04-12-2017, 05:17 AM | #1 |
23
Rep 76
How to deal with long but not deep scratches?
The other day on a narrow A-road in rural Devon I had to make space for an ambulance that had appeared behind me. Not fully concentrating I drove a little bit too close to the hedgerows on my left and heard the branches from the hedge scraping along the left side of my car. This happened at a speed of maybe 30 mph, probably less. I immediately corrected and hoped it was only the mirror that touched the hedge. Later at home in the bright sun light I could see it was worse, all along the left side visible scratches. The surface of the paint work is not actually broken, and a first attempt with my bare fingers I seem to almost get them off. Almost, not fully.
What is my best route to tackle this? Will I make it worse by trying any polish substance? If advisable, which one? Admittedly, with today's modern two-layer metallic paints I have not used polish anymore for 20 odd years. Should I give it to a bodyshop where they can maybe use machine polishing for a better result? Any advice greatly appreciated. (F34 320i GT, imperial blue metallic, 3 yrs old) |
04-12-2017, 06:10 AM | #2 |
111
Rep 388
If it's not broken the clear/base coat and you can't feel them when you run your nail across any of the scratches then they should polish out. I'd say a polisher would give a better overall finish but doing them by hand should sort it.
Regarding polish, you can pick up some Menzerna or Meguiars Ultimate from Halfords I believe. Again depending on how deep they are you may need a compound first and then polish. If you can get a picture that'd help us advise better. Last edited by asif03; 04-13-2017 at 02:17 AM.. |
04-12-2017, 06:31 AM | #3 |
122
Rep 359
Back in the day I used something called "G3 Compound" an a car, it worked really well, they were a little deeper then what your describing and it made them hardly noticeable!
Might be worth a try! Was expensive back then, might get some myself to test on a little scratch I have! |
04-12-2017, 06:54 AM | #4 | |
2647
Rep 3,664
I still use Farecla G10 finishing compound for small scratches or for blending in stone chips I have touched up. Although I use it on a DAS with medium/fine pads to get a top job. Still good stuff though
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87 |
04-12-2017, 07:12 AM | #5 |
67
Rep 192
You could use a compound to remove the scratch and then a polish to bring back the shine- the compound will haze up the paint a bit. I've used meguiars compound and polish but any would do
04-12-2017, 08:12 AM | #6 |
1388
Rep 2,127
I noticed some vertical lines on my front bumper yesterday. They cleaned off, but left a deep feeling scratch. I dont think its down to the paint, but you can definitely feel it there.
I have no idea what would have caused it as it looked like liquid dribbling down the bumper.
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
04-12-2017, 10:30 AM | #7 | |
10995
Rep 32,881
If you can feel with nail but it doesn't catch then use 2500 or 3000 grit wet & dry paper (wet) then Meguiars ultimate compound If your nail catches it needs respraying. |
04-12-2017, 10:53 AM | #8 |
3788
Rep 5,776
Sounds like an easy fix--use a DA polisher and Meguiers M105. May take several passes and you don't necessarily have to polish it all the way down, just to where it is hardly noticeable and good for you. I do this all the time.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
04-12-2017, 12:51 PM | #9 |
23
Rep 76
Lots of good advice here. Many thanks.
I'd post a photo but the scratches are incredibly difficult to capture on camera, the reflection of everything near the car including myself or the neighbour's house is stronger than the actual scratch. The human eye can however easily see it. The finger nail method seems the thing to do, I did that and my nail just about can NOT feel it. I had to look up what a "DA polisher" is and assume you meant a machine. Not sure I want to go into this myself with a machine, I'm not only a total novice, the device would be used only on this one occasion. I'm after all not a frequent hedge scratcher (I'm more a head scratcher). I'm a bit worried that the recommended compounds are way to aggressive, they are all labelled "for professional use only", hence my earlier question: Will I make it worse? And sandpaper, however fine, really? To me, the total lay-person, this sounds a little over the top, almost dangerous. Happy to listen to further opinions and advice. |
04-12-2017, 01:10 PM | #11 |
344
Rep 834
Farecla "Smart" Scratch Remover is good stuff. It's a fairly coarse abrasive but diminishes so is fairly safe as long as you don't go mad and refines nicely as the abrasive breaks down. On darker coloured paints you would probably need to refine with a finer polish to clear any hazing.
BMW X1 sDrive20i ///M Sport MHT
04-12-2017, 01:16 PM | #12 | |
10995
Rep 32,881
Yosoo 7Pcs 5/6/7" Sponge Polishing Waxing Buffing Pads Kit Set Compound Auto Car Polisher + M14 Drill Adapter Kit (7") https://www.amazon.co.uk/dp/B01GPSWT..._q7M7ybJZ3MW6K |
04-12-2017, 03:33 PM | #13 | |
709
Rep 1,696
04-13-2017, 02:35 AM | #14 |
111
Rep 388
As Teaston said, it definitely sounds like the scratches are on the lighter side so something like Meg's Ultimate will be fine. It's definitely not pro use only so don't worry about doing damage.
Put some on a microfiber and gently polish it in across the panel. You could spray the microfiber with water very slightly to help break the polish down a touch. May be worth doing the whole panel so it cleans the entire thing up instead of just the small areas where the scratches were. It'll come out looking really glossy. If you were local I'd have sorted it for you. |
04-13-2017, 03:49 AM | #15 | |
23
Rep 76
I'll give it a go and report back. Crikey, how on earth do I pronounce "Meguiars" ? |
04-13-2017, 03:57 AM | #16 |
111
Rep 388
04-13-2017, 03:57 AM | #18 | |
2647
Rep 3,664
Current: M4 G82
04-24-2017, 07:02 AM | #19 |
23
Rep 76
It's done, all is fine, not only are the scratches on my car gone, I can even now stop scratching my head. Haze free, problem free. And the winners were:
I learned:
Thanks for all the advice I received, very much appreciated. |
teaston10994.50 |
04-24-2017, 09:26 AM | #20 | |
3105
Rep 7,032
Drives: 335xd Msport +
Was recommended to me on here to cure burnt in bird poop - done whilst I was on holiday.
04-24-2017, 09:59 AM | #21 |
1363
Rep 2,495
Just remember to polish over the top of the Scratch X as it will remove any previous paint protection e.g. wax and polish.
Arrived! 2022 X4M Competition, SPY + Black Merino
Gone: 2019 X3M Competition, Toronto Red, Adelaide Grey. |
04-24-2017, 11:53 AM | #22 | |
23
Rep 76
I did opt against paint protection when I bought the car, in my infinite wisdom I considered a modern clear coated metallic paint sufficiently robust to withstand most normal environmental impacts. I therefore never polished or waxed this now three year old car. Wax may have been applied in any of the car washes it ever had, manual or in a drive through. I wouldn't know. My previous 3 series hat a metallic paint that after 13 years still looked quite good. How important is waxing really? (a certain other person in my house says that waxing is quite painful, what might she mean?) |
