F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > BMS Releases the B58 Catch Can
proTUNING Freaks
      01-18-2017, 05:47 PM   #1
Mike@N54Tuning.com
BimmerPost Supporting Vendor
4907
Drives: 2007 335i, 2015 M3
Happy to announce the release of the B58 Specific Catch Can to join the line of other Catch Can's BMS has in their catalog.
The catch can requires the BMS B58 intake to be installed in the car!!
BMS Turbo Double Baffle Oil Catch Can Features
• Increases Air Intake Efficiency
• Promotes Engine Longevity
• Non-Clogging Air/Oil Separation Double Baffle
• Free Flow Solid No Restriction Design
• Retains factory fully closed loop PCV operation
• Large Intake / Exhaust No Tapering Down
• Stealth Mounting on Cool Side of the Motor
• Anodized Black Lightweight Aluminum
• N54 Model Mounts Out of Sight Under the Cowl
• Made in USA & Guaranteed for Life
Applications:
BMW 1 Series
• 2008-2013 E82 Coupe E88 Convertible 135i / 1M
BMW 2 Series
• 2014-Present F22 Coupe F23 Convertible 220i / 228i
BMW 3 Series
• 2006-2011 E90 Sedan 335i / 335ix (E chassis only)
• 2006-2011 E91 Touring 335i / 335ix (E chassis only)
• 2006-2013 E92 Coupe 335i / 335ix / 335is (E chassis only)
• 2007-2013 E93 Convertible 335 including ix (E chassis only)
• 2013-Present F30 Sedan 320 including ix (E chassis only)
• 2012-Present F30 Sedan 328 including ix (E chassis only)
• 2015+ S55 F80 M3
• 2016+ B58 F30 340 including ix
BMW 4 Series
• 2014-Present F32 F33 F36 Sedan Convertibe Gran Coupe 420 428 428 including ix
• 2015+ S55 F82 M4
• 2016+ B58 F32 F33 440 including ix
BMW 5 Series
• 2008-2010 E60 Sedan E61 Touring 535 including ix
• Simply unscrew base every 3-6 months to empty or use the 1/8th NPT drain plug.
• Non-Clogging, No Service Needed Air/Oil Separation Double Baffle
• High flow to eliminate crankcase pressure caused by more restrictive designs
• Large 16mm+ inlet and outlet exceeds OEM PCV sizing
• Precision Machined from Solid Blocks of High Grade Aluminum
Note: Does not fit any other vehicles other than the exact vehicles and dates listed above. An oil catch can for F chassis N55 vehicles is not available.
      01-18-2017, 06:33 PM   #2
Roki187
Roki187's Avatar
126
Drives: Rocket :-)
Price???
      01-18-2017, 06:36 PM   #3
mike@x-ph.com
mike@x-ph.com's Avatar
24029
Drives: 07-335/12-328/18-M4/21-M4CP
Originally Posted by Roki187 View Post
Price???
Check the vendor section haha
https://x-ph.com/sale/
Phone number 702-494-9435
      01-18-2017, 07:14 PM   #4
Mike@N54Tuning.com
4907
Originally Posted by mike@x-ph.com View Post
Requires the Burger Tuning intake as well
We shouldn't be talking price here
And yes mike is correct the unit requires the intake for proper fitment!
Mike
      01-18-2017, 07:15 PM   #5
mike@x-ph.com
24029
Mike
I thought we are allowed to post retail price but not vendor pricing ... I will fix it before i get in trouble haha
      01-18-2017, 07:16 PM   #6
Roki187
Roki187's Avatar
126
Drives: Rocket :-)
Retail is $199 but it requires the Burger Tuning intake as well
Awesome, thank you Mike. And I already purchased the intake just not sure if it's worth it since I only have 1500 miles in 4 months and it's a lease. Not trying to be cheap but I'd like to put some $$ into my other never ending project car.
I remember n54s benefiting greatly from a catch can setup but that's a air to air intercooler and a smaller separator setup, would there be as much build up on the b58? Also the charge pipe on the b58 has a steep incline, do you think oil would make its way all the way up?
      01-18-2017, 07:29 PM   #7
Mike@N54Tuning.com
4907
I remember n54s benefiting greatly from a catch can setup but that's a air to air intercooler and separator setup, would there be as much build up on the b58? Also the charge pipe on the b58 has a steep incline, do you think oil would make its way all the way up?
Oil is mostly vapour so it gets spread around and pools at low points. With OCCs getting them in sooner then later is usually best so they can work their magic and keep the system clean.
Mike
      01-18-2017, 07:45 PM   #8
Roki187
Roki187's Avatar
126
Drives: Rocket :-)
I'm sorry about that. Not intentional.
      01-18-2017, 07:46 PM   #9
mike@x-ph.com
24029
No worries about it, my post was in reply to Mike ... you can post prices, vendors are not
      01-18-2017, 07:50 PM   #10
Roki187
Roki187's Avatar
126
Drives: Rocket :-)
Mike
Well that's my point, the low point of the charge pipe is at the turbo, so it should pool there but not sure it would get pushed up the charge pipe and into the intake manifold. I'll insect my charge pipe when it gets little warmer. But great looking product nonetheless
      01-18-2017, 09:02 PM   #11
Mike@N54Tuning.com
4907
Post up some pics of it when you inspect it and note the mileage on the car as well if you could.
Mike
      01-18-2017, 09:54 PM   #12
SingleturboVert
49
Drives: E93 335i
This looks like a nice piece!
      01-19-2017, 09:42 AM   #13
Mike@N54Tuning.com
4907
+1
BMS makes some nice catch cans.. All made in USA as well
Mike
      01-20-2017, 11:53 AM   #14
CruzM3
CruzM3's Avatar
284
Drives: 2018 M3 "Velocity Edition"
Thats to bad it onky works with there inyake as I've been waiting for this for awhile now. I don't plan on getting the BMS intake.
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s)
2017 340i w/ MPPSK & Many M Performance Parts (sold)
2016 328i (sold)
      01-23-2017, 02:56 PM   #15
SingleturboVert
49
Drives: E93 335i
What were you going to get? Or just remain stock airbox?
      01-23-2017, 05:21 PM   #16
CruzM3
CruzM3's Avatar
284
I was planning on remaining stock and waiting to see if others come out with anything that piques my interest.
2016 328i (sold)
      01-23-2017, 05:40 PM   #17
mike@x-ph.com
24029
You cant go wrong the BMS intake at current price point
      01-23-2017, 10:30 PM   #18
ray340i
284
Drives: 2016 340i msport
Just ordered mine ! Will be posting pics soon
      01-23-2017, 10:37 PM   #19
E90ROXS
E90ROXS's Avatar
225
Drives: E90
Can you guys make something that makes more power????
      01-24-2017, 12:25 AM   #20
mike@x-ph.com
24029
Congrats
      01-24-2017, 09:07 AM   #21
Mike@N54Tuning.com
4907
Like a JB4
Mike
      01-24-2017, 09:35 AM   #22
kern417
Cheapskate
4445
Drives: 2018 440i |2016 340i | 2010 X5
keeping oil out of the intake tract and cylinders "reclaims" lost horsepower. more efficient cooling, better airflow, and more efficient combustion.
Search this Thread:
Advanced Search
f30post
