04-08-2017, 07:37 PM | #1 |
1610
Rep 3,947
DIY N55 Oil Filter Housing Gasket
It seems like this is a frequently requested procedure so I've decided to compile the attached PDF from ISTAD Rheingold documents for reference purposes.
It includes the following:
05-25-2017, 02:24 PM | #3 |
215
Rep 558
I performed this procedure last two days on my F30. Not for the faint of heart. I used the Bentley manual. Pretty involved operation, due to that one bolt just right underneath the intake manifold. This required loosening the manifold and lifting it 2 inches up so I could remove the bolt. Also required oil drained, and coolant drained, fan shroud removal (another pain in the ass - it doesn't go straight up!). The oil cleanup work was not fun. I had to replace the AC belt too. So word to the wise - when you smell burnt oil; take a look under the hood right away!
Polo088161610.00 |
03-13-2018, 08:35 AM | #4 |
478
Rep 1,467
Just completed this DIY. Its pretty easy but it gets messy. Definitely lost some oil and coolant down onto the belly pan and onto the floor. Cleaned up what I could.
I am wondering if it would be wise to swap out my serpentine belt since some oil did get on it from the swap. I cleaned up what I could but its a tight squeeze. Also, do i need to change out the oil before driving it again in case of contamination during the swap? I don't think any coolant go into the oil or vice versa, but you never know. If a little bit of cross contamination happened would it be detrimental?
2014 EBII 435ix - Stage 2+ Dragy: 0-60 3.61; 60-130 10.18
2020 MG M340ix - Dragy: 0-60 3.48 2018 LBB X4M40i - Stock Dragy: 0-60 4.85 |
03-13-2018, 01:49 PM | #6 |
478
Rep 1,467
picture of belt? I wiped it pretty clean, it wasnt drenched but nonethless it got hit. Ill probably remove the belt since its $30. also going to drain oil before i put many miles on it.
