03-27-2017, 04:37 PM | #1 |
Rep 57
Drives: 2012 Z4 35is
tire air leaking ... can't find the spot..
hi all!
I am struggling with air leaking I replaced rear tires last year December. then a rear tire has been leaking air little by little. so i have to keep a 12V compressor in the trunk to put air when low presser sign on. this is so annoying me... I visited local tire shop 3 times 3 different places but they could not find leaking spot... i change cap valve but still it leaks. below is information i can tell... air leaks much faster if I drive fast... it really depends on how i drive (90mile speed can last about 50~60 mile distance) my wheel is style 295 oem genuine(no wheel crack, damage, leak) with oem rsc(no patch no repair) bubble test can not find leaking spot for the test, i drove at 150 mph then i got completely flat tire (presser gage show 0 bar) only one suspected point is attached http://e89.zpost.com/forums/showthread.php?t=1368342 can you guys advise? |
03-27-2017, 04:44 PM | #2 | |
1610
Rep 3,947
03-27-2017, 04:44 PM | #3 | |
260
Rep 709
Current: 12' E70 X5D | 04' Yamaha Warrior
Past: 13' Audi S6 | 13' E70 X5M | 13' E92 M3 Comp | 14' BMW 335xi GT | 95' E36 M3 | 84' BMW 733i | 06' Porsche Boxster S | 15' Jeep Grand Cherokee | 06' Acura TL | 85' Honda Shadow VT700 | 05’ Yamaha R6 | 12’ Triumph Tiger |
03-27-2017, 04:47 PM | #4 | |
1610
Rep 3,947
03-27-2017, 05:14 PM | #5 |
8245
Rep 16,088
I'd say the bead is literally broken, as in the cable that forms the bead. It's rare, but it happens, usually with summers or winters that get swapped with the seasons.
If he's not a troll he'll eventually find out the hard way that his moniker is anything but accurate. |
