02-13-2017, 01:57 PM | #1 |
BimmerPost Supporting Vendor
2926
Rep 21,738
▀▄ eas | Vorsteiner VFF 103's installed on an M2
Enjoy the newest photoshoot from Vorsteiner featuring the VFF 103 wheels in carbon graphite. These wheels are specific M2 fitment. Front is 19x9 et 24 and 19x10.5 et 34. Enjoy!
Year/Make/Model: 2016 BMW F87 M2 Color: Mineral Gray Transmission: DCT Modifications: BMW M performance Electronic Steering wheel Vorsteiner VFF 103 19 inch wheels
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
02-14-2017, 11:04 AM | #4 |
189
Rep 252
we are using Pirelli P-Zero Tires @ 245/35/19 and 285/30/19
Our vehicle has been lowered with eibach springs which naturally created camber from the lower center of gravity. These M2 specific rear wheels are made for tuning fitment |
02-16-2017, 03:50 PM | #7 |
189
Rep 252
BMW M2 Stock Wheel Weights:
Front: 22.2 lbs Rear: 24.2 lbs Total Weight: 92.8 lbs Vorsteiner VFF-103 19 inch Tuner Spec: Front: 19x9J - 22.5 lbs (Note: Clears Carbon Ceramics) Rears: 19x10.5J - 22.2 lbs Total: 89.4 lbs Total weight saving over stock Forged Wheels: 3.4 lbs Please Note: Tuner Spec are for vehicles with Lowering Springs or Coilover System. Our M2 pictured above was equipped with the Eibach Springs. |
02-20-2017, 06:07 PM | #9 |
189
Rep 252
regarding stock height, the wheels will most likely poke past the body so running a more aggressive rear tire may post an exaggerated poke and possibly rubbing. I know our German Distributor has utilized factory 265/35/19 but that will cause a mild stretch which will prevent the rubbing issue but aesthetically, to each their own. we like to recommend the tuner setup for vehicle that are preparing for suspension modifications as we are trying to increase track for additional grip purposes. Thank you
02-21-2017, 11:33 PM | #11 |
658
Rep 1,922
Drives: 2011 e91
10.5 et 40 will only poke about 7mm more than stock, so it should be pretty flush
2011 E91
2016 M2 - Sold 2014 X1 - Sold 2002 Land Rover Discovery II - 3" lift & 33s |
02-25-2017, 04:45 PM | #12 | |
93
Rep 151
Kevin can you please PM me a quote for these wheels? |
02-25-2017, 05:05 PM | #13 |
2351
Rep 2,829
Drives: E36M,E46M,E90M,X5M,i3,M2,i8
It's the same m2 ordered my should be here in 2weeks
BMW I12 i8 Frozen Yellow- H&R springs, 22" Radenergie F10 Monoblock Forged /// F87 M2 Aw -Vorsteiner Aero Kit, VFF-107,Macht Schnell-Springs,VF-Engineering/Hex tuning Stage Two,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe/// Wish list :Mexico delivery 2024 BMW M2 (G87) |
02-26-2017, 12:58 PM | #14 |
93
Rep 151
02-28-2017, 02:00 PM | #15 |
2351
Rep 2,829
Alpine White, yes once I have them on
11-10-2018, 01:02 PM | #16 | |
300
Rep 359
I just ordered a set of VFF-103's in 19x9J and 19x10.5J, front and rear, respectively, for my M2Comp. I was told ET21 and ET40. Is that correct? Also, I contemplate running 255/35 and 277/35 on them on stock suspension. Would you recommend alternative size? |
11-10-2018, 06:50 PM | #17 | |
55
Rep 92
19x9.5 et22 19x10.5 et34 255-35-19 275-35-19 |
11-21-2018, 05:23 PM | #18 | |
47
Rep 251
BMW M2 2018 LBB
BMW X1 2016 PSM Audi S4 2014 SMG |
06-30-2020, 10:26 AM | #19 | |
725
Rep 929
Drives: 2019 F87 M2C, 2023 G87 M2
