04-15-2017, 03:46 AM | #1 |
Rep 3
19 Fault codes
Hello new family. I am a first time owner of a BMW and I went with one of the best cars that I can think of...M5 comp and exe package. Not only that but I got it for a great deal. It currently has 46,000+ miles and I also have until December before the Manufacturing warranty goes out on it. So I'm assuming that I'm doing what any smart person would do and that's to have a good look over of the vehicle and get everything fixed before the manufacturer warranty goes out. So I ran an OBDII scan on it and it came up with 19 codes! Wasn't happy about that so I took it to the dealership and gave them a printed copy of the codes. they suggested that I changed the battery which is still under warranty and the codes will go away. well, drove the car home and basically the same codes are still there. My question for you guys is how does a BMW store codes? In other words... are these codes real faults or just messages? The scan tool that I used is the Snapon Ethos Pro. Is it because I'm using a non-BMW scanner? (I wouldn't think so...) and lastly, from you guys experiences, what other known problems should I get looked at before the warranty runs out?
The codes I have: VEHICLE INFORMATION MAKE BMW YEAR 2014 MODEL 5-Series (F10) ENGINE 4.4L 24V DI (M5) (S63B44B) SYSTEM CODE SCAN RESULTS Systems detected : 19 Engine (DME/DDE) - Codes : 0 Engine Slave (DME/DDE) - Codes : 1 Transmission (EGS) - Codes : 0 Antilock Brakes (ABS/ASC/DSC) - Codes : 20 Airbag (MRS/ASCM) - Codes : 0 Air Conditioning (IHKA/IHKR/IHKS) - Codes : 1 Camera Based Driver Support System (KAFAS) - Codes : 5 Car Information Computer/Radio (CIC/CHAMP/HU) - Codes : 0 Electronic Fuel Pump Control (EKP) - Codes : 0 Electronic Immobilizer (CAS/EWS) - Codes : 8 Footwell Module (FRM) - Codes : 16 Gear Selector Switch (GWS) - Codes : 0 Instrument Panel (KOMBI) - Codes : 15 Junction Box Electronics (JBE) - Codes : 1 Lane Change Warning (SWW) - Codes : 0 Park Distance Control (PDC) - Codes : 2 Parking Brake (EMF) - Codes : 1 Roof Function Centre (FZD) - Codes : 8 Tire Pressure Monitoring (RDC) - Codes : 0 Engine Slave (DME/DDE) 1E4101 Servotronic Taster, Electrical Short To Battery Positive Antilock Brakes (ABS/ASC/DSC) 480AB8 DSC Control Unit Vehicle Start With Vehicle Moving Or Driving Condition Unknown D35A57 ICM Interface (Longitudinal Acceleration Centre Of Gravity ID 0x199) Signal Invalid D35B2C Message (Longitudinal Acceleration Centre Of Gravity ID 0x199) Missing Receiver Dynamic Stability Control (DSC) Transmitter ICM D35542 No message (lateral acceleration, centre of gravity, 55. 0. 2) receiver Dynamic Stability Control (DSC) transmitter ICM D35462 No Message (Request, Difference, Braking Torque, Yaw Moment Distribution, 66. 1. 2) Receiver Dynamic Stability Control (DSC) Transmitter ICM D3541B No Message (Data, Driving Dynamics Sensor, Expanded, 56.0.2) Receiver, Transmitter Integrated Chassis Management (ICM) D35538 No message (roadway inclination, 56. 1. 2) receiver Dynamic Stability Control (DSC) transmitter ICM D354CC No Message (Vehicle Ride Height Filtered ID 0x0E4) Receiver Dynamic Stability Control (DSC) Transmitter ICM D356D4 No message (data, one - lane mode, driving dynamics, 66. 0. 2) receiver Dynamic Stability Control (DSC) transmitter ICM D35598 No Message (Setpoint, Share, Control, Steering, 39. 1. 2), Receiver DSC, Transmitter ICM D35907 No Message (Status ZFM, 39. 0. 2), Receiver DSC, Transmitter ICM D35755 No Message (Specified Parameterization L - Brake/HDC ID 60. 1. 4) Receiver Dynamic Stability Control (DSC) Transmitter ICM D35420 No message (request, braking torque, sum, 60. 1. 4) receiver Dynamic Stability Control (DSC) Transmitter ICM D354B8 No Message (Vehicle Speed, 55. 3. 4) Receiver Dynamic Stability Control (DSC) Transmitter ICM D35528 No Message (Vehicle Mass/Weight ID 0x2E0) Receiver Dynamic Stability Control (DSC) Transmitter ICM D35478 No Message (Vehicle Self-Steering Response, 109. 0. 2) Receiver Dynamic Stability Control (DSC) Transmitter ICM D35B30 No Message (Steering Angle Offset, 108. 0. 2), Receiver DSC, Transmitter ICM D3550A No message (configuration, switch, driving dynamics, 272. 4. 8) receiver Dynamic Stability Control (DSC) transmitter ICM D3561C No message (wheel tolerance balance, 271. 4. 8) receiver Dynamic Stability Control (DSC) transmitter ICM D35452 No Message (Data Drive Train 3 ID 251. 1. 4) Receiver Dynamic Stability Control (DSC) Transmitter Engine ECU Air Conditioning (IHKA/IHKR/IHKS) 801253 Heating And Air Conditioning System: Power Reduced Due To Power Management Camera Based Driver Support System (KAFAS) 800AB9 Under Voltage Detected 800ABB Low Voltage Differential Signaling (LVDS) Communication Fault Between Camera And Control Unit 800ABC Camera Does Not Match Vehicle Type 800AC0 Camera Switched Off Due To Excess Temperature E06C43 Signal (Warning Object Coordination Status, 0x21F) Invalid, Transmitter Dynamic Stability Control (DSC) or Integrated Chassis Management (ICM) Electronic Immobilizer (CAS/EWS) 930700 CAS: Under-voltage 930712 Brake Light Switch: Switch Sticks Or Internal Hardware Fault 930751 Output, Terminal 15: Short Circuit To Positive 93076A Deactivation Of Terminal 15: Upper Startability Limit Reached, But Deactivation Preventer Active 93076B Deactivation Of Terminal 30B: Upper Startability Limit Reached 93076C Deactivation Of Terminal 30B: Upper Startability Limit Reached, But Deactivation Preventer Or Legal Load/Consumer Active D91410 Message (Drive Train 2 Data, 230.0.2) Incorrect, Receiver CAS, Transmitter Engine ECU D91420 ICM CAN-Message of Vehicle Speed: Failure or Invalid Signal Content (V VEH COG, ST V VEH NSS, Alive, Qualifier, CRC) Footwell Module (FRM) 800FC5 Environment Fault In Headlight Driver Module, Left (Over Or Under Voltage, Over Temperature) 800FC4 Environment Fault In Headlight Driver Module, Right (Over Or Under Voltage, Over Temperature) 800FC3 Initialization Fault In Headlight Driver Module, Left 800FC2 Initialization Fault In Headlight Driver Module, Right 800FB9 Outside Mirror, Under Voltage 800E92 Protection Against Battery Exhaustive Discharge Deactivation, Side Lights 800F92 Welcome Light, Repeat Interlock, Active 800FA8 Electrical Steering Column Adjustment Under Voltage E58502 Message (Vehicle Ride Height, 0xe4) Missing, Footwell Module Receiver, Integrated Chassis Management Transmitter E58509 Message (Driving Speed, 0x1A1) Missing, Footwell Module Receiver, Integrated Chassis Management Transmitter E5850A Message (Yaw Rate, 0x19F) Missing, Footwell Module Receiver, Integrated Chassis Management Transmitter E58510 Message (Data, Drive Train 2, 0x3F9) Missing, Footwell Module Receiver, TAC Module / Digital Diesel Electronics Transmitter E58511 No Message (Power Management, 0x3B3) Receiver FRM, Transmitter Engine ECU 800FC8 LIN Bus, Headlight Driver Module (TMS) Left Communication Fault 800FC9 LIN Bus, Headlight Driver Module (TMS) Right Communication Fault 800FF0 Evaluation Electronics, Contact Free Tailgate Opening Under Voltage Or Overvoltage Instrument Panel (KOMBI) E1145C No Message (Display Engine Speed Drive Train 0xF3) Receiver Instrument Cluster Transmitter Engine ECU E11460 No Message (Data Display Transmission Train 0x3FD) Receiver Instrument Cluster Transmitter Transmission E11480 No Message (Alive Counter Safety 0xD7) Receiver Instrument Cluster Transmitter Airbag E11482 Message (Alive Counter Safety 0xD7) Not Current Receiver Instrument Cluster Transmitter Airbag B7F685 Under Voltage E114DB Instrument Panel: Demand Based Service Message, Message From CBS Subscriber (BBV) Missing E114DC Instrument Panel: Demand Based Service Message, Message From CBS Subscriber (BBH) Missing B7F668 System Time Was Reset E12C1C Engine ECU Interface (Display Drive Train Speed 0x3F9) Signal Invalid E12C20 Interface KAFAS (Recognition, Road Signs, 0x287): Signal Invalid E11421 Message Demand Based Service Message From CBS User Has Failed B7F68C Fault In Transmission Position Shift Point Display CAN Message (Detection By Graphics Board) B7F694 Network E11514 No Message (longtitudinal acceleration, centre of gravity) Receiver Instrument Cluster Transmitter Antilock Brakes/Integrated Chassis Management E11515 No Message (Transcerse acceleration, centre of gravity) Receiver Instrument Cluster Transmitter Antilock Brakes/Integrated Chassis Management Junction Box Electronics (JBE) 8020DE Wake Up Line To Intelligent Battery Sensor IBS: PWM Signal Invalid Park Distance Control (PDC) 803281 Top View Unavailable 803282 Rear View Unavailable Parking Brake (EMF) D39B2C No Message (Longitudinal Acceleration, Centre Of Gravity, 0x199, ) , Receiver Parking Brake, Transmitter Integrated Chassis Management Roof Function Centre (FZD) DE9406 Message Missing (Drive Train 2 Data, 0x3F9) Roof Module Receiver, Engine ECU Transmitter DE9412 Message (1A1, Speed Of Vehicle) Failure 801A38 Roof Module Under voltage 801A3A Burglar Alarm, Details In Alarm Memory 030215 Sunroof Module No Normalization 030295 Electrical Sliding Headlining Invalid Characteristic Curve, No Standardisation Available DE8C5E Roof Module, LIN Bus Communication Fault 801A4A Deactivation Irs And Tilt Sensor By Customer Function |
04-15-2017, 09:07 PM | #3 |
Rep 3
So today, I used my scanner to clear out all fault codes and drove the car to run errands and I'm just making it back home. Now that I have a better understanding of how the scanner software work with the car, I noticed that I actually don't have 19 codes, I actually had way more. Anyhow... I believe you are right. these are codes that have been with the car since and they were never cleared. Now that I rescanned the car, it's only pulling up 2 codes of which I can live with.
Tags |
fault codes, obdii |
