03-25-2017, 09:20 PM | #1 |
13
Rep 18
ASD Fault after Upgrade
I used ISTA/P to fully program my car and now I'm getting a fault code on my ASD module. I have tried reprogramming this module and am still getting the same fault. I have also tried VO coding the module as well. Is there a bug with the I-Level I'm using on my car?
Fault Code: 8053A5 ASD: Invalid coding data for equalising Car: 2014 F30 328i xDrive ISTA/P Version: 3.61.0.500 I-Level Factory: F020-13-07-506 I-Level Actual (after update): F020-17-03-502 |
03-26-2017, 03:51 AM | #4 |
13
Rep 18
Is it easy to downgrade my ASD to an older version? Do I just download an older version of psdzdata and run through the normal E-Sys programming process?
The hard part is finding an old psdzdata package. |
03-26-2017, 02:05 PM | #5 |
13
Rep 18
I seem to be experiencing something similar to
http://f80.bimmerpost.com/forums/sho....php?t=1193651 |
03-27-2017, 07:45 AM | #7 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
Check the coding/diy section in this forum for more results...
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
03-27-2017, 08:12 AM | #8 |
Rep 7
12-20-2017, 03:45 PM | #11 |
M-OCD
17
Rep 38
I downgraded my ASD on my F22 to psdzdata 54.2 because iwant to play with changing asd to m3/m4. But i still can’t change it, when i do and set engine to s55 and model to f80 ASD turns off and throws the invalid coding for equalising error . Any ideas?
12-21-2017, 07:01 PM | #12 |
18770
Rep 14,121
Drives: G82 M4C X-Drive
The F80 ASD is extremely annoying, I wouldn't even bother.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
04-25-2018, 09:42 AM | #13 |
2466
Rep 5,457
Drives: F30
I have this same recurring fault/error...
Any ideas how I can remove it? The only coding that I have done is with Bimmercode. |
