03-23-2017, 11:59 AM | #1 |
Rep 1
2016 F30 335D XDrive 20" Wheel Offset Question
Hello,
This is my first post on here. I have had a search through the forums and can't get a definite answer to my question so thought Id post to see if you guys couldn't help. I am looking to put on 20" wheels with 20x9" rims, 245/35/20 front tyres and 20x10.5" 275/30/20 rear tyres. My car is a 2016 335D XDrive. What offset of wheel would you recommend for this size of wheel and tyre on my car? I have AC Schnitzer lowering springs. Thanks, Stephen |
03-23-2017, 06:44 PM | #2 |
10995
Rep 32,881
Compared to the oem 19's an ET36 offset on front with these wheels will poke out 12.7mm more and an ET57 offset will poke these rear wheels out by 15.4mm.
This is about what most of us get with spacers on oem wheels, so perfect on the outside. However, on the inside the fronts will be 12.7mm closer to the suspension strut, and the rears 35.4mm closer. So you really want to check there's enough clearance on the inside. P.S. Come and check out the UK forum: http://f30.bimmerpost.com/forums/forumdisplay.php?f=412 |
03-24-2017, 02:02 PM | #3 | |
311
Rep 3,572
Hey Stephen - the tire size you mentioned will work! The offsets for the wheels woudl be 32 Front and 40 Rear to have a nice flush look to it. Hope this helps!! Jose |
03-24-2017, 04:43 PM | #4 |
10995
Rep 32,881
No way, with the 10.5" rears they'll poke out 32.4mm more than oem M Sport wheels! It would look like a roller skate!
