2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Auto start/stop question
      02-26-2017, 02:01 PM   #1
bcjbmwm3
bcjbmwm3's Avatar
340
Drives: 2020 BMW M340i xDrive
So lately my auto start stop on my m235i has not been working. It normally works in comfort and eco pro, but it hasn't been. I'm wondering if the fact it's been cold we're I am lately has anything to do with it. Does anyone have any ideas, or should I just take it into the dealer.
Thanks
Current - 2020 G20 M340i Mineral White/Cognac
Past - 2016 F22 M235i Dinan S3, 2009 E92 M3, 2010 Nissan 370Z, 2004 E46 330i, 2003 E46 325i, 1999 E46 323i
      02-26-2017, 02:32 PM   #2
BMWZ4
BMWZ4's Avatar
1910
Drives: '23 X1/'23 Allroad Progressiv
Thanks
I was told once it had something to do with temp.
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
      02-26-2017, 02:39 PM   #3
big_fooot
Drives: 2016 235
Yeah it's just the cold.
      02-26-2017, 03:12 PM   #4
wntrsnowg
106
Drives: 2016 M235i
If you look in the owners manual (in iDrive or the physical manual) there are a ton of situations where the car won't auto start/stop. Engine could be too hot or too cold, too cold or hot outside, stop/go traffic, seat belts aren't fastened, etc.
      02-26-2017, 04:17 PM   #5
bcjbmwm3
bcjbmwm3's Avatar
340
Ah, figured that. Thanks for the replies.
      02-27-2017, 01:16 PM   #6
dphjr
139
Drives: Alpine White M235i
It definitely is temperature related. In my area, the temps can fluctuate quite a bit (Friday it was 73F, yesterday it got down to around 30F). If the temperature is too cold or if the engine hasn't warmed up enough, it will temporarily disable auto start/stop. Perfectly normal.
2015 ///M235i | Alpine White | 8AT | RW Carbon Front & Rear Lips | Autotecknic Paddles | MP Side Decals | AWE Axelback | Shifteck DP | MHD Stage 2+ | BMS Intake | FTP Charge Pipe | VRSF FMIC
      03-25-2017, 08:22 PM   #7
Oyinko
40
Drives: M235i
Having the same issue but it's not related to the cold as it's always between 50 and 75 here in San Francisco.
Wondering if it is related to a low battery? I haven't been driving much recently and I know that the auto start stop will not activate if a battery is low.
However, even after a 2 hour drive today on the freeway and city, my auto start stop was still not working.
When I activate the secret menu, the voltage of the battery reads 12v (when the engine is off). Is that good enough for the auto-start to work?
      03-25-2017, 08:26 PM   #8
bcjbmwm3
bcjbmwm3's Avatar
340
My issue was definitely the cold, when it warmed up here, it started to work again. As for your issue, It could be the battery, but i'm not sure. I would just take it in if its still under warranty.
      03-28-2017, 11:07 AM   #9
Fabspeed Motorsport
Fabspeed Motorsport's Avatar
1006
Drives: BMW M235i
There is a large list of criteria the car needs to meet before the Auto Start/Stop will activate. The temperature is one of them - on both ends of the spectrum. If it is above 95 degrees F or below 37.5 degrees F, it will not shut off. Below is a list I found from an old thread of other criteria that needs to be met:
The car is coasting (manual transmission)
Brake vacuum reading is too low (manual transmission)
Insufficient brake pedal pressure is being applied to hold the vehicle stationary (automatic transmission)
Stopping on a hill/downhill with a 12% or greater gradient
If the steering angle is more then 6 degrees
If the steering wheel is still be moved after approximately one second of coming to a stop
The system has not yet be activated by going over a speed of 5mph for automatics, 3mph for manuals since the last engine switch off
If the gas pedal is being pressed (engine must be at idle speed only)
You're coming to a stop from reverse
The driver gets out of the car
If Hill Decent Control (HDC) is activated
If the engine is not up to temperature
If the carbon canister is being purged
if the grade of the fuel is too low for the engine
Transmission adaptation is active (automatic transmission)
The hydraulic pressure accumulator is not yet up to pressure (automatic transmission)
Stop-and-go traffic - system is only activated by driving over 5mph for automatics, 3mph for manuals
Batter charge is low
Outside temperature is colder then 37.4 F / 3 C
Outside temperature above 95 F / 35 C and the air conditioning system is on
Fogging of the windshield is detected by the IHKA system
Climate control system is on but passenger compartment has not yet reached desired temperature
ABS system was used when coming to a stop
via @Ron Scott --> http://f30.bimmerpost.com/forums/sho...d.php?t=663713
2addicts
