03-16-2017, 12:56 PM | #1 |
22
Rep 59
B58 Versus M3 Engine?
I was wondering if someone could tell me the real differences between the M3's engine and the B58?
Is it just a tune and a larger turbocharger? They both have the same 3.0L no? I just want to know because I plan on getting the Dinan +MPPK over the next year or two and wondering if this is well within the engines range of power or if my engine/transmission is going to poop out on me 100,000 miles in because of this. Thanks! |
03-16-2017, 01:14 PM | #2 |
1410
Rep 3,211
S55 has 2 turbos
Bottom line short of it is the S55 going to have higher rated internal parts & surrounding systems to better cope with the heat and pressures involved with more HP & torque. Many of B58/340's internals also have high ratings but not all & its the weaker point in the chain which fails eventually the system.. the M3 got a stronger chain overall built for it. Cant expect to overstress the system and not have the reliability not take a hit longterm |
03-16-2017, 01:32 PM | #4 |
53
Rep 182
They are totally different engines and blocks. B58 has a closed deck design and I believe the s55 has an open deck design. I also believe the s55 is derived from the n55, but obviously with many upgrades such as cooling, 2 turbos, chains, belts, internals, etc.
My belief is that BMW is trying to use up the last of their inventory that was made for the n55/s55 engines and in the future will move forward with the b58 design in a large portion of their performance engines and M lines. But obviously with many other changes and upgrades, just based on the B-line engines. Could be wrong, just my opinion. I'm no expert by any means, so don't quote me on any of this.
2016 340i - 6MT // M-Sport // JB4 // BMS Intake // AFE catback
03-16-2017, 01:35 PM | #5 |
2564
Rep 1,710
03-16-2017, 01:36 PM | #6 |
420
Rep 841
M3 is built off the old 6 cylinder block, as above, the 340 motor is a different architecture.
BMW is famous for easing in a new motor while still using the old ones, again as above. . Heck, the 4 series didn't get the 340 motor right off. |
03-16-2017, 01:48 PM | #7 |
1410
Rep 3,211
its off the N55 but they filled it in and now its closed deck.
I believe its also air-water intercooler and many of the features are similar to the B58's but its got higher rated parts for sure.. to upgrade all the parts to match the M3 (if it can even be done and tuned properly together) would prob take more time and $$$ than it takes to just buy an M3.. beyond straight-line power M3 handles like a sportscar what not enuf power for ya? for now I find stock torque more than adequate for dd in sport mode |
03-16-2017, 02:41 PM | #8 | |
22
Rep 59
03-16-2017, 04:20 PM | #9 | |
54
Rep 80
03-16-2017, 04:33 PM | #10 |
22
Rep 59
03-16-2017, 06:08 PM | #11 |
1410
Rep 3,211
If you are getting the Dinan Elite and the MPPSK then you are under warranty either by BMW or Dinan for your entire new car factory warranty.. whats to worry about?
If you are worried about stressing out your rated parts then dont slap any tunes on.. |
03-16-2017, 07:11 PM | #12 |
Eric_Y
103
Rep 456
Drives: 2016 340i, 2010 E92 M3
Please correct me if I'm wrong. s55 is closed deck design, although N55 is open deck
Jaymax85711.00 krnnerdboy190.00 |
03-16-2017, 07:16 PM | #13 |
22
Rep 59
I'm not worried about warranty. I want my car to last 150,000+ miles since I bought it new (not leased/purchased used), therefore I would like to "tune responsibly" you could say. E.g. maybe I could upgrade X part in addition to to the tune etc...
03-16-2017, 08:04 PM | #14 |
105
Rep 259
Drives: 16' AW 340i xDrive
As someone mentioned before the M3 has stronger engine internals to handle the power and make a reliable engine. I'm not sure what is available out there for the b58 and how much is required, tearing into the engine is a costly thing. The b58 is new, i doubt anyone really has the answer to how much power you can actually squeeze out of it reliably and for how long.
03-16-2017, 08:11 PM | #15 |
1410
Rep 3,211
Then I would say stay stock or go with MPPSK as a mild tune take care of maintenance religiously.. 6,000mi oil changes .. tranny oil change every 50,000mi .. change diff oil into schedule as well
I mean its no surprise MPPSK torque of 369 ftlb on the auto stays within torque ratings of say the ZF 8HP50 rated at 369 ftlb.. its purposely staying within rated #s |
03-16-2017, 08:23 PM | #16 | |
BimmerPost Supporting Vendor
4912
Rep 115,980
I am also sure there are much more internal differences / tolerances in terms of design and strength of components. Mike |
03-16-2017, 09:08 PM | #17 | |
1646
Rep 4,876
Their non-linear boost curve is a blast to drive. You get into the throttle at that range, and then it exponentially accelerates. |
03-16-2017, 09:55 PM | #19 | |
22
Rep 59
Maybe 80,000 miles down the line or so I will slap on some extra juice... Thanks for all of your responses!! |
03-16-2017, 11:49 PM | #20 | |
252
Rep 674
krnnerdboy190.00 |
03-17-2017, 12:12 AM | #21 | ||
53
Rep 182
So Mr. Expert. Please respond with your expert information to follow your comment rather than leave your reply at that. Are you part of the solution or part of the problem?
03-17-2017, 12:24 AM | #22 | |
252
Rep 674
krnnerdboy190.00 |
