04-11-2017, 03:37 PM | #1 |
286
Rep 506
Car feels unsteady....
Recently changed my run flats to non run flats and put the less than rigid feel down to the softer side walls of the non run flats but recently it feels decidedly unstable, especially when on the motorway..
Any ideas??? Cheers Virge
Incoming BG X3 M40i
04-11-2017, 03:53 PM | #4 |
286
Rep 506
Will get em checked tomorrow, tyre pressures on the car looked right.
Incoming BG X3 M40i
04-11-2017, 04:01 PM | #7 |
13347
Rep 7,484
Camber? Toe? Alignment? Tyre Pressure? Something up with suspension?
When I swapped to non RFT on an old E92 the alignment was way out of whack. One of the control arms was also worn so I replaced both with Meyle HD. The car felt more controlled after that. I think at around 80k miles the suspension was due for an overhaul anyway. I opted for uni royal and the side walls were so soft corners became interesting! What tyres did you put on? Last edited by Soul_Glo; 04-11-2017 at 04:10 PM.. |
04-11-2017, 04:04 PM | #8 |
6422
Rep 8,501
Although it won't have changed as a result of changing tyres, assuming of course that the size and aspect ratios are the same, but it's worth getting a proper 4 wheel alignment done.
My F31 benefitted from a Hunter 4 wheel alignment - it wasn't out by much but has yours ever been checked to factory spec settings ?
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
04-11-2017, 04:20 PM | #9 |
286
Rep 506
I put Falkens on but I can't see this been the problem as the reviews for these were good. The size and loads are correct, what is the correct tyre pressures for 225/40/19 and 255/35/19?
Incoming BG X3 M40i
04-11-2017, 04:46 PM | #10 |
6422
Rep 8,501
Between 2.4-2.6 Bar - it seems to be down to personal preference. I run mine (those sizes; Michelin Pilot Super Sports) at 2.5 Bar all round.
04-11-2017, 04:58 PM | #11 |
3533
Rep 11,292
And check your tyre pressures when the tyres are cold, on your drive before you go anywhere.
Dont drive to a garage and check them, waste of time.
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
04-12-2017, 02:10 AM | #13 |
409
Rep 1,162
Non runflats do certainly feel quite different and if you're very used to how the RFTs behave can feel a little odd at first.
I have found on some sections of the motorway network (Lane 3 of Junction 9-8 of the M25 being a classic example) the car is quite prone to tramlining due to the terrible surface condition. This I've found does feel different depending on whether you have RFT, Non-RFT or a square RFT setup (as I have for Winter atm). The best performer is the square setup incidentally. I think this is likely to get worse as time goes on due to the pathetic level of competant resurfacing going on. |
04-12-2017, 02:21 AM | #14 |
1867
Rep 13,043
Drives: BMW M340I G20
I think this comes back to F3# not being transformed as much as the E9#'s. The f3# tend to be softer in the damping department. So together with softer side walls, it can feel a bit odd.
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
04-12-2017, 02:49 AM | #15 |
547
Rep 1,484
Who fitted them? Get back to them and tear a strip off them. They are responsible, they should know better, they should have put the correct amount of air into your tyres after fitting. No excuses. Dangerous, dangerous, dangerous.
04-12-2017, 03:23 AM | #16 |
75
Rep 282
I believe I had the same feeling a few years back when I replaced the worn out Bridgestone R/F to PZero R/F on the rear of E92 318D. I thought they had replaced the 2 tyres with jelly and didn't feel that stable being pushed round high speed bends (Example M5 - Swindon A417) The tyres were filled to the correct pressure and were fitted in the correct orientation.
I would have thought what I felt would be increased by putting on normal tyres with softer side walls... |
04-12-2017, 03:29 AM | #17 | |
1983
Rep 3,216
So they are being 'reviewed' compared to generally old, worn-out tyres. Of course the reviews are generally good ! The 'poor' reviews are normally down to failures in fitting, supply, or some other cockup, and very little to do with the tyres themselves. As to tyre pressures, you may well find you need slightly higher pressures for non-RFT tyres compared to RFTs. The sidewall flexes a lot more, and needs the additional pressure in the tyre to retain it's shape. |
