03-16-2017, 11:53 AM | #1 |
56
Rep 171
Drives: X3 M Comp
Low Washer Fluid continually On
I've been fighting with this damn warning light forever. I had months ago mistakenly used some of the orange rain x washer fluid to refill my empty resistor, but after reading the boards found it to cause problems and emptied it and got regular plane Jane blue fluid. Filled the reservoir with water / fluid combo and I was left unbothered by a warning light and tone.
Well my resistor emptied again, and I used same 1/2 water 1/2 blue fluid to refill it and the freaking light and warning won't go away. I have tried more water to dilute it, more fluid than water, it has been I the 20's and I found the whole reservoir frozen yesterday, telling me there wasn't enough washer fluid to keep it from freezing. What's the or recreational mix? Is it the fluid? My understanding is there's a resistor in the resivoir that runs a current to determine if it's empty or not. Why the rain X fluids don't work because they don't conduct the current enough. That's what I read somewhere, I could be completely wrong. Is the sensor hard to replace? Can it be programed out? The headlight washers will not spray with the warning light on. This is annoying the crap out of me. Any help is appreciated. -NVE |
03-16-2017, 01:51 PM | #4 |
536
Rep 2,825
this happened to me before, it is a well known problem. I sort of just forgot about it and it went away. I got the light again recently, topped up and the warning went away again.
I think if you use up all the fluid until it empty and top up again, it may go away. good luck |
HFW0035696.50 |
03-16-2017, 08:55 PM | #6 |
1646
Rep 4,877
Not sure why you are diluting washer mix at 50%. You should be using it straight out of the bottle to ensure that it doesn't freeze.
It's possible that when the tank froze, whatever senses the level in the tank was damaged as well. |
03-17-2017, 10:47 AM | #7 |
536
Rep 2,825
you live in calgary so that is understandable, but I think if you live in a more mild climate 50/50 mix would never freeze.
03-23-2017, 04:00 PM | #10 |
56
Rep 171
Drives: X3 M Comp
Thanks for the replies. The only reason I diluted it was because I read on this forum as a fix for the problem. It seems to happen at lower temperatures, and the 20 degree day was out of the blue that even shocked the weather men. Is the reservoir easy to get to / is the sensor easy to get to and clean? I have tried emptying the thing all the way and using different fluids. If it's not difficult to remove / replace I would do it if anyone can point me in the right direction. Thanks.
-NVE |
02-16-2023, 10:27 PM | #11 |
Rep 5
Same problem on my 2013 f30 328. Used rain x and it gummed up the sensor. I was able to get to the sensor on the bottle by just turning my wheel and getting to it. Behind front right wheel. Just tied the two contacts on the sensor together so it will never read low again. Not worth the $500 to replace the bottle/sensor at dealer. I’ll just fill it when it runs out
02-17-2023, 08:04 AM | #12 |
8245
Rep 16,088
