Sulfur Smell from Exhaust
03-27-2017, 09:28 AM | #1 |
12
Rep 58
Wife went to leave this am when she started getting a heavy Sulfur smell from her exhaust. Car is an 06' E90 330i, 155K miles. She said it had a rough idle, but I didn't notice it when I went out to investigate. But I guess we can say it did for arguments sake. We always use 93 Octane from the same Shell, which she just filled up a few days ago. No check engine light this am either. Not sure if this is something I can TS myself, or if it needs to go to the shop. Or if I should just run through the tank of gas. I am reading it can be a faulty O2 sensor, but this car has 4 it seems like, so that would be a costly guess, given no codes were thrown (I will try scanning tonight just to be sure, but no CEL came on).
Also reading it can be a fuel pressure regulator. Any ideas on how to approach this guys? I'd like to try to fix myself if it's doable, but it also seems like I am guessing with no codes to go by. Or do I just deal with it for now and see if it goes away? TIA guys! |
03-27-2017, 10:03 AM | #2 |
12
Rep 58
Another thing I wonder if it might be is a bad coil. Plugs aren't too old, maybe 40-50K, but those are good for 100K usually. If I have a bum ignition pack, then that could be running rich, causing the smell, right?
03-27-2017, 10:40 AM | #3 |
Cometh
1090
Rep 1,308
Drives: Boy's Soul
That smell is usually from a faulty ignition coil misfiring. It could be intermittent and only misfires under load. Let us know if there are any codes
03-27-2017, 03:13 PM | #4 |
12
Rep 58
I didn't see any CEL this morning, but I will check again tonight. I have a couple of new coil packs just in case, but ordered 4 more to speed up the TS'ing in case I don't have a code, or there are multiple packs failing. I plan to replace all six, start her up and see what we get.
03-27-2017, 11:30 PM | #5 |
537
Rep 2,825
I would replace the o2 sensor.
the smell is very likely due to an aging or partially clogged cat. there are some methods (lots of repeated redlines) which would probably help clear shit out. |
03-28-2017, 08:22 AM | #6 |
12
Rep 58
WHICH 02 Sensor? It looks like it has 4.
Meanwhile, I went to put my 6 new coil packs in and they were keyed differently UGGGH!! (tab was on the left, mine is in the center), so I couldn't install them. I got them off Amazon so returning them and since I had the old ones out, was able to search with the correct part number and I'll get 6 correct ones ordered today. |
03-28-2017, 10:48 AM | #7 | |
537
Rep 2,825
I would try clearing out the cats tho. at night when the car is warm go onto an empty highway, redline it, slow down, then redline it again like 5 times this should help clear them out and it will run better. |
03-28-2017, 01:55 PM | #8 |
12
Rep 58
That doesn't sound too smart. It was running rough when it started smelling. Just because there isn't a code doesn't mean a coil can't be going out....
Prior to this, had an ongoing issue where the car would go into limp mode if I floored it (not necessarily kick down mode) and throw a CEL, but there wouldn't be any codes. Even my mechanic couldn't find any. Anyways, got some ordered again. I'll swap all 6 out, test, and see if that's it. If I still have the problem, then I know it isn't a coil issue and can return them. |
04-03-2017, 07:52 AM | #9 |
12
Rep 58
OK, so I got my new set of coils in on Friday, installed them and still got the same issue. Running very rough. Don't think the plugs are the issue and they aren't that old. So ended up having her towed to the shop to have them take a look. Should hear back today with a status.
04-03-2017, 12:47 PM | #12 |
2341
Rep 3,541
Check if the pipe is wet inside, touch it then smell it. If it's gasoline then your injector is stuck open.
04-03-2017, 01:14 PM | #13 | |
537
Rep 2,825
I've already explained to you that it is a clogged cat. either replace it, or try saving yourself alot of money by redlining the shit out of it and clear things out.. like several times. |
04-03-2017, 01:40 PM | #14 |
12
Rep 58
I was right!
Problem ended up being a coil(s). Apparently with the new design the electrical connection (wiring harness, not spark plug) isn't as smooth, and I didn't have them all connected correctly. That stinks because I've had the old coils off several times before and never had any problems. At any rate...beats a much more expensive fix...could have been much worse... Thanks for all your help guys! |
04-04-2017, 07:23 AM | #15 | |
2341
Rep 3,541
