03-24-2017, 09:03 AM | #1 |
157
Rep 597
Just did trans fluid change, FMIC, CP, Intake install..
Posted a thread in DIY section about my experience, happy to answer any questions there if you're about to do any of these yourself:
http://f30.bimmerpost.com/forums/sho....php?t=1367228 -tgm |
03-30-2017, 03:16 PM | #2 |
214
Rep 456
Thanks for the post...I just turned 30K on my 335 and may opt to perform a transmission service @ 35K. I may ping you on directions on using ISTA as I also have the program but don't know how to use it.
03-30-2017, 06:10 PM | #3 |
157
Rep 597
Nothing to it, tbh. Don't really need to dig through ISTA, just check out the DIY thread that has the torque specs and the bolt pattern. Really is as simple as make sure you can access fill plug -> drain -> remove pan -> bolt up new pan -> follow torque instructions -> fill -> start car and go through P-R-M1-M2 10 sec each while continuing to fill -> torque fill plug.
It took literally an hour and a half, tops. -tgm |
03-31-2017, 10:32 AM | #4 | |
157
Rep 597
-tgm |
03-31-2017, 10:36 AM | #5 | |
214
Rep 456
03-31-2017, 10:52 AM | #6 | |
3788
Rep 5,776
ISTA is really easy and if you have it and the cable hook it up and try it. You can check for codes and see info about your car.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
03-31-2017, 09:52 PM | #8 | ||
203
Rep 943
Drives: 2012 328i Modern Line
:wave:
03-31-2017, 10:19 PM | #9 | |
1610
Rep 3,947
I set my ISTAD, ISTAP, ETK, and KSD within a Oracle VirtualBox virtual machine. The VM takes up about 260gb but could expand to 500gb. See: http://f30.bimmerpost.com/forums/sho....php?t=1339348 |
03-31-2017, 10:44 PM | #10 | ||
3788
Rep 5,776
http://f30.bimmerpost.com/forums/sho....php?t=1312102
04-01-2017, 08:24 AM | #11 | |
1610
Rep 3,947
It's far easier if you just set up a VM dedicated for ISTA. Also, you're never really sure about the source of such software and therefore not sure if it contains malware. Given that, it's safer to set it up in a VM so it doesn't affect your host machine directly. |
