03-30-2017, 04:39 AM | #1 |
30
Rep 47
Difference Sport + and stick left S
Apologies, I've had a quick search and can't see anything that tells me what the difference is between running my car in Sport + mode with the gearlever in the normal position, and in Sport + with the gearlever over to the left in M/S mode (left in S).
I expected there to be a change in upshift/downshift behavior (a bit like dynamic in my old S3, which would basically select the lowest gear for the speed .. so you could run around town in 1st and it wouldn't change up until you hit the limiter) I'm not really experiencing much difference. Should there be? Am I just being a nugget? I have an F30 335i with Sports Auto and paddles (2013) |
03-30-2017, 04:42 AM | #2 |
741
Rep 2,511
With the stick left you run higher rpm than sports mode, I think Sport drops one gear and left drops two.
Also, if you paddle with the stick left you have full control. In other modes it won't let you do something stupid with the paddles.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
03-30-2017, 04:45 AM | #3 |
1397
Rep 8,083
If the shifter is to the left it will hold revs and change later but will still be automatic so couldn't drive around in 1st for ever. However, if you switch to 'manual' mode (shifter to the left and then operate one of the paddles) it will then stay in that gear until you change it yourself or it hits the limiter / nearly stalls. Changing to sport+ just makes it a bit more aggressive in either of the auto modes.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
03-30-2017, 05:03 AM | #5 | |
6659
Rep 15,858
For example, I run with chassis checked, so Sport mode does nothing to the gearbox. In that configuration I require Sport+ to engages the Sport mode gearbox settings. If I switch to Sport+, say accelerating from 30mph, the transmission will drop one gear, flick the shifter to M/S, drops another gear. Same happens at higher speeds. Sport+ typically drops one gear, add M/S, drops another gear. |
03-30-2017, 05:18 AM | #6 |
505
Rep 2,152
teaston has a spread sheet showing what they do in different mode and stick positions
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
03-30-2017, 06:34 AM | #9 |
268
Rep 609
Drives: F31 330D xDrive MPPK ACS
What is the story with using the down paddle to drop to the lowest possible gear ie a kind of kickdown? I've seen references to this but don't seem to be able to replicate it, do you have to be in a particular mode?
F31 Mineral Grey 330d Xdrive, ACS, Adaptive, MPPK.
Gone but not forgotten: 1967 Triumph GT6 Mk1 (6 pot 2 litre widowmaker) 1966 Triumph TR4A (4 pot 2.2 litre, huge torque, lovely car) 2004 Audi TT 3.2 DSG Quattro (weak springs & nose heavy) 2006 VW Golf GTI (brilliant on good tyres) |
03-30-2017, 07:18 AM | #11 | |
26
Rep 45
As for the gear stick being in the middle or left, yeah it definitely feels more responsive when the gear leaver is in sport. |
03-30-2017, 07:42 AM | #12 |
680
Rep 2,444
Drives: 2018 630iGT sport
Can't say as I've noticed any delay differences with the paddle TBH.
As mentioned above, it's more gearing related. |
03-30-2017, 05:40 PM | #15 |
310
Rep 1,338
Drives: 2014 F30 320D X-Drive
main thing i find is that it shifts through gears much quicker in sport+ i use it often on joining on to motorways from a round about
Current Ride: 2020 G20 M340i in Metallic Black Sapphire with Individual Full Merino Ivory White and Piano Black Trim Previous Ride1: 2014 F30 M Sport 320D X-Drive Auto, Dakota Beige Leather, M Sport Brakes, Adaptive M Suspension, Paddle Shifters, 19" 403 Alloys, Folding Mirrors, Pro Sat Nav & Harman Kardon Surround Sound. Previous Ride2: 2004 E46 M Sport 320CI Auto, Montana Beige Leather & 18" 135M Alloys.
03-31-2017, 01:39 AM | #16 | |
General
6733
Rep 20,651
It will drop to lowest gear, likely better in a petrol. |
03-31-2017, 02:21 AM | #17 | |
2966
Rep 6,003
03-31-2017, 07:02 AM | #18 | |
310
Rep 1,338
Gonna try tonight |
04-04-2017, 02:41 PM | #19 |
57
Rep 124
Interesting stuff and that is a great table. I did try launch control on a dry country road about a week ago but I got the impression it was just spinning the rear tyres when I was standing still but could have been doing it wrong.
Despite all the modes and being capable of flicking the stick left, I tend to just drive in Comfort where it hits the legal 70 limit even from standstill in probably about 7 seconds. What would be interesting perhaps is - is the 0-60 time and say 30-70 time much different between comfort/sport/sport + and the same with the box to the left, to me more revs can mean less torque on the d engines so probably makes no difference. Anyone done a test?
M340i saloon, mineral grey, comfort plus pack, driver assistant pro pack, HK sound, mineral grey
Also drive BMW Z4 S Drive 23i Auto, Suzuki Jimny JLX+ |
