04-07-2017, 02:36 AM | #1 |
84
Rep 306
Throttle peddle
Hi all,
So yesterday i noticed when i floor the peddle i thought i was hitting the floor, but its almost like it stops, then i pushed more and it carried on if that makes sense, so its like it sticks or hits a point, then you push it more and it carries on, so its not continuous, i dont really know how to describle it, but is that normal is it is sticking? |
04-07-2017, 02:48 AM | #4 |
6420
Rep 8,500
It forces the box to kick-down. The box will drop a gear or two under increased throttle, but kick-down forces the use if a lower gear again.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
snipnoob86287.50 |
04-07-2017, 06:22 AM | #7 | |
6659
Rep 15,858
A fast kick-down, (fast throttle application), can instigate a 'brutal' block change, even 8th - 2nd gear, in the most aggressive application. |
