04-09-2017, 10:24 PM | #1 |
41
Rep 156
Auto Stop-Start not engaging after coding
I'm not sure if it's because of my coding, but lately weather has warmed up (well above 10C, more like 15-16C), but I still notice ASS not kicking in. In the EfficientDynamics screen, I still see the A icon slashed whenever I come to a complete stop, engine completely warmed up.
The only thing lately I've done lately was coded my car to roll windows up with fob and unlock all the doors after ignition off. I made sure I only coded FDL and everything works. Another thing weird I notice is, when air con is completely off, ED Info seems to say I'm still blowing air con (see image). Last time ASS "stopped" working was after I temporarily stored it for about a month or two. After a bit of driving it started shutting engine again. Just out of curiosity, I also checked engine oil level (it did have a minor leak issue that was fixed), and that's right at max. Car is a 2012 328i with an N20. Hope I didn't break anything? EDIT: I'm also suspecting my 5-year old battery and dashcam setup now. It's set up for 6 hour recording after ignition off, maybe enough to not trigger ASS but not enough to cause a drain message. View post on imgur.com Last edited by ToniCipriani; 04-10-2017 at 09:18 AM.. |
04-15-2017, 08:36 PM | #2 |
200
Rep 536
Drives: 2013 335xi Alpine White
Most likely your battery is the issue. You can get a good battery tender that reconditions the battery. See if that helps
04-17-2017, 10:29 AM | #3 | |
41
Rep 156
PS: are you on OppositeLock? |
04-17-2017, 11:10 AM | #4 | |
200
Rep 536
No, I'm not on OppositeLock. |
04-17-2017, 11:31 AM | #5 | ||
41
Rep 156
Confused you with someone else...sorry. |
04-17-2017, 12:12 PM | #6 |
200
Rep 536
09-25-2017, 03:54 AM | #8 |
No 55mph
1622
Rep 8,476
Good deal that was an EZ fix
But IMHO, nothing could be better than Auto Start Stop not working I only thank the BMW gods that they have it so you can set it to default to OFF every time car is started The ASS acronym is very suitable for this feature
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
09-25-2017, 06:50 AM | #9 | |
41
Rep 156
I just don't like the idea that something that's supposed to work isn't, and it should be up to me to decide. And on that note... it's always default enabled on mine. Only my friend's F82 it remembers the last setting. Maybe I'll do that coding next to change it to last memory... or code it always enabled on my friend. Muhuhahahaha. |
09-26-2017, 11:18 AM | #10 |
200
Rep 536
Evil...but I love it! Even better if you could code heated seats to turn on with startup so he gets an unexpected hot seat all the time...that's really gonna make him loose it!!
01-07-2018, 10:31 PM | #11 |
64
Rep 310
i noticed my Auto stop start stopped working also... i did have it coded to have it disable on start up. but from what i still remember, it still worked if i pressed the button. However i stopped using it, and installed JB4 and recently noticed it stopped working, even with the Auto start stop enabled, not sure if JB4 is the cause.
2008 E90 M3 6-Speed - Sold
2013 F30 335i MSport 6-Speed - Current |
01-08-2018, 09:03 AM | #12 | |
41
Rep 156
https://www.youtube.com/watch?v=9ftrk9cjJgw |
