04-08-2017, 02:35 PM | #1 |
217
Rep 602
Black wheel bolts and Mcgard Locks
I have just ordered some black 12mm Eibach spacers, but need 16 longer wheel bolts and 4 longer Mcgard locks, can anyone please suggest the best place to get these. EBay?
Bolts are M14 x 1.25, need at least 39mm long. Any links would be great, thanks.
Past BMW's: 2017 G30 530d MSport, 2015 F30 330d MSport, 2013 F10 520d MSport, 2009 E60 530d MSport, 2001 E46 330i MSport, 2002 E39 520i MSport
04-08-2017, 04:47 PM | #3 |
217
Rep 602
Thanks mate, the bolts look perfect, but will probably go Mcgard on the locks for extra security...
04-09-2017, 04:53 AM | #4 |
97
Rep 155
The bolts are what I fitted on my car.
As for the lockers, i put these on after having to have nut's welded to my Mcgard bolts due to them being over torqued by the dealer & not being able to remove them from the car. |
04-10-2017, 04:37 AM | #5 |
978
Rep 2,069
Hi there, my spacers are 12mm all round. After lots of searching I found the right ones, these are the ones you need....
http://www.carsecurit.com/en/1199-mc...535072443.html |
04-10-2017, 04:56 PM | #6 | |
217
Rep 602
The bolts are 43mm so should be ok I hope.... Cheers
04-11-2017, 01:31 AM | #7 | |
217
Rep 602
Thanks
04-11-2017, 02:41 AM | #8 |
97
Rep 155
On 12 & 15mm spacers i had 43mm bolts which gave me no problems.
When I changed things are & put only 6mm spacers on the car with the 43mm bolts. This caused an issue with the rear wheels (rubbing from the internal hub - could be handbrake mechanism). Only advice is fit them & drive around the block slowly. If you have any strange noises coming from the wheels you know you have an issue |
04-21-2017, 05:01 PM | #9 |
217
Rep 602
Fitted the Eibach spacers today, 12mm all round and they look great.
Quite chuffed. Next up is a remap or tuning box, starting my research into which one tomorrow...
