03-27-2017, 04:36 PM | #1 |
40
Rep 160
Negative battery terminal near engine for 440i?
Hello,
Does anyone have a clue about where exactly negative battery terminal is in 440i. I did check owners manual, but didnt give much info. It shows aid-terminals connected in front neae washer fluid but not sure. Last edited by SikhM4CS; 03-27-2017 at 08:58 PM.. |
03-27-2017, 05:19 PM | #3 |
40
Rep 160
03-27-2017, 05:20 PM | #4 |
464
Rep 716
03-27-2017, 05:32 PM | #5 |
772
Rep 1,502
Do you actually need the negative terminal, or just a ground to attach a jumper cable to? If it's the latter, just clamp to a bolt or strut in the engine bay; there's probably a bolt marked for it near the positive terminal.
03-27-2017, 05:40 PM | #6 |
2963
Rep 5,997
There is a positive battery terminal under the hood and a negative post attached to the frame on the left side. You hook up jumper cables to these posts when jumping.
03-27-2017, 08:59 PM | #7 |
40
Rep 160
03-27-2017, 08:59 PM | #8 |
40
Rep 160
03-27-2017, 09:06 PM | #9 |
707
Rep 1,170
Open trunk, on passenger side near rear of car is the battery location. Simply remove any panels or cargo tray like items and you should see the battery. edit: look under the recessed storage compartment
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. |
03-28-2017, 12:30 AM | #10 | |
2963
Rep 5,997
04-28-2020, 10:36 AM | #11 |
Rep 1
Drives: BMW F33 435D XDrive M Sport
on the last picture under the bonnet, or hood, the positive terminal (which you already found) is under the red cap and the negative I believe it the bolt with a brown wire running of it.
04-28-2020, 10:44 AM | #12 |
1599
Rep 3,748
Question is the OP trying to work on the electrical system that the needed to unplug the battery, then he need to go the trunk to disconnect the battery.
If the OP just want to jump the car or charge the battery, he can do that in the post located in the engine bay. We don't know what he (OP) trying to do. |
04-28-2020, 10:55 AM | #13 | |
4488
Rep 10,473
Since he hasn't been on forum since 2018, he probably gave up and sold car |
upsidedownfunnel1996.00 |
04-28-2020, 11:22 AM | #14 | |
1996
Rep 2,499
In case someone lands on this in a search, here is where to access the battery. Remember folks, always disconnect the cable from the negative terminal, not the positive terminal. |
pw0n43.00 |
04-28-2020, 06:03 PM | #16 |
153
Rep 258
To kill power, yes, it's in the trunk. Do Not disconnect the positive terminal first. Always, on any car, disconnect the negative terminal. That way, if your wrench touches metal, you won't cause a short.
Here is your engine bay photo. I highlighted the Positive and Negative terminals for jump starting (NOT for disconnecting power!) Note that if you're ever working on one of these engines and you remove the plastic cover over the Red terminal in the engine, cover it with a cloth while you're working, so that you don't accidentally cause a short. |
04-29-2020, 04:40 AM | #17 | |
417
Rep 919
04-29-2020, 10:51 PM | #18 | ||
153
Rep 258
