'm cautious with this one and without trying to start a war just wondered how much different a 335d feels when you boot it from a start compared with 330d? I know specs are similar low down and I assume the 335d will pull more at higher speeds but wondered how much different they actually feel 0-60? Or 0-100. Also do they both have two turbos? What's the difference with the engines? A thousand thanks |
04-15-2017, 04:21 PM | #2 | |
759
Rep 2,192
I had a 330 before , 335 now, both cars were generally quicker than I'm prepared to go on a public road most of the time. 330 was S drive, handled much better out of the box than my x drive, ACS springs have narrowed gap though. Used to see the traction light on the 330 a bit, never seen it yet on the x drive.
M3 CP in THE fastest colour (says so in the title )
04-16-2017, 06:53 AM | #3 |
952
Rep 1,447
Test drove a 335d before eventually buying a 330d. Both xDrive so no traction issues for either. From 0-30 I'd say there's not a lot in it off the line, from there onwards the 335d is noticeably a quicker car.
Neither had the top end I was used to coming from an M135i and in the end it came down to a good deal on a fully loaded ex-demo that saw me into a 30d. If I could've, I'd have bought a 35d but I'm happy with my lot. Both great Diesel engines. |
04-16-2017, 07:17 AM | #4 |
49
Rep 235
as above very little between them in actual fast "feel" - i had a 330d and upgraded to a 335d last year and to be honest the 330d was a much better drivers car but im sure this will but to due to the springs which will be sorted soon.
You'll only feel the difference above legal speeds in my opinion. |
04-16-2017, 10:24 AM | #5 |
337
Rep 1,660
As far as the E9x is concerned, the 335d is reasonably quick up to 100.
Over 100, it's awesome. I seem to find it "wanting" more low down grunt at sensible overtaking speeds, i.e. 45 to 70 Mike |
04-16-2017, 10:37 AM | #6 |
220
Rep 541
Not driven the 330d, but its my understanding that the two turbos on the 335d are fixed vane and therefore are better for power delivery across the narrower rev range that they operate. The variable vane single turbo of the 330d must operate across the entire range od revs and this reduces its ability to deliver the same amount of airflow. Therefore from start off the 335d smaller turbo will be better at delivering power than the single turbo of the 330d, so the 335d will pick up better with less lag. I thought this was the whole point of the bi-turbo system.
Maybe its not that noticeable when driving them separately as they are both quick, but the two alongside each other then the 335d will pull ahead from the outset, otherwise what's the point? |
04-16-2017, 11:06 AM | #7 | |
709
Rep 1,696
04-16-2017, 11:08 AM | #8 |
101
Rep 196
I ll second that about the 335d. Up to 100 it's quick. After 100 it's manic. Up to about 135ish there's no let up. I'm too chicken after that.
04-16-2017, 11:24 AM | #9 |
337
Rep 1,660
04-16-2017, 11:24 AM | #10 |
110
Rep 331
04-16-2017, 11:45 AM | #11 | |
6659
Rep 15,858
335d N57Z engine has the bi-turbo setup. Smaller turbo is similar to the 330d with a VGT/VNT. Larger 'second' turbo is a fixed vane design. The bi-turbo setup allows for more instant pick up and boost at low rpm, from the smaller turbo, plus a wider boost range at higher rpm and loadings from the large turbo. Result, best of both worlds! |
04-16-2017, 11:54 AM | #12 |
6659
Rep 15,858
I recall the engine debates when the first 35d engines were introduced. The high end urge was where users found the real difference, even with the low end being slightly improved. I remember one user who had driven both engines in Germany, commenting it was 120+mph, where the 535d (in his case) showed how much better the 35d engine was in real world driving performance.
04-16-2017, 12:05 PM | #13 | |
49
Rep 235
Maybe i havent noticed much difference between the 30d and 35d because my 30d was s drive hence less weight? Hoping it may free up a bit over time. |
04-16-2017, 12:17 PM | #14 |
10995
Rep 32,881
I found my 330d "felt" as quick as my 335d low down, probably because of the shove when the single big turbo kicked in.
The figures on the speedo disagree though obviously. |
04-16-2017, 12:23 PM | #15 | |
6659
Rep 15,858
I've driven the 535d and 530d, the 535d has the edge IMO, but is it necessary? Perhaps more a 'nice to have' model. Of course there are those who must have the most powerful model and even then (for some) it needs tuning. For many users a 30d does the job required, without any real compromise. |
04-16-2017, 01:50 PM | #16 | |
49
Rep 235
04-16-2017, 02:07 PM | #17 |
355
Rep 1,846
I've always said I didn't really need a 435d and a 430d would have been fine. A 6 pot diesel is great and very smooth. A remapped 435d is hot hatch beating performance but with much better Mpg and less excitement.
04-16-2017, 02:14 PM | #18 |
3533
Rep 11,292
Those that prefer sdrive can go for a 330d and put the MPPK on it then it's near 335d performance as power to weight is similar.
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
JLR19691882.00 |
04-16-2017, 03:17 PM | #19 |
1882
Rep 7,000
04-16-2017, 03:24 PM | #20 |
823
Rep 1,910
I have the 30D & brother has the 35D, both xDrive. The 35 is much faster after a ton, 40-80 also gets the edge, as for driveability the 30 feels more nippy but compared to the 35 it feels a tad weaker...unless you do long/motorway trips the 30 will be more than enough.
Both great driving machines.
Happy Motoring
Evdok |
04-16-2017, 03:58 PM | #21 |
49
Rep 235
thats why i dont think i'm noticing much power difference with my new 335d, the x drive must add a load of weight as its no where near as nimble as the s drive 30d
04-16-2017, 04:59 PM | #22 |
501
Rep 1,580
How many miles on the 335?
G20 320dx. Every option except a tow bar
'20 Subaru XV 2.0. Gone; F30 335dx, F30 330dx, F21 LCI 125d, F48 X1 20dx, F10 520d |
