04-03-2017, 09:50 AM | #1 |
67
Rep 240
MOT Test Tyre Advisory
Hi there,
I wonder if someone could give me some advise please, or point me in the right direction? I had an MOT carried out last month and I got an advisory on both front tyres of :- Front Outer Tyre worn close to the legal limit edges on both (4.1.E.1) The car has done 31K miles and the tester said they are worn dangerously close to the canvas on both tyres. I asked if this might be balance and or tracking and he said he did not think so but had seen it on other BMW's What are your opinions please guys - maybe I should have a hunter alignment? Thanks Andrew https://www.dropbox.com/s/nazm29h899..._0429.JPG?dl=0 Last edited by andrew.webber; 04-03-2017 at 11:02 AM.. |
04-03-2017, 09:57 AM | #2 |
1983
Rep 3,216
My car was starting to be similar on the MOT last May - plenty of tread depth on the rest of the tyre, but the outer shoulder a bit worn - nothing near as bad as yours though, they are really worn out.
My advisory was just put as 'Nearside front tyre low on edges', and 'offside front tyre low on edges'. Mileage was 31k, tyres were original I had an alignment carried out when the replacement tyres were fitted a few days later, and it was all perfectly fine. |
04-03-2017, 10:39 AM | #5 |
10995
Rep 32,881
04-03-2017, 10:42 AM | #6 | |
67
Rep 240
I will probably get a hunter alignment done in any case I think and maybe change the fronts to non run flat ? Thanks Andrew |
04-03-2017, 10:48 AM | #8 |
741
Rep 2,511
Have you been running your tyres at a too low pressure. Runflat edge weight loading could do this.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
04-03-2017, 11:03 AM | #9 |
67
Rep 240
04-03-2017, 11:12 AM | #10 |
849
Rep 1,858
see my thread on the wear on the inside edge of my rear tyres - i got a Hunter alignment after this http://f30.bimmerpost.com/forums/sho...ighlight=check
04-03-2017, 11:21 AM | #11 |
10995
Rep 32,881
04-03-2017, 11:27 AM | #12 |
409
Rep 1,162
It is not unusual to see edge / shoulder wear on runflat tyres. This is simply because of the sidewall stiffness. Although from personal experience Bridgestone tyres do tend to be a little worse than others. If the tyre was doing this prematurely then I would suspect under inflation but 31k isn't too unreasonable to change the fronts.
If sticking to runflats quite a lot of people of here seem to recommend Goodyear Eagle F1s. |
04-03-2017, 11:28 AM | #13 |
General
8567
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
Whilst 31k is ok mileage it's the least I'd expect from a set of fronts on your car, so looking at the wear pattern then something isn't quite right, whether that's the tracking or the pressures.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
04-03-2017, 12:26 PM | #14 | |
602
Rep 2,246
Now the sun seems to be here, I'm making the move to a set on non RF MPSS I picked up a couple of months ago.....can't wait |
04-03-2017, 12:31 PM | #15 | |
36
Rep 87
Beancounter_74601.50 |
04-03-2017, 01:02 PM | #16 |
2472
Rep 4,653
If your tyres are lasting 31k miles then you are clearly not driving hard enough....
Steve Roberts UK
F82 M4 I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/ |
04-03-2017, 01:14 PM | #17 |
67
Rep 240
Just looking at Pirelli run flats - probably not going to go that way now but I replaced the 2 rear tyres last month and paid £130 each via Blackcircles.
The same tyres now £208 each - that seems a flippin big increase in 3 weeks !! Weak Pound as an excuse maybe? |
04-03-2017, 01:30 PM | #20 |
344
Rep 834
Fair enough. Worth getting the front tracking checked and adjusted if necessary. Full Hunter 3D alignment not necessary just to fix the front toe angle but if you do they can compensate for any thrust angle that cannot be dialled out at the rear.
BMW X1 sDrive20i ///M Sport MHT
