04-12-2017, 09:41 AM | #1 |
53
Rep 99
BMW Transmission Issues
I have a 13' N55 6 speed, and recently my second gear has been grinding really bad when you downshift and upshift into it at RPM's higher than 4k. I took it to the dealership and they said I need a new transmission. Luckily I have CPO and it's being covered.
This is my second BMW transmission I have problems with. My previous car was an E60 545i 6 speed as well, and third gear would grind really bad. Is this a common problem on BMW manual transmissions? Anyone else have this problem? |
04-12-2017, 10:26 AM | #3 | |
731
Rep 1,472
http://f30.bimmerpost.com/forums/sho....php?t=1308545 http://f30.bimmerpost.com/forums/sho....php?t=1028795 |
04-12-2017, 10:55 AM | #4 | |
Curmudgeon and Pedant
690
Rep 3,489
Look, clutches wear out. Synchros are clutches; they wear out. Frankly, your driving style or technique probably has something to do with it, too. Do you rev-match? You didn't say, but if you don't you need to learn to do so. Notice that some newer BMWs do it for you (except in Sport mode!) ... |
04-12-2017, 12:50 PM | #5 | |
71
Rep 178
I had the exact same problem when I purchased my F30 335i. The gear would grind every time I went into second, although I had the clutch to the floor, and quite commonly it also happen going into first and third. This was an issue when I test drove the car and so they agreed to replace the transmission (which was under both warranty and CPO anyway). Anyway, seems like it is a relatively common issue, and I don't think it's just with BMW. A friend of mine has a 2015 VW GTI and he also had the same issue. Turns out for him the synchro was bad. It's a similar issue with the manual gearbox. I might be a little off topic here and I'm not sure if it is true, but I hear if you have spacers, or are considering putting them on, those can also cause issues with the x-drive/transmission? Can someone clarify that? I think my car might have spacers (the rear wheels sit flush with the body, rather than being tucked into the wheel wells), but this is only with my summer tires. My winters still sit tucked into the wheel well. If the car does have spacers then I don't want to be back in the shop after CPO expires with the same issue. Last edited by Carbon.F30; 04-12-2017 at 12:55 PM.. Reason: Typo |
04-12-2017, 02:36 PM | #6 |
130
Rep 247
I purchased my 2014 335i 6-speed used with 31k miles. My SA couldn't pull up service records on it, but my parts guy could (don't know why). Parts said that my car had a new transmission installed at 25k miles. I wish I knew why.
I also found that my steering wheel was replaced at 11K miles and replaced again along with horns at 15k miles. I wish I knew why. |
04-12-2017, 03:00 PM | #7 |
53
Rep 99
I noticed is somewhere around 48k miles but it happened so rare I thought it was just me messing up. It didn't start doing everytime until now 10k miles later
04-12-2017, 03:05 PM | #8 | |
53
Rep 99
04-12-2017, 03:06 PM | #9 | |
53
Rep 99
04-12-2017, 03:21 PM | #10 | |
464
Rep 716
Rev-matching and heel-toe is half the fun of driving a manual anyway |
04-12-2017, 10:52 PM | #15 |
130
Rep 247
04-12-2017, 11:16 PM | #16 | |
464
Rep 716
Remember this thread? Why would you want that feature if it's useless? http://f30.bimmerpost.com/forums/sho...4#post21249604 Yes you can get away with not rev matching by letting the clutch out like a granny and making the synchros do it. No that's not the only or best way to do it. If you're good at rev matching you don't even have to think about it Last edited by donkey; 04-12-2017 at 11:23 PM.. |
04-12-2017, 11:31 PM | #17 | |
648
Rep 1,476
Drives: 2022 G01 X3 M40i (Black/Black)
Rev matching is not necessary on modern transmissions. It's like arguing you should rewind your DVD.
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust 2006 E90 330i (Silver) 6MT, Sport |
ae400753.00 |
04-12-2017, 11:31 PM | #18 |
464
Rep 716
04-12-2017, 11:35 PM | #19 | |
648
Rep 1,476
The synchros are a known weakness in the F30 transmission. I drove 3 manuals before my purchase, and 2 of them had bad synchros. Every car I've ever driven has been a manual, and never have the synchros been a problem. p.s. They added rev matching for the SAME reason people learn to do it heel-and-toe...so as not to upset the chassis mid-corner during performance driving (or even casual driving), NOT in order to save wear on synchros.
ae400753.00 |
04-12-2017, 11:43 PM | #20 | |
464
Rep 716
Yes you can use the synchros to downshift by letting the clutch out slower. But a rev match will be faster if done properly and allows you to get back on the gas quicker (since you're not on the clutch). If the synchros are a known weak point for F30's - I would even go as far to say that it MIGHT be possible that using them more would make any potential flaws noticeable sooner. Or any drivetrain shock from an incorrect downshift without rev matching (i.e. the clutch was dumped too soon causing a shock) could mess them up more than a synchro that doesn't have these issues. That last part is just a guess - but there's no denying that rev matching in general can be useful for these cars. |
AudiA4647.50 |
04-12-2017, 11:56 PM | #21 |
648
Rep 1,476
According to BMW you do. BMW will not let the dealer open up the transmission case. If any part is bad, it's a complete transmission swap and the dealer sends the bad transmission back to BMW (presumably for them to study and/or rebuild).
04-13-2017, 01:34 AM | #22 |
690
Rep 3,489
Every MT BMW I've ever had, from the 78 E21 & E12 to my E34 and E46, have had 2nd gear synchros that eventually get stiff. The 1->2 and 2->3 (and back down) gearshifts are the most used shifts. Often, the engine speed differences between them are the most, too. Both contribute to more wear.
ae400753.00 |
