04-07-2017, 12:07 AM | #1 |
2966
Rep 6,003
Low Oil 3 Days after oil change F30
So I brought my 340i in for the service on Monday and now it says low oil. I had previously driven 14k miles without low oil occurring. Unlikely that the car would burn a quart of oil in 3 days after not doing so in the last 10 months and the car was technically in service since march so more than a year. Would seem they didn't put enough oil in. I'll bring it in tomorrow to see what the SA says. Anyone have this happen just after oil change? They also had not reset the CBS.
04-07-2017, 03:50 AM | #2 |
2JZ-GTE
3045
Rep 3,996
Did you check your oil level after it was changed?
Did you check your bumpers to see if they were scratched? Sometimes it's a no charge option to scratch one of your bumpers as part of free maintenance. |
04-07-2017, 08:23 AM | #3 |
2966
Rep 6,003
Lol yes I should check oil level and cbs each time. I also had paid maintenance at the same time. We will see if they'll hook me up with a quart of oil to keep in the trunk along with a funnel like others on here. I've never had to do this with my hondas and toyotas ive owned in the past and drive past 100 k miles. I have a Toyota currently with over 100 k miles although there was an oil leak once with that car due to a botched oil change by an incompetent mechanic.
04-07-2017, 08:46 AM | #4 |
245
Rep 2,387
I would think the low oil indication would come up immediately. Check under the car for an oil spot in case there's a leak from the oil sump. Look at the oil filter housing for leaking at the gasket.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
04-07-2017, 08:48 AM | #5 |
1412
Rep 3,211
I cringe alil everytime I need to take a car to the service.. just never know what surprises end up
tturedraider4974.50 |
04-07-2017, 09:20 AM | #6 |
2966
Rep 6,003
There might be a leak onto the underside panel that doesn't leak to the ground
04-07-2017, 09:21 AM | #7 |
2966
Rep 6,003
04-07-2017, 11:21 AM | #8 |
2966
Rep 6,003
So they checked the oil level sensor and it was checking okay, so they didn't put enough oil apparently. So no different than service departments at Honda and Toyota, lol where problems often occur just after being serviced and are not due to a fault with the vehicle.
insanecoder1412.00 |
04-07-2017, 11:54 AM | #9 | |
245
Rep 2,387
insanecoder1412.00 IndotagSwizz524.50 |
04-07-2017, 12:10 PM | #10 |
1061
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
My CBS just told me it's time. Hopefully they make sure it's topped off!
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
04-07-2017, 12:13 PM | #11 |
2966
Rep 6,003
04-07-2017, 12:24 PM | #12 |
2966
Rep 6,003
They should offer to give you the oil/filter/drain plug/filter housing gasket for free if under maintenance contract so you can opt to DIY without having to pay anything. Otherwise it's $80 typically, maybe a little less if you use different oil or purchase from another website. I would still want free wiper blades and cabin air filter/brakes, so they'd have to be able to do those while not also doing oil changes.
04-07-2017, 12:26 PM | #13 |
1061
Rep 3,258
Yup. Where did you take yours? Im going to Pacific/Glendale......
25% 3M Tint| |
04-07-2017, 02:10 PM | #15 | |
536
Rep 2,825
04-07-2017, 03:35 PM | #16 | |
245
Rep 2,387
04-07-2017, 03:37 PM | #17 | ||
2966
Rep 6,003
04-07-2017, 04:23 PM | #18 |
989
Rep 2,200
I've only had one oil change performed by the dealer (CPO 2013 purchased 02/2016, under free maintenance program, oil changed after 1 year / 8k miles). My car thinks the level is OK, so I'll assume it is!
I understand the oil has to be warm for the oil level check to be performed. Perhaps the OP's techs didn't wait for the oil to warm. You would think they'd know how much to add... |
04-07-2017, 04:26 PM | #19 | |
2966
Rep 6,003
04-08-2017, 07:21 AM | #20 |
2966
Rep 6,003
I now have a theory as to what caused the under fill. The vast majority of the cars being serviced that day and probably most days have the N20 which takes 6L of oil vs the B58 which takes 7L. They must be so used to putting 6L of oil they forgot to add the seventh bottle. They got lazy and didn't run the oil level check in I drive as they have to warm up the engine to run it and that takes time and there are a million customers. Probably figured it wasn't necessary since they know how many liters it takes right? Takeaway here is to check the oil level yourself before leaving though you may have to drive around the block first. I guess if you have sufficient oil pressure it won't ruin the engine with 6L even though the engine had to be running to do the test. I'm assuming a low pressure light would be a more dangerous situation and you would know right away.
04-08-2017, 07:45 AM | #21 | ||
2966
Rep 6,003
04-08-2017, 07:48 AM | #22 | |
2966
Rep 6,003
