03-26-2017, 03:26 PM | #1 |
345
Rep 442
LSD installed, skipping when turning?
A little over a week ago I had the BMW M Performance limited slip diff installed in my 2016 M235i. I haven't yet put the recommended 500 miles on the car since it was installed so I've been taking it easy while driving. Even still I've noticed what feels like skipping in the car when making a turn while accelerating. For example, making a quick right hand start from a stop sign into traffic. If I get on it, even a tiny little bit, I feel some skipping in the car that was not there when the stock diff was installed. I'm not getting any traction control lights or anything flashing on the dash when this happens. I also don't hear anything abnormal.
I'm assuming, maybe incorrectly, that something isn't right. Anyone else with an LSD installed notice the same thing? |
03-26-2017, 03:54 PM | #2 |
583
Rep 1,117
Drives: 2015 BMW M235i
mine was installed right away so I can't compare to driving without but it does sound like the lsd clutch packs are breaking in as intended. I believe the clutch packs also engage under load and angle, not only when you break traction. I am not an expert though. Is it super jerky or noisy? I would probably ride out the break in period moderately and then revisit if it's too much.
03-26-2017, 04:11 PM | #3 |
345
Rep 442
It is jerky yes, that's exactly the issue. I haven't heard any noise from it though. I'll give it a little more time, maybe I need to drive it harder to break the clutches in more?
03-26-2017, 10:27 PM | #6 |
583
Rep 1,117
pretty sure they are delivered with the oe fluid and they bolt right up. Don't drive it too hard, stay within the limits for the first little while (I think break in is 500 or so miles).
03-27-2017, 08:14 AM | #7 | |||
1610
Rep 3,947
I just installed mine last week and wrote a DIY writeup: http://f30.bimmerpost.com/forums/sho...=982938&page=8 I put over 500 miles on it and replaced the original fluid with Castrol Syntrax 75w140. |
03-27-2017, 03:05 PM | #9 |
1610
Rep 3,947
It will 'chatter' a bit. The clutches in the LSD are working. Clutch based LSDs are not completely silent. You shouldn't get too much "skipping".
03-27-2017, 03:14 PM | #10 |
345
Rep 442
I guess I should clarify, I don't hear any sound coming from the diff. I feel what I would describe as skipping from the rear end under acceleration while turning.
03-27-2017, 03:15 PM | #11 |
1610
Rep 3,947
03-27-2017, 03:20 PM | #12 |
345
Rep 442
Just the stock pilot super sports, have about 8800 miles on the car. It almost feels like wheel slip, but I'm not on the gas hard enough for it to be breaking grip. I'd say it happens on anything slightly higher than normal acceleration. Its quite jerky.
03-28-2017, 02:25 AM | #13 |
Luxury at the redline :)
9105
Rep 7,563
I'm glad you mention this; I have noticed the same issue on my 2016 235i with the LSD Installed. After pulling a sharp left turn from my driveway to the main street, the back ends sounds almost like the tires are losing grip but it doesn't feel like it because the car pulls strait ahead, without hesitation.. Weird.. I just assumed it was the LSD clutches scavenging quickly for grip, upon an immediate load. I wouldn't worry too much about it; I've had my car for over a year without any drivetrain issues..
03-28-2017, 07:51 AM | #14 | |
1610
Rep 3,947
03-28-2017, 05:10 PM | #15 |
345
Rep 442
Thanks all for the input. I'm going to keep an eye on it to try to better determine when it happens.
Could it be that the inside tire is actually sliding (being pulled?) horizontally from the power being delivered by the outside wheel? In other words, is it being shoved around the corner and the grip from the PSS tires is causing some skipping of the inside tire? I could get my IS250 to do something similar by accelerating into corners, a little slide, and then back to normal. That car didn't have an LSD though, and certainly didn't have tires with the same grip as the PSS on my BMW. |
03-28-2017, 06:12 PM | #16 |
28
Rep 68
Back when I build my drift car I had to brake in doing figure 8 and it got gradually better. Vary the acceleration and deceleration, it'll get better.
03-30-2017, 06:15 AM | #17 |
1425
Rep 3,395
03-30-2017, 11:24 AM | #18 |
5554
Rep 5,372
^This. Gentle and steady figure 8s. The LSD needs to break in and is why BMW tells you to go easy on it for the first 500 miles. Just like a brand new manual transmission, the LSD needs to a few thousand miles to really set and settled. When new, it can be somewhat mechanical, especially at slow speeds and tight turns.
04-02-2017, 06:10 PM | #20 |
345
Rep 966
i agree with performing the figure 8 turning.
It is the best way to break in the diff, and I would also check the fluid level just to make sure it is filled correctly |
04-26-2017, 01:26 PM | #21 |
Supreme Allied Commander
3845
Rep 54,376
Drives: F80 M3
Sometimes an additional friction modifier is needed to quiet down a clutch type LSD.
05-03-2017, 11:31 PM | #22 |
13
Rep 27
So, for all of you who have the LSD, is it significantly better than without? This is my first BMW without LSD, and it is a bit odd in the way it moves under high acceleration. Much prefer both wheels doing something predictable.
