M2 Technical Topics > Track / Autocross / Dragstrip > DSC Question
      02-14-2017, 09:58 AM   #1
rich8102
37
Drives: 2017 LBB M2
DSC Question
When I completely turn dsc off the throttle response seems to go into sport or comfort. When I put it back in sport plus the dsc goes back into mdm mode.
Is there a way to keep sport plus throttle response while having the dsc completely off?
      02-14-2017, 11:48 AM   #2
SupraSaiyan
SupraSaiyan's Avatar
45
Drives: 2008 M3 6MT Stripper AW/Black
Sorry to burst your bubble, but the answer is no, you can't keep it in sport plus throttle response with DSC completely off.
      02-14-2017, 12:30 PM   #3
CommitConfirm
475
Drives: The Bus
Apparently Sport+ is MDM mode but without the exhaust burbles.
Transition mode is MDM with sport throttle response and exhaust burble.
I have not found a way to have both. I guess we needed to buy an M4 for M1 & M2 customisation
      02-14-2017, 02:44 PM   #4
rich8102
37
Drives: 2017 LBB M2
Oh well!!! Not the end of the world. I was practicing launches in sport plus and the stability control was very intrusive(manual transmission).
Had an M4 previously. Not my cup of tea.
Thanks for the replies
      02-14-2017, 03:25 PM   #5
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
Are you guys sure? I thought you could go to sport + first and then hold down the DSC button to completely turn it off but keep the throttle mapping in sport +?
      02-14-2017, 03:35 PM   #6
rich8102
37
Drives: 2017 LBB M2
Yes unfortunately. The way I noticed it was, while I was driving in sport plus at a constant speed I would press the DSC button to completely turn off traction control. You will feel the car de-tune like you were taking the car out of sport plus and putting it back into sport or comfort while the DSC remains off. Kind of stinks.
      02-14-2017, 03:39 PM   #7
CommitConfirm
475
Drives: The Bus
Short press of the traction button enables MDM but some traction control is still on. To be honest even in 'traction' mode the nannies are still too intrusive for my taste.
Long press will completely disable traction control. But the M2 has a lot of mechanical grip so will still 'correct' itself and you really need to do something stupid to come unstuck. You can't argue with physics
      02-14-2017, 10:02 PM   #8
DelGriffith
DelGriffith's Avatar
325
Drives: 2019 SO M2C
Seems to me that no matter what mode the car is in, a long press of the traction control button will place it in sport mode with no nannies. Wish sport+ could be maintained, but it appears not. Is this the "race" mode previously referenced? Or is that simply sport+? Seems to be slightly limited in terms of modes with regards to traction on/off....
'02 E39 M5-Gone
'07 E60 M5-Gone
'07 E64 M6 Cab-Gone
'17 F87 MG M2-Gone
'19 F87 SO M2C
      03-10-2017, 07:52 AM   #9
Twt
Twt's Avatar
634
Drives: 2017 M2
If you code the car to switch from US MDM to the euro one you can run sport plus with much less intrusion....it's not a perfect solution but it help a lot.
      03-14-2017, 12:14 AM   #10
jayg80
jayg80's Avatar
217
Drives: M3
I feel like a short press of the traction button puts the throttle into comfort which is painfully slow response. Is it just me?
VegasM285.50
      03-14-2017, 02:44 AM   #11
SupraSaiyan
45
No, that's the way it is unfortunately...
      03-14-2017, 08:10 AM   #12
Elwood74
Elwood74's Avatar
76
Drives: 2017 M2
Sport + really just remaps the throttle to give you more at smaller initial inputs. This is mostly useful/noticeable down low in the rev band and at slower speeds. But ultimately WOT is still just WOT. No 'extra'. The most likely time you'd be turning everything off would be on the track. And there you'd be using the upper RPM almost exclusively. And for the times you wouldn't, you'd want a very nice modular pedal. Something you do not get with the Sport+ mapping.
      03-14-2017, 08:43 AM   #13
Wangspeed
51
Drives: BMW M2
I don't get why people like sport+ throttle mapping. It is way too sensitive and ultimately gives zero extra power.
      03-15-2017, 02:55 PM   #14
MRufo
36
Drives: M2
I drove an old 530i as a loaner car yesterday while my resonator delete pipe was getting installed. The throttle response was incredible. I got back in my M2 and sport/sport + felt like mush.
At first I actually thought there was something wrong with the car-lol.
...and the Dinan Pipe didn't properly fit and they had to weld it in. I should probably start another thread about that! The shop staff was very surprised-they said the Dinan parts usually fit perfectly.
      03-17-2017, 02:37 PM   #15
ben_lzn
75
Drives: 2011 135i M pkg
One more question to double check this.
Is there as way to combine Sport mode (so auto rev match is ON) + limited traction control in the same time?
      03-17-2017, 02:58 PM   #16
Prollig
Prollig's Avatar
118
Drives: 2017 M2
That would be Sport+
      03-17-2017, 03:38 PM   #17
ben_lzn
75
Isn't Sport+ turning the rev match off?
      03-17-2017, 04:51 PM   #18
Prollig
Prollig's Avatar
118
Drives: 2017 M2
Rev match stays on in sport + and every mode including comfort. It only goes off when you turn DSC all the way off. (long press)
m2
