Help: Foam polishing Pad soak with Compound / Wax / Glazes
01-21-2017, 02:34 PM | #1 |
401
Rep 1,425
I detailed my car with Chemical guys 10fx.
I followed CG youtube instruction, 3 dots per area for 5.5 foam pad. (E.g) the hood is divided into 4 small areas, which means I used 12 dots on a single pad for the hood. After polishing the hood, I found lots of powder on the pad, so I used a toothbrush to get rid of the powder. After I was done detailing, I went to wash the pad, when I squished the pads, fresh wax, compound, glazes came right out of the pads, it look like they just came straight out of the bottle. So did I use product too much on the pads? If Yes, whats the correct amount for each pad for the hood.
3IM . Okada Plasma Direct . Euro Ram Intake . AA header (Pending) . PE . 2nd Cat Delete . F30 340mm 6 pot . EBC Yellow Stuff . StopTech SS Brake Line . BMW Performance CF Strut Bar. 219M . PSS
01-23-2017, 08:32 AM | #3 |
74
Rep 322
I usually spray liberally with APC initially after use, If more cleaning is necessary then I let them soak for few minutes in a 5 gallon bucket filled with about 3-4 gallons of water with a diluted pack of Snappy Boost Cleaner .....if necessary I give em a few wrings and they come out pretty clean.....
MHD Stage 1+ FMIC // VRSF 5" stepped// StopTech x-drilled Centric Posi-Quiet Ceramic Pads // Wiesslicht AE's // OEM Blacklines // Matte Kidneys // MonoChrome emblems.....
01-24-2017, 07:43 AM | #4 |
360
Rep 5,052
Cleaning is absolutely critical. You need to clean your pad as you are working and also very thoroughly once you are finished.
You should also use several pads for each job. As your pads become saturated with spent product and paint residue, they will become less effective. I typically recommend a minimum of 3 pads for each step of the paint correction process (ie 3 for compounding and 3 for polishing). You can find plenty of information in this article about pads and pad cleaning.... Polishing Pads: How Many Do I Need? by Zach McGovern |
01-26-2017, 08:01 AM | #5 | |
601
Rep 2,703
Drives: 2009 335i - Sport PKG
Zach, what is the best way to clean pads during and after? |
01-26-2017, 08:28 AM | #6 |
360
Rep 5,052
This article walks through the basics...
Pad Cleaning During and After Polishing by Ivan Rajic For microfiber pads, I prefer to use compressed air to clean them out during use... How to Clean Microfiber Pads with Compressed Air by Zach McGovern and I like to use a pressure washer after use to get the majority of the crud out before I finish cleaning them by hand... Pad Cleaning Using a Power Washer by Greg Gellas -Zach |
