02-26-2017, 10:08 PM | #1 |
42
Rep 111
F2X stealth meth tank?
Does anyone know whether there is a stealth meth tank for F2x user?
I am using a 1G BMS tank and that looks dangerous and really mess. I know BMS are providing F3X/F8X stealth tank but they have a really large space under the hood. Advan performance has E9X's one. BTW I can design one since I learn'd lots of solidwork but have no idea how to product. |
02-27-2017, 07:15 AM | #2 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
Last I heard they decided to work on one for F10 instead of F22 due to lack of space
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
02-27-2017, 09:38 AM | #4 |
1330
Rep 2,214
I've always used my washer fluid reservoir. Tap into it and you can use the straight cheapo blue washer fluid, which is basically a 50/50 water/meth mix. I also went this route on past vehicles because I get the factory "low fluid" warning through the MDI, as opposed to an auxilary light/sensor. It also keeps the routing up in the front of the car. So many ways this could work, it's really up to you.
02-27-2017, 07:23 PM | #5 |
1631
Rep 1,422
The washer fluid is much less than 50% unless you get the extreme cold (-50F) fluid - usually purple. Plus, I was advised that washer fluid usually contains additives that cause deposits to form.
Just spring for Boost juice or VP Racing M1. |
02-27-2017, 07:53 PM | #6 | |
197
Rep 258
"Windshield Washer fluid: Only if it is blue in color and rated for -20 deg F. It should have no special additives. This means it is safe to use and made of about 30% methanol, 70% water. If it is another color or another temperature rating, do not use it. You can “spike” your Blue -20 Washer fluid to a 50% mixture by adding 3 12OZ yellow bottles of Heet® gas-line-antifreeze to every gallon of washer fluid." I also agree with using the stock windshield washer tank. First for the stealth of it and second for the low level warning. Anyone know how much fluid the stock tank holds? I'm using Snow Performance Boost Juice in my E46 setup; its 49% methanol, 51% water... |
02-28-2017, 12:03 AM | #7 |
42
Rep 111
I've read some washer fluid reservoir use as meth tank fail. Pump place would be hard to balance seems.
Checked under space, seems too small for a pump+tank |
02-28-2017, 07:08 PM | #8 | ||
1330
Rep 2,214
Many people have been skeptical of the washer juice including myself, but once I tried it on my BT A4, I never tried it any other way because the results were spot on.
03-03-2017, 01:49 PM | #9 |
841
Rep 2,363
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
Unfortunately I don't think the M235is have he room for it like the f30 does under the trunk. I like the idea of the washer fluid tank though. Very interesting
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
03-08-2017, 11:37 AM | #10 |
341
Rep 1,184
Is there any way the pump could just be located in a different spot with a line running too the washer fluid tank? Are there any cons to using wash fluid tank? If you remove the meth kit do you have a hole to plug?
03-10-2017, 04:14 PM | #11 | |
1330
Rep 2,214
I haven't even began to look at the m235's tank configuration because I'm not at the point, yet. By summer time, I'll have a kit and a game plan for mine, and will share my experience with you guys. D
Taunto281.50 |
04-04-2018, 01:48 PM | #12 |
1330
Rep 2,214
In case anyone was wondering, this is what I ended up with, working great!
Once the fender liner is out you have easy access to the single bolt holding the tank in: Drilled a hole which was a c-hair smaller than the tubing to allow for a tight fit: Pump lives under my intake, bolted to the fender liner, worked out better than I thought
04-05-2018, 10:58 PM | #13 |
105
Rep 225
Not many options on where to put the tank. I removed the trunk tray on the right side and built a structure to hold the 1 gal BMS tank.
16 M235 Cabrio - BM3, ER CP, Wagner DP & IC, Dinan Intake, MPE, Torqbyte CM5
18 340i F30 mostly stock |
Dylan861330.00 |
04-06-2018, 11:37 AM | #14 |
1330
Rep 2,214
Yea, that was my thought as well. Then decided since I'm using the washer juice anyway, might as well double it up as my meth tank. Also retains the factory "low washer level" alarm, which is nice to have. Keeps everything up front, too..
04-06-2018, 01:25 PM | #15 | |
341
Rep 1,184
I keep a bottle of quick detailer, glass cleaner, a couple bottles of heet and a microfiber towel tucked in there. With all that stuff you don't even see the tank. |
04-06-2018, 01:30 PM | #16 | |
341
Rep 1,184
I keep a bottle of quick detailer, glass cleaner, a couple bottles of heet and a microfiber towel tucked in there. With all that stuff you don't even see the tank. Also don't mind my hideous paint job. I'll fix that at some point. |
04-06-2018, 11:03 PM | #17 |
105
Rep 225
I did seriously think about that, as the alarm is a big nice to have. One issue that sucks in SoCal is that we have no -35 WW fluid. Anywhere. Everything is 32, which is basically water. So I'm stuck with getting Boost Juice $10 a gallon at Amazon or the hassle of driving a ways to get M1 at close to the same price.
04-08-2018, 11:16 AM | #18 | |
341
Rep 1,184
