01-28-2017, 08:37 AM | #1 |
2924
Rep 1,303
Drives: 2021 C8 Corvette 1LT
B58 Map 1 Operating Temps
So just did a 20-25 minute trip on map 1 with the JB4 app (Thanks Mike @ x-ph for my BT adapter). I was curious what normal operating temps were for the B58 and couldn't find anything so wanted to post my results and see if anyone else has their own input and numbers to add.
5 minute warmup = 130F 1-2 minutes of driving = 160-165F 10 minutes = 185F 15 minutes = 226F (never went above this temp) I was in Comfort mode/map 1 the whole time, outside temp is 35F, and IAT stayed between 45-50F while driving, ~60F when idle Trans temps were: 5 minute warmup =75F 1-2 minutes of driving = 95F 10 minutes = 108F 15 minutes 120F 25 minutes = 140F |
01-28-2017, 08:39 AM | #2 |
2924
Rep 1,303
Forgot to mention only have the BMS CAI and JB4 installed during this run.
01-28-2017, 07:15 PM | #3 | |
Newer 2er
296
Rep 474
Drives: 2017 M240i (Sold)
2017 BMW M240i (Sold)
2021 F-150 Raptor 2017 Porsche 718 Cayman S 2017 Audi Q5 |
01-28-2017, 08:28 PM | #4 |
2924
Rep 1,303
Not sure why but the JB4 app when I select "water" it constantly reads 0F. I was assuming it didn't have a coolant gauge to read.
01-28-2017, 08:57 PM | #5 |
689
Rep 908
Drives: '17 F22,15 E84 M Sport,02 R53
01-29-2017, 06:31 AM | #6 |
Newer 2er
296
Rep 474
It probably doesn't support it. When researching OBD2 apps it seems some didn't support oil temp, but did provide coolant temp. Also, depended on model and year as well.
01-29-2017, 10:19 AM | #7 |
2924
Rep 1,303
Figured JB4 would have supported them all. It's the b58 version. Only gives oil and trans temp
01-29-2017, 10:21 PM | #8 | |
20
Rep 48
5 minute warmup = 130F 1-2 minutes of driving = 160-165F 10 minutes = 185F 15 minutes = 226F (never went above this temp) |
02-16-2017, 09:16 PM | #9 |
Gunny
30
Rep 623
Drives: '07 E90 335i 6MT, 2016 F10 535
Dang... my n54 engine oil operating temp has always been around 245 f.
2007 E90 335i 6MT, ZSP, Nav, PDC, CA, Montego Blue, Terra Dakota leather, CDV, clutch-stop, E46 M Shift Knob, Logic HVI, JB4 PnP, MS 3" downpipes, Koni Yellow adjustable sport shocks, RE 12mm(f)/BMS 15mm(r) spacers, Blacklines, LUX 5.0 LED halo ring lights, DAEOS (Vista) harness, GP Thunder 7500k fogs, 35% sides-20% rear tint, matt black kidney grill, matt black 335i trunk badge
02-17-2017, 12:07 AM | #10 |
2924
Rep 1,303
N54 is the 228 motor right? They don't have the aux oil coolers
02-17-2017, 06:48 AM | #11 |
Bavarian Love
24
Rep 263
N54 is the 335 engine and some did and some didnt come with the oil cooler. I was fortunate enough to have the stock oil cooler and temperature was always between 210 and 250f. The N54 was running hot !
08 FG2 Civic SI FBO - SOLD
09 E92 335i Xdrive FBO - SOLD 17 F22 230i Xdrive | Alpine White | Coral Red | M-Sport | BMS Intake | JB4 | 666M Rep | M Carbon Mirrors | Roof Rack | Daily Driven |
02-17-2017, 08:22 AM | #12 |
2924
Rep 1,303
Ah ok. That does seem pretty hot to run at.
02-17-2017, 08:54 AM | #13 |
689
Rep 908
I still do not get how after sitting for 12 hours in 33 degree weather - immediately on startup the coolant is reported @ 47degrees in Torque.
02-17-2017, 12:05 PM | #14 |
2924
Rep 1,303
The B58 motor is designed to retain heat so it can run more efficiently. When a motor is cold, it doesn't get the best mpg/performance and it also pollutes more. That's why they went this route with the B series engines.
02-17-2017, 12:42 PM | #15 |
Rep 18
I switched the gauges on the JB4 app this morning to check these temps.
On sport / map 3 I was also seeing oil around 226F, but my trans temp was about 228F. Would temps be different for a manual? ambient temp ~58F |
02-17-2017, 01:30 PM | #16 |
2924
Rep 1,303
Possibly. I was only driving for about 20-25 minutes total and trans temp hit 140ish. It was also like 35 outside
02-22-2017, 11:06 AM | #17 |
689
Rep 908
While that may be so - I was out of town from from Fri-Monday and when I got in the car (5am on Monday morning)- ambient air was 33F - the Torque app still registered 43F - That's after a weekend of not being driven and below freezing night time temps, day time temps were not into the 40's.
I also understand the thermodynamics of why the motor @ operating temp is more efficient, I just don't understand why Torque is reporting temps consistently higher. |
02-22-2017, 11:48 AM | #18 |
2924
Rep 1,303
Hmm that is odd to have it reading warmer like that.
