04-09-2017, 06:17 AM | #1 |
34
Rep 68
Speed Limiter '' LIMIT ''
Dears,
I have been on an open road during this weekend; and wanted to push my LCI_330i to top speed! It was easy for the car to hit the 250 km/h and I've noticed that speed kept going beyond that until it almost hits a flat-out 260 km/h My first question is; I thought that the Spped-Limiter will cut-off the engine to prevent it from going over the LIMIT, Second question; if I coded the limiter to be off and the can go up to higher speeds (as engine RPM was still between 5000-6000) how much speed can the B48 with 252ps reach? and this will need a digital speedo activated of course Thanks
" if everything seems under control; you're just not going Fast enough " ??
04-09-2017, 07:40 AM | #2 |
141
Rep 416
It will only give you an audible warning "chime" or ring when you've reached your preset limit. It won't physically interfere with the engine, brakes, throttle or any other operational aspect of the vehicle.
04-09-2017, 03:32 PM | #3 |
981
Rep 1,560
I think the OP is talking about the factory top speed limit.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
04-09-2017, 03:37 PM | #4 |
2966
Rep 6,001
They really should raise the top speed limiter to be like the B58, it's pretty much the same chassis and can handle the higher speed. I read on the forum that the top speed limiter can only be removed within 10 hours from the time of ECU installation at the factory. I would think it could be removed with a reflash. They actually advertise the higher top speed limiter on the 340i as a feature you should be willing to pay more for lol. Why not just make all f30s the same?
04-09-2017, 04:52 PM | #5 |
1412
Rep 3,211
Most bimmers in the states are limited to 130mph
if you have option 840?(usually w/msport) then its upped to 155mph in Germany they take off the limiter supposedly within 10 hrs you can option off the limiter via coding which to me logically cannot happen unless its done the last day of production on the assembly line.. who gets delivery that early? |
04-09-2017, 04:58 PM | #6 |
8245
Rep 16,085
04-09-2017, 05:03 PM | #7 |
2966
Rep 6,001
My tires are rated for up to 180 Mph because they are pirelli p-zeros, same ones as on the Ferrari 458. However, the door jam indicates at standard tire pressure you should not exceed 100 mph. There is a higher tire pressure recommended for speeds above 100 apparently. Also, if the customer decides to upgrade the tires they should be able to set a higher speed limiter via the i drive. 133 MPH seems like a very low rating for sport sedan tires.
04-09-2017, 07:49 PM | #8 | ||
GasCompressor
333
Rep 564
2022 Porsche 911 Cabriolet Agate Grey/Black PDK 2019 440i M-Sport Smoke Topaz Metallic/Opel (Sold) 2014 335i M-Sport Black/Beige MPPK/MPE (Totaled) 2013 328i Sport xDrive Imperial Blue/Grey (Sold) |
04-10-2017, 11:36 PM | #9 | |
74
Rep 248
I ordered a 340 with x drive and it has the 840 option. If think the zrt option is of they remove the limiter completely. |
04-11-2017, 12:24 PM | #10 |
1061
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
Hmm...thought my window sticker showed speed limiter removed/changed. Regardless, with the flash tune, it's not there anyway .
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
Tags |
330i, b48, lci, top speed |
