02-05-2017, 04:58 PM | #1 |
367
Rep 454
Variable Damper Control VS Adaptive Drive
I'm in a big dilemma, not sure if I should go with AD or only VDC. I'm sure this will be interesting to many people, especially since G30 uses a new AD technology.
If I'm right, VDC is doing most of the great and the important stuff such as stiffens control and the dynamic suspension adjustment. AD just adds the Anti Roll to the story. Now the question is, is the Anti Roll needed at all on the G30? I don't expect this car to roll much even without it, plus slightly rolling car might offer a better and more natural feeling in the curves. So how I see it now, two disadvantages of the AD are: 1. It costs a lot. 2. I adds wight to the car. While the advantage is less rolling but with a questionable influence to the return info to the driver. I already ordered a car with the AD, but I still have time to modify the order and I'm thinking of removing AD from the config (and then maybe to add 4 wheel steering instead). |
02-05-2017, 06:39 PM | #2 | |
578
Rep 473
2023 BMW G05 X5 xDrive40i
2023 BMW G30 540i |
02-06-2017, 07:27 AM | #3 | |
6659
Rep 15,858
I opted for AD on the F10/11, because I wanted the widest possible working envelope. Extra comfort (for me as driver and passengers) and better handling, with that comfort ability, all in the same package. Possible at the toggle of mode switch. VDC only gives one element to that requirement. ARS adds more than just 'less roll' when pushing on through the curves, gives a more comfortable ride at the same time. ARS assists straight line comfort, as each wheel has better independent VDC capabilities, not influenced by cross car 'copy' stiff ARBs induce. ARS is tuned to give a better handling balance than you can get with fixed rate ARBs, is adjusted according to how hard you drive. From a neutral chassis balance in less demanding conditions, tuned 'on the fly' to slight understeer as you work the suspension. I will be looking to test AD in the G30/31, see how it is improved (BMW claims) over the F10/11 system. I rate it in my F11 wagon. ARS being the key part in making the chassis suspension characteristics I want from a 5-series. |
02-06-2017, 07:41 AM | #4 |
18
Rep 49
I'd definetely prefer 4-steering wheels instead of AD. It improves both safety (higher speeds) and comfort (maneuverability at low ones). It is much easier to drive with it (especially in Europe with its narrow streets). In my opinion roads in Switzerland are level enough to drive on comfortably with VDC
02-06-2017, 02:10 PM | #5 |
Rep 9
I own a F11 with Adaptive Drive, which costed 3700 euro here in Europe.
For G30/G31, I would definitevely go for VDC + IAS instead of AD, as it will be cheaper and more effective. |
02-08-2017, 06:25 PM | #6 |
367
Rep 454
The more I read, the more I get confused
What I don't get is if the AD (AR to be precise) would influence vehicle comfort on the straight road, over the bumps etc (especially with 20' wheels), or this part is done solely by the VDC. Second thing, what offers a better performance in the curves, AR or IAS (VDC would be included in any case). |
02-09-2017, 03:50 AM | #7 | |
6659
Rep 15,858
Depends on what you view as giving better performance, steering or body roll. Roll bars are different part numbers for the VDC and M-sport suspension. Weight difference suggests a smaller bar for VDC equipped cars, hence more roll is possible in the bends than the passive M-sport suspension. My conclusion, VDC optioned cars will roll more than many users would want. VDC will slow weight transfer into bends, but still allow roll as you load the chassis, compared to active roll bars. |
02-09-2017, 07:03 AM | #8 | |
161
Rep 619
My G30 will have VDC... my logic being I'll should have the same control as today, but more comfortable.... it covers most of my driving pattern
Sunset Orange G20 330e xDrive M Sport Pro - Tech/Pro Pack, Park Assist Plus
Bluestone G30 M Sport - Gone to Stud Alpine White F10 M Sport - Gone to Stud |
02-09-2017, 08:22 AM | #9 | |
6659
Rep 15,858
I'm sure your logic is right for the G30 and best compromise for your driving, VDC adding extra comfort when desired. UK motor mag tests are concluding (recommending) VDC is optioned for a better ride quality on UK roads. Makes a lot of sense, IMO. |
02-09-2017, 01:22 PM | #10 | |
18
Rep 49
02-09-2017, 01:52 PM | #11 | |
1312
Rep 10,185
No, that has been changed on the G30 (And G11) It no longer uses the fully variable planetary gearbox for the steering, but rather uses the variably cut steering shaft just like the "sport steering" on other BMW models. So the ratio changes the further you turn the steering whee. This is fixed and does not adapt to conditions
BMW if you are reading, I need a job, Please. |
02-09-2017, 02:30 PM | #12 | |
18
Rep 49
02-09-2017, 02:46 PM | #13 |
1312
Rep 10,185
Probably the rear wheel steering that was activated by DSC
04-20-2018, 09:00 AM | #14 |
Delrosa81
59
Rep 251
I have the G30 540i with adaptive dampers, I don’t really feel much of a difference in comfort or sport mode though but then again, haven been pushing the car much as well. The car is still under 1000miles on the clock still, been going easy on it still. Nowadays, I try to keep the car in adaptive mode as much as possible. I do feel this car has way lesser body roll around corners as compared to my F10 LCI 528i with standard suspension, non M Sport. Both cars on stock suspension.
F20 LCi
04-20-2018, 11:40 AM | #15 |
Live for today tomorrow never comes
1989
Rep 9,498
I have gone Adaptive Drive,
and find it great it's flat in fast corners and smooths out poor road bumps, love it.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
04-20-2018, 11:51 AM | #16 | |
499
Rep 987
Drives: G30 - 530d M Sport
04-20-2018, 01:39 PM | #17 | ||
443
Rep 1,963
Drives: I20 IX M60 Oxide Grey
Running: G30 530d M Sport (B57) Mediterranean Blue
Running: I20 IX M60 Oxide Grey Gone: F15 X5 40d M Sport (N57) Glacier Silver, E61 520d SE Auto (N47D20) Titanium Silver, F31 330d M Sport (N57D30A) Estoril Blue, E87 120d SE Auto (M47TU2D20) Sparkling Graphite |
04-21-2018, 12:47 AM | #18 |
Delrosa81
59
Rep 251
Oic thanks for the clarification. I do have the adaptive dampers too. I don really feel much of a difference between Comfort and Sport Mode though. I do feel that this car is more composed especially around bends compared to my previous F10 LCI.
F20 LCi
04-21-2018, 05:11 AM | #19 | |
499
Rep 987
04-22-2018, 08:13 AM | #20 | ||
Delrosa81
59
Rep 251
F20 LCi
ADS-UK498.50 |
04-22-2018, 09:07 AM | #21 |
1989
Rep 9,498
This car does not require an Oil change at such low miles, is this something you want?.
04-22-2018, 09:32 AM | #22 |
Delrosa81
59
Rep 251
Yes, I’m aware but I’m rather old school, flushing out the metal particles of a new engine before pushing it hard.
F20 LCi
